Question about GE Dryers
Dryer heat starts then no heat
I have a ge gas dryer model# dvl223gb5ww, when I start dryer I see light for heating coinl or whatever it is then after 10 min or so I go down and still spinning but no more heat
  • jessicaarice Jun 18, 2009
    ok i looked inside and noticed, at times no glow, then a flicker, then glow for bit. then no glow
  • jessicaarice Jun 19, 2009
    ummm.....I dont know for sure there is gas flow, sometime when I open dryer there is heat and clothes drying, sometime just cold air in there. would I see and actual flame underneath when that thing is glowing?
  • 6,784 Answers
Hi, the most common issue will be a set of defective coils but, i suggest that you run through all points and check all the listed check points before replacing the coils.
1. Gas valve coils
igniter glows, then shuts off without igniting gas - the problem is probably with defective coils (black, located on top of the gas valve). It is recommended to replace all coils (usually two or three) if found defective.
Note: Sometimes the whole gas valve may be defective, thus not letting the gas out. However, this problem is not common.
2. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Note: It is recommended by most dryer manufacturers to replace a hi-limit thermostat when replacing a thermal fuse.
3. igniter
igniter may burn out or break. Replace the igniter if found defective.
Note: Igniters are very fragile and break easily. It is recommended to handle the igniter only touching the ceramic part of it (usually white in color).
4. Flame sensor (or radiant heat sensor)
Replace the sensor (located near the igniter) if found defective.
Posted on Jun 18, 2009
  • Michael Masters
    Michael Masters Jun 18, 2009
    ok, do you get any kind of flame or, is the gas flow not flowing at this point?
  • Michael Masters
    Michael Masters Jun 19, 2009
    yes, the flame will cycle.
Location ignition module
i need the location of a ignition module on a 1986 nissan sentra with a 1.6L
Jan 02, 2014 | GE Dryers
Had a flood in the basement. THe electric motor works by there is no heat. Turned on the main and cutoff valve to the dryer started the dry it tumbles just fine but still no heat. Don't think...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Sep 06, 2011 | GE Dryers
Ge profile dryer drum turns but therte is no heat
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Oct 27, 2010 | GE Dryers
My ge dryer wont heat up
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Jul 08, 2010 | GE DWSR483GB Gas Dryer
My dryer only lights the first time.
heatman101
Jul 05, 2010 | GE DVLR223 Dryers
GE Profile gas dryer won't ignite
heatman101
Jun 01, 2010 | GE Profile DPXH46EAWW Gas Dryer
GE Dryer Model #DWSR483EB2WW Dryer tumbles,
Does it get hot when you start the dryer, and never gets hot again when its running? The solenoid wire might be opening due to heat, the solenoid is responsible for opening the gas valve, and booster valve. The wire is located in a round plastic sleeve with two electrical contacts sticking out.
Dec 11, 2009 | GE DBSR453EBWW Electric Dryer
Ge dryer model dbvh512gfoww not heating can hear ignitor clicking but will not light
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
uifg
Nov 02, 2009 | GE DBVH512GFWW Dryer
GE Gas Dryer (Model DQSR 483) Drum works but does not heat
There are three things besides what you aleady checked:
1. Open the small access door in front of the dryer and start the heat cycle. The ignitor must glow a bright orange so that it is hot enough to light the gas. If there is no orange glow, then the ignior needs replacement.
2. If it glows then cuts off, then glows, again and cuts off, the thermocouple sensor wire is out of position. It needs to be very, very close to the ignitor. This thermocouple sends a temperature signal when it senses that the ignitor is hot enough to ignite the gas. Unplug the dryer. Re-position the thermocouple wire mount so that the thermocouple wire is almost touching the ignitor. You may also "bend" the wire. Plug power back on and heat.
3. If it still does not heat, then the automatic gas valve that is controlled by the thermocouple sending unit is broken. The automatic gas valve cannot be safely "fixed" and must be replaced.
Hope it's just the thermocouple wire.
Oct 01, 2009 | GE DBXR463EBWW Electric Dryer
Ge gas dryer runs but does'nt heat
Open Front panel and check to see if ignitor is glowing when you start the dryer
Apr 16, 2009 | GE DBXR463GB Gas Dryer
Dryers Logo
165 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
vince
Are you a GE Dryer Expert? Answer questions, earn points and help others
