Question about Keurig Platinum B70 Coffee Maker
Leak were do get the o ring
  • 3,961 Answers
If it is a standard sort of 0-ring, any size, you can get these from any hardware store
http://www.homedepot.ca/wcsstore/HomeDepotCanada/images/catalog/15449.M3969_4.jpg
Posted on Apr 17, 2014
Why is my newly rebuilt 5.7 350 chev. Engine burning so much oil. It's not leaking, and not smokeing out tail pipe?
what was entailed in the rebuild?
cylinders bored and hone , new pistons , rings
crank grind and new bearings
or was it just a ring refresh and sand paper on the cylinders
I'm thinking the latter ( cheap and nasty)
The oil will be coming past the rings and being burnt in the exhaust ( cat converter if you still have one )
That oil passing the rings comes from , glazed bores , rings being installed upside down, ring gaps not being set 120 degrees apart but almost lining up
worn ring lands in the pistons
Sump oil either leaks out -- Gaskets , seals filters or is passed by the rings and burnt in the combustion process
Dec 30, 2015 | Cars & Trucks
I have changed the o ring three time and I cant get it to stop leaking. Two new o rings installed....still leaks. large o ring sx200z7
Had problems with these types before also. As the filter ages it warps and thats a problem lol.
You said you cleaned the recesses Im hoping top and bottom and lubricated the recesses IN addition to the o-ring, don't hold back on that lube either. And lastly although it sounds odd, dont over-tighten the nuts, tighten them slightly over hand tight turn the pump on for a bit leaking everywher tighten everywhere, leaking in one spot, tighten only that one spot a little.
Putting on all that lube doesnt do too good when it spits it out from pressure.
Also pics next time, and good luck!
Nov 12, 2015 | Pool & Spa
Oil leak, come from starter oil ring?
yes--remove starter-use new "O" ring.slightly oil "O" ring put it back on
starter.And make sure its firmly seated.
Apr 19, 2014 | 2004 Honda VT 1100 C2 Shadow Sabre
What causes excessive oil usage in B&S engine?
The piston rings are going bad, or you have a leak some where.
Look for leaks by washing down the unit so you can see where the oil is coming from.
It may only leak when running, so you may have to run it until it warms up and then look for the leak. Most of the time i notice the dipstick tube o-ring is bad at the bottom of the tube. Replace the o-ring to stop that leak.
If its the piston rings, then your motor probably smokes while its running or when you really work the motor such as mowing thick high grass.
You spark plug will be oily and indicate to you that the rings are allowing oil to pass by.
To fix that, you have to freshen up the top end of the motor, with new rings and possibly new piston if the cylinder needs bored.
Check for leaks first, then pull the spark plug and see if its oily.
Dec 03, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Thermostat leaking. I have a 2002 Ford explorer v6 4.0 it was leaking antifreez so I changed the o ring and it is still leaking. When i drained the radiator the white plug is now leaking also. I only...
IF O - RING STILL LEAKING YOU COULD OVER TIGHTEN CRACKED IT.NOW FORD V6 USES THERMOSTAT GASKET WHERE YOU PUT RTV SEALANT ON BOTH SIDES.BUT IF USING O - RING IT SHOULDNT LEAK NONE.THE DRAIN PLUG NEEDS NEW O RING.BECAUSE IT CAN BE SCREWED ALL THE WAY OUT REPLACED. IF DRAIN PLUG DONT HAVE O - RING YOU CAN USE THE PLUMBERS WHITE TEFLON TAPE TO SEAL THREADS FROM LEAKING COOLANT.
Aug 12, 2010 | Ford Explorer Cars & Trucks
Gas leaks from the gas cap past the rubber o-ring
Ethanol fuel is causing many problems with 2 stroke engines. I would recommend purchasing another fuel cap and rotating them. Let one dry out while using the other. Usually they will work fine for a day and then rotate the dry one in. Ethanol is causing the cap to warp.
May 15, 2010 | Garden
By MANY accounts,not the best choice.Lots of probs starting,exhaust breaking,and one review with your exact point of the leaking gas cap,but his dealer got it fixed.Tuff call,but I don't think "grease" on the o-ring is a top answer,since the gas will just get rid of it sooner or later.If it's not a big choice to fix,I might try a few wraps of TEFLON TAPE like plumbers use on connections and see if that helps.
Mar 27, 2010 | Garden
Water Pump leakes from steel tube.
when installing new o-ring on tube, lubricate o-ring and stick it in water pump. Then pull pressure back on tube and then tighten hold down clamp. problem solved
Apr 16, 2009 | Dodge Caravan Cars & Trucks
Persistent problem of leaking clutch cover on 1997 tl1000s
You can see the 2003 cover for the TL1000R here. It is number 25A. Or perhaps item 7-2 for a 2001 TL1000S here?
Mar 16, 2009 | 1997 Suzuki TL 1000 S
Keurig Platinum B70 Coffee Maker Logo
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
