Question about Zeiss 30 SL/M Slit Lamp
No light on **** lamp - Zeiss 30 SL/M Slit Lamp
2000. Where is fuse for tail lights?
Do your headlamps work ?
Park/Marker/License/Tail Lamps
Voltage is applied to the turn/headlamp switch at all times. When the turn/headlamp switch is in the PARK or the HEAD position, voltage is applied to the following components:
The park lamps
The marker lamps
The tail lamps
The license lamp
The front marker lamps are grounded through the turn filament of the respective front park/turn lamp. The front marker lamps light as a result.
The automatic lamp control function turns on the park lamps and the headlamps. This action occurs when the ambient light sensor determines that the exterior lamps should be turned ON based on the amount of available light. When the BCM grounds the park lamp relay, voltage is supplied directly to the park lamps, bypassing the turn/headlamp switch assembly. When this action occurs, the following conditions exist:
The automatic lamp control relay is grounded.
The headlamps turn ON. Refer to Headlights/Daytime Running Lights (DRL) Circuit Description .
The lamps turn OFF when the BCM does not ground the park lamp relay or the automatic lamp control relay. This action is caused by the following conditions:
The available light reaches a predetermined level.
The ignition switch is turned to the OFF position
Mar 31, 2016 | Pontiac Grand Am Cars & Trucks
Why aren't parking lights working?
Park lamp fuse 20amp located in the under hood fuse box .DRL control module
Daytime Running Lamps (DRL) Control Module
Right of the steering column, behind the IP
Park, Sidemarker, Tail and License Lamps
Voltage is applied continuously to the PARK fuse to the headlamp and the instrument panel (IP) lamp dimmer switch through CKT 1340.
When the headlamp and the (IP) lamp dimmer switch is in the PARK or HEAD position, voltage is applied to CKT 9 thus activating the following lamps:
• The park lamps
• The side marker lamps
• The tail lamps
• The license lamps
The park/turn lamps are the only lamps that do not activate yet receive a current from CKT 9. The park/turn lamps do not activate because the voltage drop across the front side marker lamps is much higher than that across the turn lamp filaments Step
Action
Normal Result(s)
Abnormal Result(s)*
Turn the headlamp/instrument panel (IP) lamp dimmer switch to the PARK position.
The following lamps light:
• The license plate lamps
• The taillight lamps
• The front side marker lamps (Domestic)
• The front parking lamps (Domestic)
The headlamp position lamps (Export)
Refer to Park Lamps Inoperative
Step
Action
Value(s)
Yes
No
Inspect the PARK LP fuse.
Is the fuse open?
YES - Go to Step 2
NO - Go to Step 3
Repair a short to ground in CKT 1340.
Is the repair complete?
Go to Exterior Lights System Check
Use a test light in order to backprobe the headlamp/IP lamp dimmer switch harness connector between terminal R and ground.
Did the test lamp light?
Go to Step 7
Go to Step 4
Use a test light in order to backprobe the headlamp/IP lamp dimmer switch harness connector between terminal O and ground.
Go to Step 5
Go to Step 6
5
Replace the headlamp/IP lamp dimmer switch. Refer to Headlamp Switch Replacement .
6
Repair the following conditions in CKT 1340 between the PARK LP fuse and the headlamp and the IP lamp dimmer switch harness connector terminal O:
• A faulty connection
• An open circuit
7
Repair the following conditions in CKT 9 between the headlamp and the IP lamp dimmer switch harness connector terminal R and S204:
• An open circuit
Feb 18, 2016 | 1999 Pontiac Montana
How do I fix 62HM15 picture. Have sound-No Picture. Have red light steady and Green light blinks 8 times and cuts off and back on.
Usually 8 flashes means the lamp is not lighting.
When most lamps go bad , they physically crack because of excess heat.
The problem is probably the lamp or the ballast, which makes the voltage to light the lamp.
Replace lamp and remember to close the lamp access door after replacing, because the lamp will not light if the door is open an
Jan 23, 2015 | Toshiba 62HM15 62" Television
Trunk cargo light not working after LED installed....
The SJB supplies power to the interior lighting system. The SJB will set DTCs if certain circuit failures exist with the interior lighting system.
Visual Inspection Chart Mechanical Electrical
  • Courtesy lamps
  • Map lamps
  • Luggage compartment lamp
  • Vanity lamps
  • Glove compartment lamp
  • Smart junction box (SJB) fuse 3 (15A)
  • Circuitry
  • Courtesy lamps
  • Map lamps
  • Vanity lamps
  • SJB
Check fuse # 3 SJB
Jul 07, 2017 | 2010 Ford Fusion 2.5
I have had ongoing lamp issues. I have purchased 2 new lamps, (Phillips) The new lamp won't light, but the old original lamp will light but is dim. Why would the old lamp light and new one won't. The...
Hi, You old lamps were compromised due to long usages while the news lamps are defective. They may manufacturing defect. Please claim the new lamps to supplier then.
Regards ,Jay
Jan 28, 2011 | Panasonic PT-56LCX66 Television
Arm 205 display error F5 02 what this the solution for resetting ???/
the error F5 02 means that the copy lamp lighting is abnormal.
This is what is in the service manual:
F5 02 Content Copy lamp lighting abnormality
Details The copy lamp does not light up.
Cause Copy lamp error
Copy lamp harness abnormality
CCD PWB harness abnormality
Check and remedy
Check the copy lamp (SIM 5-3)
When the lamp lights:
Check the harnesses and connectors
between the CCD unit and the MCU PWB.
When the lamp does not light:
Check the harness and connector
between the copy lamp and the MCU PWB.
Replace the copy lamp unit.
Replace the MCU PWB.
Remarks Copy lamp disconnection
Cable is not attached.
You must call a tech to solv your problem.
Dec 01, 2010 | Sharp AR 201 Copier
I replaced the lamp after only a 14 months but it will not light up, then I put the old lamp back in and the lamp comes on momentarally but then shuts off and the TV never lights up. Why will the TV not...
Lamps last between 5,000-8.000 hrs Keep in mind every hour you play TV ,thats an hour lost on Lamp and its also possiable to receive a defective Lamp even new doesnt mean it works.
Lamp Fan if defetive can also prevent lamp from lighting. This happens to protect lamp from running and getting way to hot and therfore buring lamp up .
Ballast Board that connects to lamp is what turns the lamp on,if the ballast board is defective Lamp will not firer,meaning you either have bad lamp fan or new lamp is defective. Heres another Tip Sony had alot of problems with their Light Engines prices for that part range from $650.00 up to $2,799.00 depending on which light Engine you have? Since your TV is Still under warranty take it in quickly and be sure to ASK about warranty on YOUR Light Engine!!!
Jul 03, 2010 | Sony KDS-50A2000 50" HDTV
Projector's lamp won't light up.
Change thermostat and service it.Then solve your problem.
Dec 12, 2009 | BenQ PB8220 Multimedia Projector
Eiki LC-XG110 lamp going off
Lamp is near end of life. Try reseting lamp timer and order new lamp if unit stays on
May 13, 2009 | Eiki LC-XG110 Multimedia Projector
Lamp
red light indicates lamp is expired. even though you get temporary light, the lamp is shot. Try BULBMAN.COM for a new lamp.
Sep 25, 2007 | Toshiba TDP-S20U Multimedia Projector
Zeiss 30 SL/M Slit Lamp Logo
47 people viewed this question
Top Zeiss Science & Laboratory Experts
Gareth Cockram
Gareth Cockram
William McMath
ray gallant
Are you a Zeiss Science and Laboratory Expert? Answer questions, earn points and help others
