Question about Maytag Kitchen Ranges
Precision touch control 800 oven sometimes turns off
Must unplug before it will turn on again
  • 79 Answers
SOURCE: Gas Oven Won't Light
make sure the wire is connected to the ignition(where it sparks)if it is gently clean the sparking surface with a piece of fine sandpaper.Hope this helps,if it still does'nt work you may need to replace this part but it should'nt be expensive and you can do it yourself(usually one screw) ps sorry for the late reply.
Posted on Mar 12, 2009
shinn8
  • 85 Answers
SOURCE: We have a Maytag Gas Range, Precision Touch
Likely your oven igniter is bad. Part number 74007498
Posted on May 18, 2009
shinn8
  • 85 Answers
SOURCE: maytog gas oven model 5765QDB--oven will not heat up
Sounds like your oven igniter is bad.
Part number is 74007498
  • 1531 Answers
SOURCE: Maytag electric Precision Touch 850, Clock and
check the main power at the terminal block and make sure you have the correct amount of power.just because the unit is lit up it may need to be changed.
Posted on Oct 20, 2010
rickead1
  • 1998 Answers
SOURCE: I lost my manual. The touch controls for the oven
hello Ted,
IF your oven is just consistently heating could be that you have a defective tempreture sensor you can do an ohms test on it and it should read between 1000-1100 ohms message me back your model number an i can look up your manual as well as far as the touch controls and the light this would be a control issue which is also most likely why your unit is heating as well which would mean you would look to replaceing the control if you have any further questions message me back and please remember when our chat has fully concluded to rank how this opinion has helped Thanks Rick
Posted on Feb 22, 2011
Why is there a loud noise coming from control panel when I turn on the oven?
How often does it happen? Sounds like your control board is starting to fail. The Repair Shack can fix the oven control board if it needs repaired.
Nov 29, 2015 | GE Profile PT916SRSS 30" Single Electric...
Oven will not turn on after self cleaning has finished
If electric turn the oven to bake and look at the bottom element. If if does not turn red hot, it may be defective.
If gas, turn to bake and watch the igniter to see if it get red hot. If not, it may be defective.
May 22, 2014 | Ovens
How do remove the oven bulb cover in a maytag precision touch control 800?
the trick is to push the metal ring IN at the same time as turning the bulb cover counter clockwise
Feb 01, 2013 | Ovens
The oven is GE JKP15,about 10 years old. Error: F7 - Keeps beeping. Turned on brakers, but it starts beeping again when the braker is turned on.
this code means either a stuck control pad or a faulty control board/display board... one thing to try is turn power off again at breaker and run your hand over all the keys on the control panel firmly pressing each key sometimes you can luck out and free it up if that is the problem and reset power if it starts again you will have to gain access behind the control panel and unplug the ribbon cable to control panel.... if it stops after you unplug ribbon cable most likely it is a bad touch pad assembly if it continues you most likely have a stuck relay on the control board and will need to replace that... i have see the fault require both the touch pad and control board ,but hopefully this will help you ..i assure you it is one of the 2 problems ... g.e servicer for 18 years now and a common problem most of the time happens after a long cooking period or a self clean was preformed recently...
GOOD LUCK
Feb 07, 2011 | Ovens
Oven displays F7 error code and does not function
Unplug the Oven, Disconnect the Power Supply and then Turn the Oven Back, say after 30 minutes. If the code still appears it could be either Faulty Touch Pad or Computer.
Now,
To check, Turn OFF the Oven as we did earlier, then remove the Control Panel . Disconnect the Ribbon like Cable from the Touch Pad. Disconnect it from the Computer. Turn the Oven, and if Code appears Replace Computer Unless Replace Touch Pad.
It is a Valid Model Number. You could buy the same from :-
http://www.repairclinic.com/Appliance-Parts?s=t-JT950B0A1BB-%3d%3d
http://www.cashwells.com/
Let me know, if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Dec 20, 2009 | GE Ovens
F1 is displayed on Maytag Electric Oven I ran the self-clean cycle on my Maytag Model MER5530 oven yesterday; before it completed F3 was displayed and beeps sounded. I pressed CANCEL, the F3...
Hi
F1 error means that you have either a bad ERC (clock) or a bad touch pad. To check these please follow these simple instructions:
  1. Disconnect power to stove
  2. Gain access to the back of the clock (electronic range control or ERC).
  3. Unplug the touch pad ribbon connector from the ERC. This will be a flat wire approx. 1 1/2" to 2" wide.
  4. Make sure everything is clear and will not short out when power is turned back on.
  5. Turn power back on to stove.
  6. Watch for the F1 and listen for the beep.
  7. If you get the F1 and beep, replace the ERC.
  8. If after approx. 30 minutes you do NOT get the F1 and hear the beep, replace the touch pad...
thank u
rate me!!!
Aug 14, 2009 | Maytag Ovens
After a power outage, my Amana Gas easy touch control 800 touch panel does not work. The stove lights and clicks when I light a burner so it's getting electric yet the pad clock and oven don't work. Any...
Has it ever worked since the power outage? Have you tried unplugging it for about an hour and then plugging it back in. Sometimes that can reset the control board and solve your problem. I alway like to try the simplest things first.
May 16, 2009 | Kitchen Ranges
Kitchen Ranges Logo
16 people viewed this question
Top Maytag Kitchen Ranges Experts
vince
gbob59
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
