Question about Refrigerators
Dometic RM 3601 No Gas Operation
The ''no gas'' indicator lights up w/n 15 seconds of turning on the unit. No igniter poping, no gas turned on at start-up. Inspection reveals, 12V to unit is fine, gas solenoid works with 12V jumper, burner flame works with jumper and manual lighting. What voltage should be present at plug from panel board to gas solenoid? Will bad igniter cause no voltage to gas solenoid? What is next to test? Robert
22yooper
  • 828 Answers
SOURCE: won't cool down
The gases in the system may have totally separated. Try (burping it ) as follows. Witht the refrigerator sitting on its base, roll it on to the door and wait 5 minutes, Then roll it to its top so it is literally upside down, wait 5 minutes. Then roll it to its back and wait 5 minutes. Then restore it to its base and wait 5 minutes. Thi procedure will flush the water from the boiler section through the passages of the system and recombine the gases. Then try it on 120 Volts. It takes about 12 hours for the unit to fully cool down.
Posted on Jul 07, 2008
  • 93 Answers
SOURCE: Dometic rm 2652 fridge works on a/c. i get a check
you may need to change the thermocople this cost about 12 dollars this is what make electricity to epen the gas valve thanks from gilles
Posted on Mar 15, 2009
  • 68 Answers
SOURCE: Dometic rm 2612. Shuts down on gas.
Ron;
Check the burner assembly. 1 screw, remove the sheet metal cover and clean it. The burner collects rust. This is the likely. Other issues would be the gas pressure usually checked with a manometer. Should 11" of water column. If your furnace works good then the gas pressure is probably ok. Also could have a faulty ignitor which sends a miliamp signal back to the circuit board. Check the burner first, after that leave the cover off and turn the fridge on. Watch the ingnitor attempt to lite the burner. Be sure the spark is going to the burner and not shorting out on the sheet metal it is mounted in. If it is shorting to the frame the ignitor needs replacing.
Thanks for using Fixya
Jerry
Posted on Mar 31, 2009
  • 122 Answers
SOURCE: Dometic RM2562 - No Flame
use a set of needle nose pliers & disconnect the igniter wire the module should start clicking if it does not click check the wires to the board clean them good & reconnect if the module still wont start clicking your board is bad if it does click the igniter adjustment off stick a nickle between the igniter & burner the gap should be the size of the nickle 3/16"
Posted on Jun 07, 2009
VtToolMan
  • 704 Answers
SOURCE: Dometic rv fridge runs fine on elec, lights on gas
It is key that all control switches are in the correct position, depending on what power source you are using, gas, electric, etc. If the switches are not in the proper setting, the unit will not operate.
Here's the manual for your fridge that should be printed out for your use and reference (and reading enjoyment). It has all the info needed to operate and troubleshoot it.
Typically, when using any gas appliance with a pilot light, the sensor has to first be hot enough to trigger it to allow the safety gas shutoff to open and allow the gas to flow to the pilot/burner. Follow the instructions and you should be all set.
http://gasrefrigeration.net/dom_techdata/2707_2811SM.PDF
Hope you find this helpful and best regards!
Posted on Jul 30, 2009
My dometic fridge will run on electric but not gas
The gas lines are pretty sensitive to corrosion. A lot of times you just need to gently clean off the tip of the line that feeds the gas next to the igniter. Check your igniter as well.
Aug 14, 2014 | Dometic Refrigerators
I have a Dometic rm 2807 when I turn it on the light comes on for the auto then goes to gas then to check It will not even go to ac what could be the problem?
The most common cause of the issue you described is a failure of the lower circuit board. The cycle of the light from auto to gas to check is a fault indicator.
Oct 03, 2013 | Dometic RM2852 Refrigerator
Our Dometic RM2652 RV frig has 2 yellow lights on which are indicated to be alert lights. The frig/freezer seem to be working fine.......????? Is something about to go out on it?
The 2 yellow lites... if you would... Is there and indication by description of what those 2 lights are?
Here are the modes:
OPERATING MODES
AUTO MODE
Press the AUTO/MANUAL mode selector button (2) to the DOWN position. The AUTO mode indicator lamp (A) will illuminate.
When operating in the AUTO mode, the AUTO mode indicator lamp (A) will illuminate. The control system will automatically select between AC and GAS operation with AC having priority over GAS. If the control system is operating on AC energy and it then becomes unavailable, the system will automatically switch to
GAS. As soon as AC becomes available again the control will switch back to AC operation.
If 120 volts AC is not available, the control system will automatically switch to GAS operation. Within 45 seconds the burner should be ignited and operating normally. If unsuccessful, the CHECK indicator lamp (B) will illuminate.
To restart an ignition attempt with the CHECK lamp illuminated or to clear (turn off) the CHECK lamp, press the main power ON/OFF button to the OFF and then to the ON position. The control system will attempt a new 45 second ignition sequence.
On the initial refrigerator start-up on gas (120 volts AC is not available), it may take longer than 45 seconds to allow air to be purged from the gas line. If the refrigerator has not been used for a long time or the LP tanks have just been refilled, air may be trapped in the supply lines. To purge the air from the lines may require resetting the main power ON/OFF button (1) three of four times. If repeated attempts fail to start the LP gas operation, check to make sure that the LP gas supply tanks are not empty and all manual shutoff valves in the lines are open.
NOTE: DO NOT continue to reset GAS operation if the CHECK indicator lamp continues to be illuminated after 3 or 4 tries.
If 120 volts AC becomes available while the CHECK indicator lamp is on, the control system will switch to 120 volt AC operation, The CHECK lamp will not turn off until the main power ON/OFF button is pressed to the OFF then ON position.
In AUTO mode operation, the temperature is controlled by a single temperature setting.
MANUAL MODE
When operating in the MANUAL mode, the AUTO mode indicator lamp (A) will be off, and the refrigerator will run continuously on the energy source selected by the control system.
NOTE: The food in the lower compartment may be frozen if the refrigerator is left on "MANUAL" mode.
STANDBY MODE . .
This control system contains a feature that will continue to operate the cooling system in the event of a failure of a major operating component. If the control cannot read the temperature sensor and operate at the preset temperature, then the control will run the cooling unit like the MANUAL mode.The refrigerator will continue to operate in this mode indefinitely or until a new sensor is installed and the
system is reset.
I posted the above information from the contents of the service manual. I can help you but... at the moment for sure I have come to the conclusion that ONE of the lights your seeing is the CHECK light. The mystery is... what is the 2nd light your seeing? Manual of Stand-by?
I am pretty sure we can sort this out but... we need to really communicate clearly and well. In our posts here.
Thanks for choosing FixYa,
Kelly
Feb 14, 2011 | Dometic RM2652 Refrigerator
I have a dometic rm 4605 aes fridge in my motorhome priblem is wont work on gas can not hear auto ignition spark when turned to gas works ok on 12v & 240v
G'day I have a Dometic RM4605,184LT FRIDGE, AES what setting on gas would you have the fridge set. Settings are between 1 to 5 for max cold in the fridge I did run the fridge for two hours on number 4 setting but it was still 10 degrees in the fridge and -0 in the freezer.
Thanks
Jan 23, 2011 | Dometic Refrigerators
Refrigerator for lp-gas and electri operation RM 2652 RM 2852 It will not light on gas or electric amylynnlpn@yahoo.com
SOLENOID VALVE Check the solenoid coil with a properly calibrated ohm meter. Remove the connector from the solenoid and measure the resistance across the terminals. The proper reading would be 49 ohms with tolerance range of ten percent. . . Next, hook up a manometer at the test port. Then check for DC volts at gas valve terminals while the unit is in trial-for-ianition. If DC volts are present and pressure is low, replace the valve. If DC volts are not present at the valve while the unit is in trial-for-ianition, verify that the wire at Plug 3, Terminal 2 on lower circuit board have DC volts v (9V or more)
IGNITER First verify proper voltage at the positive (+) and ground (-) terminals of the ignitor. The reading should be within one volt of incoming voltage at the main terminal block during trial-for-inanition Next, remove high voltage cable from igniter. The igniter should produce a sparking sound, during trial-for-inanition. If not, replace the igniter. The igniter installed on the refrigerators as original equipment is part number 2931132019 (RV Gas Model 679). This igniter is rated 50 MA. This igniter may also be used on any other model
Hope this helped
Appliance Wiz
Inanition: Proofing for ignition
Dec 27, 2010 | Dometic Refrigerators
98 trailer with a Dometic RM2652 will not ignite on propane
Dometic DM 2652 just installed in travel trailer. Went to plug in and turn on later and discovered no lights or power? what do I start checking?
Apr 19, 2010 | Dometic RM2652 Refrigerator
My RM 2652 when dry camping it uses the 2 batteries overnight ?
OPERATING MODES
AUTO MODE
will illuminate.
the lines are open.
after 3 or 4 tries.
Nov 18, 2008 | Dometic RM2652 Refrigerator
DOMETIC RM 7651l HAVE POWER AND GAS TO THE FRIDGE BUT WONT START (TWO MONTHS OLD)
Igniting a Dometic gas fridge
    Electronic Ignition
    1. Open gas cylinder or pressure regulating valve
    2. Turn on Electronic ignitor switch
    3. Turn gas control knob to the MAX position, press and hold down
    4. After ignition, hold down knob for a further 15 seconds before releasing. The neon light will stop flashing
    Piezo Ignition
    2. Turn gas control knob to the MAX position, press and hold down
    3. After approximately 10-15 seconds
      press Piezo knob several times until pilot light a lit
  1. Check the Pilot light is alight
  2. The flame can be controlled by aperture ©
    Should no ignition occur, repeat the ignition process after 1 minute
    (This could take longer than 10 seconds if the unit has been out of operation for a prolonged period or after replacing the gas cylinder. (Cause: air in the lines)
  3. Once sufficient refrigeration has been obtained in the cooling tank at the MAX position, the control knob should be turned to the MIN position by low outside temperatures or when the refrigerator is only lightly loaded respectively the ambient temperature is below +18c in order to avoid over freezing the contents.
I hope this helps you...
Regards
Wouter...
Sep 30, 2008 | Refrigerators
Refrigerators Logo
195 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
