Question about Dymo Office Equipment & Supplies
Usb device not recognized
No autoplay
2 Suggested Answers
SOURCE: AUTOPLAY doesnt come up wen i insert USB
You should be able to go to the control panel and click Hardware and Sound and then autoplay. Scroll all the way to the bottom of the screen and you should see the name of your usb device. Make sure you select a specific action for your specific USB drive or it may not pop up. Hope this helps.
Posted on May 30, 2012
AUTOPLAY doesnt come up wen i insert USB device...ALthough i hav already activatd the autoplay fxn on my system.....i use window7 home premium
May 30, 2012 | Acer Computers & Internet
Tip
Disable AutoPlay in Windows Vista Windows Vista's AutoPlay options are a great...
Windows Vista's AutoPlay options are a great improvement over Windows XP in terms of flexibility, but unfortunately there are so many options that it can be confusing, especially since there's no specific mention of USB Flash drives in the options. Open your Control Panel, and then click on "Play CDs or other media automatically" to open the AutoPlay dialog. Disable AutoPlay Globally. The quickest way to disable AutoPlay entirely is to just uncheck the box for "Use AutoPlay for all media and devices", which should usually work.
on Jan 01, 2008 | Microsoft Windows XP Professional Full...
Tip
on Sep 01, 2007 | Microsoft Windows XP Professional Full...
I just got my Coby Mp3, and i plugged the USB into my computer and the autoplay screen that is supposed to come on my computer, hasnt.
Does you computer detect a new device when you plugged the Coby MP3 player?
If Coby MP3 player has cd driver, better to install it to your pc. Some computer/laptop doesn't detect autoplay when new USB device plug-in
May 07, 2011 | Coby MP828 MP3 Player
The memory card is not showing my pictures when i plug my camera into my laptop
Please follow the steps below for connecting the Camera to the Computer for transferring the images.
Turn the Camera ON.
Turn the Computer ON.
Make sure to Insert the Memory Stick in the Camera.
Set the USB CONNECT option in the Setup 2 Menu of the Camera to PTP. [Set the Mode dial of the Camera to Camera, press the Menu button, select SETUP-->SETUP2-->USB CONNECT-->PTP-->OK.]
Connect the Camera to the Computer using the supplied USB cable.
The Computer will automatically install the USB Driver for the Camera.
When the installation completes, an AutoPlay window will appear.
In the AutoPlay window, click the Import Pictures option.
In the Importing Pictures and Videos window, click the Import button.
If the USB connection from the camera is not recognized by the computer, disconnect the USB cable and repeat changing the USB CONNECT option to PictBridge, Mass Storage or Auto.
If the issue persists, try connecting to a different USB port on the Computer.
Try re-installing the USB Driver from the Device Manager.
Good Luck!
KenSolutions
Nov 23, 2010 | Sony Cyber-shot DSC-W50 Digital Camera
My Kingston pendrive DTI/8GB does not auto start itself. How can I fix this given that I need the data inside.
support.microsoft.com/kb/330135
Whats gone wrong and what to do above.
www.softwarepatch.com/windows/xp-autorun.html Software above to download and FIX the problem for you.
www.ehow.com › ... › Computer Drives & Storage
www.ehow.com › ... › PC Support
Above are some explanation links.
Try this below, if your dive isn't recognized... Remove and reinstall all USB controllers To remove and reinstall all USB controllers, follow these steps: Click Start, click Run, type sysdm.cpl in the Open box, and then click OK. Click the Hardware tab. Click the Device Manager button. Expand Universal Serial Bus controllers. Right-click every device under the Universal Serial Bus controllers node, and then click Uninstall to remove them one at a time. Restart the computer, and then reinstall the USB controllers. Plug in the removable USB storage device, and then test to make sure that the issue is resolved.
Apr 05, 2010 | Vantec 1 Bay NexStar 3 USB 2.0 External...
It makes three noises when i plug into comp and wont show up in menu of external hardrives
When it makes noises when you plug it into your computer it means that the computer aknowledged that you plugged it in. Depending on the speed and state of its autoplay feature you may have to wait up to 5 mins for it to load depending on speed of your computer and USB hub. If it then still does not recognize by having a box pop up saying "autoplay" or a box prompting you to do things with the drive then your autoplay feature is no longer working or a file was deleted causing it to crash. Try deleting the driver for this device and then rebooting your computer and plug it in again for the first time to see if all the drivers will load, problem should then be fixed. You need to go to control panel ---->System-------->Device Manager to find the driver for the drive.
Feb 28, 2010 | Western Digital WD Passport 250GB Portable...
My usb device can not autoplay automatically
if you are referring to a USB storage device, check its properlies. When connected to the computer, go to My Computer in Windows, right-click the driver letter assigned to the device, then go to properties. look for the Autoplay tab and adjust the settings as desired.
Oct 17, 2009 | Toshiba Satellite P105-S6177 Notebook
I HAVE A SONY DIGI CAM MODEL DSC W-5. MY PC IS NOW UPGRADED WITH WINDOWS VISTA AND SINCE THEN IT IS NOT POSSIBLE TO DOWNLOAD THE PICTURE TO PC. THE INSTALLATION CD ISSUED WITH CAMERA DOES NOT COMPITABLE...
  1. Turn on the camera.
  2. Insert the recording media containing the pictures into the camera.
  3. Depending on your camera, set the USB Connection or Transfer mode setting in the menu to the Mass Storage , Normal , or PTP .
  4. Use the USB cable supplied with the camera to connect the camera to the computer. IMPORTANT:
    • Connection through a USB hub or other USB device -- such as a printer or keyboard -- is not supported and cannot be guaranteed. Connect the camera directly to a USB port on the computer.
    • If the USB connection from the camera is not recognized by the computer, disconnect the USB cable and repeat steps 4 and 5 using a different USB Connection or Transfer mode setting. If the connection is still not recognized, further troubleshooting is available.
    NOTES:
    • The computer will automatically install the USB driver for the camera.
    • When the camera connection is established, an AutoPlay window will appear.
  5. In the AutoPlay window, click Import pictures .
  6. In the Importing Pictures and Videos window, click the Import button. NOTE: After the pictures have been imported, the Windows Photo Gallery window will appear and display thumbnails of the imported images.
If this doesn't work there is an updated driver available
Here
(from Sony Website)
Mar 19, 2009 | Sony Cameras
Sony Ericsson media manager software
What OS are you running? Does your system use USB 1.1 or USB 2.0? Try powering off your w910, wait a few seconds to make sure it completely cycles off, then connect your phone to your PC. It should turn on in USB (ie. 'Mass Storage') mode. If Windows attempts to Autoplay the device, Cancel the dialog. If Windows attempts to install any drivers for the device (or Vista prompts you to scan the device), Cancel the dialog(s). If you go into 'My Computer', is your phone recognized here (as a USB Mass Storage Device)? If not, the app is not going to recognize it either. Try disconnecting any other USB devices or memory card readers.
Nov 04, 2007 | Sony Ericsson W900i Cellular Phone
14 people viewed this question
Top Dymo Office Equipment & Supplies Experts
Ed Mac
Jax Planet
Jax Planet
Are you a Dymo Office Equipment and Supply Expert? Answer questions, earn points and help others
