Question about Kodak Picture Maker Kiosk Printer
HOW TO REMOVE THE TOUCH SCREEN
WE ARE TRYING TO REPLACE THE OLD TOUCH SCREEN WITH A NEW ONE
The touch screen stops working when I open the lid past an angle of around 70 degrees
If this is a new laptop barely months old please contact the place you bought it. You will have a warranty on it, you will be able to get it replaced under warranty. It would be pointless anyone trying to help you fix it as it may void your warranty
Mar 15, 2015 | Computers & Internet
Rebuilding asus k50
Is the wires the black and grey ones these are located underneath and hook to a Network card. Just remove the back panel and unplug them. Pull them through, one should also be a ground and the other will be the screen plugin on the motherboard. The other will go to the back lamp that is about it. So what is stuck or if it is fixed do not remove it unless it is part of what your going to use for the new screen. And never touch the white strip across the top of the screen of your LCD new screen. Outside edges only. John
Apr 21, 2012 | ASUS A6J Notebook
How do I remove the huawei U7510 glass screen digitiser for replacement?
Its a screen protector which will be sticked on the mobile screen. It will be so thnn, please use an sharp stick which will not damage the screen and using that remove the old screen protector. Then remove the sticker from the new protector and place it on the phone screen and stick .
Thanks
Apr 02, 2012 | Huawei Technologies X5 artphone
I am trying to replace my 1999 S70 radiator. How
done one not so long ago and i had to remove the front bumper and the safety thing behinf the bumper then pump the ac gas out to remove the ac rad then it was easy
Jul 24, 2010 | 1999 Volvo S70
Nikon L11, how to replace the LCD screen?
is very easy. you will need only a cross screw driver. This operation should take no more then 15 - 20 minutes
May 31, 2010 | Nikon Coolpix L11 Digital Camera
How can i replace the touchscreen of a LG KF600
If you are technically minded, yes, you will be able to do this yourself. Otherwise you need a technical person to do it for you.
I assume you are technical. This is what you should do:-
1. You should have the replacement touch screen handy (You should have bought a new touch screen).
2. Remove battery, memory card, sim card etc.
3. Unscrew the screws holding the casing/(housing of the phone) to the panel.
4. Then with object like a knife, position the edge gently between where the lower and upper parts of the casing contact/(close up) and pry open.
5. You will see where you can disconnect the touch screen from the panel. Gently detach from the panel. Connect the new one and reassemble.
Sep 09, 2009 | LG KF600 3MP InteractPad Triband Phone...
Screen problem
hi..... this is the only way with the touch screens
  • If the touch pad is scratch or cracked , you can replace the touch screen(touch pad/Digitizer) only.
  • The touch screen have the protect film on it,please remove the protect film before you use the touch screen .
  • Before you buy this item please check your touch screen model and make sure it's same as the photo.
  • 100% brand new.
Jul 15, 2009 | O2 Xda Atom
Mitac Mio 168 won't go past ALIGN SCREEN
The touch panel on the LCD unit is defective and needa to be replaced with a new Compleet new LCD+TP unit.
If you have a screen gaurd on your Touch panel, try to remove it and check again, if it doean't help ---> new LCD+TP unit
Nov 15, 2007 | Mitac Mio 168 Pocket PC
Kodak Picture Maker Kiosk Printer Logo
29 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
