Question about Miele Coffee Makers & Espresso Machines
Miele coffee wont grind coffee beans - Miele Coffee Makers & Espresso Machines
espressodoc
  • 29 Answers
SOURCE: Coffeee beans won't feed into grinder
Push the coffe brew button again. It should take right off and grind again.
Posted on Jul 27, 2007
SOURCE: Coffee will no longer grind.
ONE COMMON PROBLEM IN THIS MACHINES, SINCE THEY ARE MADE IN CHINA, THE QUALITY OF THE BEARINGS DETERIORATE IN ABOUT EXACTLY ONE YEAR. AND THE GRINDER NO LONGER WORKS. THE BEARING BUSHING ITS MADE OF BRASS, AND THE LOAD OF THE COFFEE BEANS OVER KILL THE BEARING. ITS A RIP-OFF....
Posted on Aug 24, 2007
  • 4 Answers
SOURCE: machine will not grind beans.
That error message will also appear if the coffee grind is too fine.
Posted on Dec 14, 2007
  • 2039 Answers
SOURCE: DeLonghi automatic espresso machine
do you use the machine often oil in coffee create residue and can accumulate on the grinder and the residue is so thick that it does not let coffee trus remove the coffee bean and were the beans go u should see the grinder teet use a little tootbrush or anything that might fit in there remove the residue and try it it should be good thanks for using fixya pierre
Posted on Feb 08, 2008
  • 1089 Answers
SOURCE: the coffee grinder on my Magic Comfort Plus is not
Hi Sounds like you have a blockage in you grind passage. Try removing the brew group. Then inside on the roof of the machine where the brew unit was setting there is a drop chute where the coffee is dropped into the brew unit. From the left side of the drop chute pull down and back, and it will drop coffee. This will clear an opening that relieves pressure on the passage. There is a passage inside the drop chute area that goes to the grinder. Vacuum it out. It will be on the right side of the drop chute. Once that is cleared go to the bean hopper. There is a lever under the bean hopper. Push the lever back to the largest number. You can push the lever to a larger number any time, but it has to be grinding to pull to a smaller number. Now replace everything and make your coffee. Once you have made your coffee you can pull back to a number that was higher than the one you had it on, but only when the grinder is running.
Posted on Jan 25, 2010
How to unclog coffee spouts?
I have a different machine, but it came with a needle like cleaner for those tiny holes in the cup that holds grinds. Also, if I grind the coffee too fine, there isn't enough pressure to push coffee out of both holes. Make a coarser grind to see if that solves the problem.
May 01, 2016 | Miele CVA4066 Built-In Whole Bean Coffee...
The grinder is not working. Only water is coming out.
Basically coffee is not being ground. Likely causes are grinder is faulty or temperature cut-out for Grinder has blown. Either can be replaced as a spare from Miele. Note: A possible cause for Grinder not working is that the carbon brushes are worn away preventing electrical contact. Unfortunately Miele does not sell brushes as a spare part.
May 13, 2014 | Miele CVA4070 Coffee Maker
Stops after grinding beans
cva 2660 doesnt grind beans it uses nespresso capsules.
Jun 03, 2012 | Miele CVA2660 Stainless Steel Coffee Maker
My coffee system is quiter than usual when it is gringing and we pulled out the coffee bean tray which has plenty of beans in it and then put it back in. That is what the operating manual told us to do but...
there is a lever under the beans container that controls the size of the grind. it should always always be center, or to the right of center. if it is too far to the left, the chute will clog up and the grinder teeth will get impacted with coffee flour. nothing to do at that point but set up a service call to replace the grinder. please make sure your servicer is a miele tech. anyone else will not know how to work on this machine.
May 26, 2012 | Miele Coffee System
The grinder runs but does not grind beans
Sounds like a blockage in the bean hopper. With the power off, take away the bean hopper and reach in the hole where the beans go and poke around to see if you can clear it.
Mar 03, 2012 | Miele CVA615 Espresso Machine
I owe the miele CVA4075 BUT my whole bean grinder is not grinding the bean and only water gets dispensed, anyone have a solution?
Make sure the hopper is working correctly to see if there are any blockages, then check under the hopper to the opening where the beans go to the grinder. My guess is that there are a few beans and chipped portions of beans which are clogged under there.
Jun 28, 2011 | Miele Coffee Makers & Espresso Machines
Fault F 17 appears when in use. Starts grinding the beans but no coffee in the cup yet. What does F17 mean?
f 17 is no water flow. It usually occurs when the brew unit has not been cleaned regularly, when the coffee grind size is set too fine, or when oily beans are used. You can try to soak the brew unit in hot water for a while, and run water through it in the sink. Unfortunately, most cases require brew unit replacement. A properly cleaned and maintained brew unit should last the life of the machine.
Jan 26, 2011 | Miele CVA4070 Coffee Maker
I placed ground coffee instead coffee beans in coffee bean container. I used the mixer and mix but do not have a mute.Doesn't work.Can I solve a problem or should I call service . If yes, what I have to...
Bean grinders expect to grind whole beans as you have just found out. The grounds have clogged the entrance of the grinder. Use a wood chop stick to try and loosen up the 'caked' coffee and remove the coffee with a vacuum hose attachment. Try to **** out as much of the coffee as you can. Please note that this should all be done with the machine unplugged. Try grinding again but don't let it 'Hum' too long if it's not grinding. You can also try to adjust the grinder 'coarser' to give more room for the burrs to clear. Good Luck!
Feb 16, 2010 | Miele CVA610
Hi, I have a Miele 4070 that I bought 3 months ago. It made great coffee for the first two months and then the coffee suddenly became weaker, and thinner and has less body. I have not changed beans, and...
,Hi
If you have adjustments for your bean hopper, 1 should have a + and - on it. Move that adjustment to the + but then back it up 1 click. Then go to the grind adjustment and move it down to a smaller #, but only when it is grinding. When you get the grind adjusted you should have grinds that look like coarse granulated sugar.
If you have taken the brew head apart you may have put it together wrong.
Jan 05, 2010 | Miele CVA615 Espresso Machine
Coffee Makers & Espresso Machines Logo
79 people viewed this question
Top Miele Coffee Makers & Espresso Machines Experts
Jerry Greenberg
Jerry Greenberg
Michael Galve
Michael Galve
Colin Stickland
Colin Stickland
Are you a Miele Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
