Question about Maytag Washing Machines
Washer jumps and vibrates when spinning - Maytag Washing Machines
    Prodigy:
    An expert who has answered 500 questions.
  • Maytag Expert
  • 517 Answers
Some things to think about?
1/ does it do it on every spin or some times
2/ is the wash load to heavy or to little
3/ has the internal weights come loose
4/ have you removed the transport bolts if new machine
5/ is the machine on a level area
6/ try to think of what i write and why ????
Posted on Jul 14, 2014
Washer jumps and vibrates and makes extreme noise
Is this a new machine that you purchased and installed yourself? Or is this a machine that has worked properly and is now displaying this problem? If new, it sounds as though you may have not removed the shipping bolts that secure the drum. This would prevent the drum's suspension system from being able to absorb vibration during the spin cycle and cause the vibration to transmit to the machine's outer shell. If the machine is older, then the drum suspension system itself may need repairs.
Sep 16, 2014 | Washing Machines
My washer will fill with water and we have power at the outlet but it will not agitate or spin...Suggestions?
It could be the motor if you do not hear or feel any type of hum or vibration during the time when it should be Agitating or spinning. If you do hear or feel a hum or vibration then it is most likely the belt has either broken or fell off, another posability is the spring attached to the belt tensioner has broken. Most all of these problems are easily fixed but usually require ordering the needed part.
Thumbs Up if this is Helpful!!!
Jun 18, 2011 | Kenmore Washing Machines
The washer vibrates in the wash and spin cycle .
Try checking for the shipping screws, did you remove them? They are there to prevent the drum moving during transport but if left in the whole machine will try to jump about.
Jun 10, 2011 | Amana NAV5800AW Top Load Washer
Jumps around really bad even on the "low spin" cycle Samsung front loading brand new
First check that the "shipping" bolts have been removed...
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front load washers can make..
Washer Problems Washer noise when spinning
heatman101
Apr 18, 2011 | Washing Machines
We just bought a used Frigidaire front loader bought in 2004 and the washer jumps when in even the lowest spin cycle. We have bought a rug for under the washer and it has not helped. Any ideas???
Washer Problems
heatman101
Feb 02, 2011 | Washing Machines
Washing mashine jumps around during the spin cycle
Washer Problems
heatman101
Jan 25, 2011 | Kenmore Washing Machines
On the spin cycle my miele walks acrossed the floor
make sure you loads are balanced, put heaviest clothes in first... if you can rock it by hand then the legs are not adjusted properly. If you stand 2 feet away from front of machine, jump up and down and see it move the floor is soft and you need 2 sheets of plywood to make 1 1/2 inches put under the machine
Aug 06, 2009 | Washing Machines
Washing machine has a seizure during the spin cycle.
Try leveling the washer so that it is about half a bubble biased towards the rear. This usually helps front loading washers balance properly even if the installation instructions say that it should be perfectly level. This can also aid draining problems.
Also, some newer front loading washing machines are simply prone to dramatic vibration even when they is "anti-vibration" or "vibration reduction" systems. You can never go wrong installing an anti-vibration pad under the washer. Good Vibrations Inc, Kellett Enterprises and The Vibration Solution all have good products. The Vibration Solution seems to have figured out the best solution and offers excellent support and return policies.
Washer anti-vibration pads
If all else fails call the retailer and ask for an exchange.
Jun 05, 2009 | Frigidaire ATF6000ES Front Load Washer
Whirlpool washing machine
Welcome hendrik,
You said, jumping around during spin cycle
How old is your GHW9150 washer?
Usually it is overload or load unbalanced due to uneven load.You must stop the machine and re-distribute the load and or weight!
Here are some Whirlpool reasons for you.
But if nothing helps you may have a mechanical problem to be serviced!
Try these ideas first!
Is the load balanced?
A single or bulky item may cause imbalance. Add more items
or redistribute the load.
Washer makes noise or vibrates
Is the washer level?
The washer must be level. The four feet should be properly
installed, and the nuts should be tightened against the
washer cabinet.
As water is drained from the washer, you may hear air being
pulled through the pump. This happens during the end of
draining. It is normal.
Are you washing items with metal snaps, buckles or zippers?
You may hear metal items touching the washer drum. This is
normal.
Is washer installed on a sturdy and solid floor?
Refer to the “Installation Instructions” for flooring
requirements. Noise and vibration may be reduced by placing
a piece of ¾" (19.1 mm) plywood underneath your washer.
The plywood may extend underneath both washer and dryer
to keep them at equal heights.
Let me know If you have any questions and what happens!!!
Huuum
Please remember to leave a rating!
Oct 11, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Vibration
Is the machine level. The feet should be tightened and the nuts should be tightened against the cabinet. Tilt the machine back and check the shock absorbers. One of the shockies could have jumped out of the guides.
Oct 16, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
71 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
