I have the date and time showing correctly, but when it prints it prints a random line of letters and numbers and never the same thing twice. How can I fix it to print the date and time correctly?
Mine is doing the same thing. I read that the 3V battery may need to be changed.... so I changed the 3V and all four AA batteries and hit reset and am still experiencing the same as you. Random **** printing when display seems okay. Never same stuff twice. Very frustrating.
It depends on the type of stamper. There are many kinds of self-inking stampers. The most common one has a slide-out "stamp-pad" tray (it'll just look a thick black line until you remove it). For these, you use your hand to press the stamp just slightly (just barely lift it from the pad) and then push the tray out the side (it doesn't matter which direction, just press against the black line from one side and it'll pop out the other side). Once you have removed it, you can then put refill ink on the portion that has dried out. Wait for it to absorb (if it's very dry repeat the process one or two times) then press the stamper again and slide the tray back in, being careful to make sure you have it going the correct way or you'll reverse the colors. Stamp on a piece of throw-away paper about 10 times to make sure it is working properly and has enough ink.
What prints different? What Display Screen? What are talking about? Buckup full details gets the answer I know about computers I am not into mind reading Assuming you have one that is?
if it is an older model [2001 or so] you just gently put your hand over the top like your going to pick it up but just push down and slightly forward. there is a button on the underside.
