Question about Heavy Duty 133751 Arrow, P22, Plier Type Staple Gun
Arrow P22 Jam
How do you clear a Jam in an Arrow P22 Stapler? The sleeve of staples is stuck and will not come out.
4 Suggested Answers
efs_perpends
  • 1996 Answers
SOURCE: I have a staple stuck in my Arrow model #ETN-50
Unplug it. If you can see the driver jammed against the staple, take a screwdriver end and try to push the driver back in and the staple should be released. If you can't get the driver to go in and release the staple, you'll have to disassemble it to clear the jam, If you need help with that, see the instructions for the current model here, page three, diagram 3, cleaning the magazine.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Posted on Aug 18, 2009
Testimonial: "Thanks for your help! Much appreciated!"
SRF518
  • 232 Answers
SOURCE: how to open arrow p22 staple gun
there is a spring follower in the base with a hook that latches into the body of the stapler. press in then down to unlatch the follower.
Posted on Oct 21, 2009
Testimonial: "yes thanks very much!"
1percentclub
  • 75 Answers
SOURCE: a staple jammed in the moving part (driver?) when
first remove the the spring loaded rod that keeps the staples in place and tight, if you can see any part of the jammed staple , grab it with pliers or vice grips and pull it out any way you can , might be more than one staple jammed too, turn stapler upside down to dump out any loose staples and debris , keep working until she frees up , if you still cant get it out might have to loosen screws up that hold it together, a little light lubricant will be good for it too . then load it back up with staples and put tension rod back in, i always try to keep it full of staples at all times ,like when it gets 2/3 empty , fill it up, this will ensure good tension on the business end of the staples!!
Posted on May 22, 2011
Will the Arrow staples # 405 fit into my Craftsman 68464 staple gun ?
thats the picture of the manual staple gun
and the picture of type of staples you want
on the staple box confirms you can use the staples in that
sears craftsman
note the staple has inches and metric dimensions
all you need to check is the stapler eject system is not worn out
or cause a jam as you try to staple
if sticky .. try some sewing machine oil on the stapler workings
Oct 14, 2016 | Arrow Fastener 405 5/16" Flat crown...
How do I free up a jammed staple in an Arrow P22 model?
Hi Francis. Remove the staples from the Arrow P22. Place a piece of wood (rod) about a quarter of an inch thick between the arms of the stapler just behind where the stapler is ejected and press down a couple of times until the jammed staple is dislodged. If the plunger is already jammed in the downward position then first pull it up and then push it down again. This procedure has worked for me on a variety of staplers over a period of very many years. Good luck!!
Feb 04, 2015 | Arrow Plier-Type Stapler - P22
What staples does a black and decker electric stapler 9700 take and where can I buy them?
Hi Stephen,
Of course the manual states to use their staples for best results.
However it does at least state it is designed for a wide variety.
Most hardware stores have a range of staples to choose from.
Home Depot, Harbor Freight, Lowes etc. Try a chisel point this may help penetrate the wood deep enough. All staples are not made the same. So again trial and error may be the quickest route. Fortunately you can purchase small boxes for your testing.
The manual for this stapler is here:
(Page 2 talks about the staples to use.)
Black Decker 9701 Instruction Manual Page 2
Good luck and hope this helps!
Jan 04, 2015 | Arrow Tools & Hardware - Others
How do you fix a P22 Stapler
You may have to use pliers to remove the bit of broken staple jamming it.
Jun 09, 2014 | Heavy Duty 133751 Arrow, P22, Plier Type...
Someone loaded regular staples into our Swingline 45 Optima now it will not work when loaded with the correct staples.
Using the wrong or style ofstaples, overfilling the machine and stapling through too-thick materials can causeOptima to jam. Now follow these steps: 1. Holdthe base down as you lift the top of the Optima stapler to access the stapletray. 2. Removeall the staples from the tray so that you have access to the jammed staple. 3. Turnthe stapler upside down and shake it to clear out staples you can't reach withyour fingers. 4. Gripthe jammed staple with the needle-nose pliers and, while holding the staplersecurely, pull it up. 5. Twistthe staple until it breaks into two pieces if it will not pull straight out.Pull out the two individual pieces. The Optima stapler line bySwingline is designed to be jam-free when Optima premium jam-free staples areused. Using another , style or brand may cause frequent jamming. Hope thiswill help you. Good Luck.
Jul 21, 2011 | Office Equipment & Supplies
Arrow staple gun will not shoot it seems it is locked into place
You likely have i staple jamed in it see if you can get something that fits into the end where the staples come out and pull the bent staples out this is common even on bigger models
Nov 23, 2010 | Arrow T50P ARROW STAPLE GUN
How do I load JT21 staples into a Arrow JT27 Stapler gun?
I was having the problems everyone listed... with the staples loading & firing... I guess the instructions are lousy .. should be ON THE PACKAGE to make it clear.. but.. on the stapler itself on the bottom.. it explains how to correctly load.. you don't put the staples on the piece that slides out.. you slide it out, load the staples in the open tunnel ..then slide the piece back.. that piece is the spring loader... since i finally figured it out ( by coincidence that I turned it over & noticed some faint words printed) - it works PERFECT every time! great little stapler... please fix your directions... seems to be a common misunderstanding!!!
Nov 07, 2010 | Arrow T50P ARROW STAPLE GUN
Staples are stuck inside the stapler and will not come out
Typically you do not open these up.
Makes it difficult to remove stuck or wrong staples.
I have had good luck removing the staple ram rod and rapping firmly on the **** of the stapler against a wooden table. The idea is jolting the stuck staples into reverse out the way they went in. Tedious process but usually works. Removing the jammed staples in the nose at the striker plate requires using needle nose pliers and a sharp awl or small screw driver used on very small screws.
My T50 Arrow stapler is over 20 years old.
Still works great. Sometimes I slide in the wrong size staples by mistake. The process above usually works.
May 26, 2010 | Arrow T50P ARROW STAPLE GUN
How to open arrow p22 staple gun
Oct 21, 2009 | Heavy Duty 133751 Arrow, P22, Plier Type...
Stapler works intermittantly
If not the power source or cord, the next activation point would be the trigger. Does the stapler make any sort of noise when the trigger is depressed? What type and model stapler is it?
Nov 02, 2008 | Arrow No.ETF50PBN Extra Heavy Duty...
Heavy Duty 133751 Arrow, P22,  Plier Type Staple Gun Logo
Top Heavy Duty Tools & Hardware - Others Experts
yoopertech
Paul Carew
Joseph Hoffmann
Are you a Heavy Duty Tool and Hardware - Other Expert? Answer questions, earn points and help others
