Question about Toto Aquia II Dual Flush Toilet
I have recently installed a uberhaus dual flush toilet from Rona. It has been working well for a couple of monrhs but now does not fill immediately after flushing. It will wuddenly fill, however, when
) My IUberhaus dual flush toilet will not refill after flush. If I take topmoff and touch white sceew on top it flushes immediately. How to fix this? Thankyou
  • 14 Answers
SOURCE: Toto Toilet - no water flow to refill tank after flush
Remove the tank lid and look at the fill valve. Is it a yellow valve?
This fill valve is common on the Toto Toilets and can easliy plug with debrie.
They can be disassmbled and cleaned. however, I usually just replace the valve with Fluid Master Fill valve.
You will also want to check the water coming into the toilet by turning off the water that supplies the toilet and disconnecting the water supply line. After removing the water supply line turn on the water at the valve to make sure that the water is flowing properly. Check the supply line also to make sure it is not plugged.
Be sure and place a small container to catch the water that will come from the valve. A towell will also help from making too much of a mess.
If the Supply line and the valve are clear the problem is in the fill valve.
The G-Max system denotes the Flushiing system which is a 3" flapper that allows the water from the tank to flow into the bowl quicker.
Good Toilets!
sanray
Posted on Jan 10, 2009
SOURCE: toilet tank will not refill with water after flushing
I fixed the problem. There was a clog in the pipes so i just flushe dthe pipes out.
thanks,
for your help
Posted on Jan 18, 2009
  • 659 Answers
SOURCE: Toilet will not flush
You need to replace the fill valve with a oem replacment valve. You need to use toto parts.
Posted on Mar 21, 2009
  • 17 Answers
SOURCE: toilet bowl gurgles after flushing cycle
Sounds like your toilet is not vented properly. Possilbly something caught in the trap is causing it to syphon
Posted on Jan 23, 2010
SOURCE: toto toilet
my toto toilet seems to pulse when filling. Once full it i fine.
Posted on May 28, 2010
I need a dual flush button for my uberhaus toilet, not round but oval
Fixya does not sell Uberhaus flush buttons.
Sep 05, 2017 | Home
Does Uberhaus dual flush one piece toilet come in 17 comfort height
I believe it does due to ADA. If not in stock, they can order it for you.
Feb 06, 2015 | Home
Uberhaus canada
Usual issue is a worn or misaligned flapper. Could also be worn parts in the fill valve.
Jul 17, 2014 | Home
I have a uberhaus dual flush toilet. I turned off the water supply in the house to work on a sink and when I turned it back on the toilet won't fill anymore. If I fill the tank or the bowl it will flush...
You will have to disassemble the fill valve and clean it. When you shut the water off and on to work on the sink it dislodged dirt and scale in the water piping which clogged the toilet fill valve. Check your lavatory sink areators too they may also be partially plugged. Hope this helps.
Bob
Jun 09, 2014 | Home
Why my uberhaus dual flush toilet does not flush properly
Perhaps it is taking a long time to fill the cistern, take top off and see if it's filling after flushing, if it's slow and pressure is ok it is likely to need a new diaphragm in the filling valve.
May 12, 2014 | Home
Uberhaus dual flush toilet power-assisted
buy a simpler toilet less problems and you will sleep at night
Jul 18, 2013 | Home
Uberhaus dual flush toilet keeps running
The flapper may not be seating properly after a flush. Even though you say the toilets are brand new, something may be askew in the flushing assembly or may have been affected during installation
May 27, 2013 | Home
VitrA dual flush toilet doesn't flush enough water
maybe by shortening the chain length on the flapper valve might help
Jul 24, 2010 | VitrA Aria Toilet with Elongated Bowl/...
Toto Aquia II Dual Flush Toilet Logo
56 people viewed this question
Top Toto Home Experts
john h
Robert McCall
Robert McCall
Mike
Are you a Toto Home Expert? Answer questions, earn points and help others
