Question about Neff 24 in. S5543X2 Built-in Dishwasher
Dishwasher stuck in program and shows 1 minute left but doesn't stop and still has water in it
3 Suggested Answers
Joe_Rex
  • 114 Answers
SOURCE: Program stuck at 1, machine keeps running indefinitely
SOUNDS LIKE THE TIMER CONTROL MAY BE BAD. IT COULD BE THE ELECTRICS OF THE TIMER OR GEARING THAT ARE BAD. PERSONALLY I DO NOT !!! RECOMEND TRYING TO TAKE APART AND REPAIRING ELECTRICAL TIMER COMPONENTS. (CLEANING CONTACTS I HAVE DONE TO GET A/C EQUIPMENT TO RUN FOR THE ELDERLY OR HEART PATEINTS UNTIL A NEW PART IS AVAILABLE... SHIPPED OVER-NIGHT) ALL CONTACTS !!! ARE DESIGNED TO AN EXACT THICKNESS AND TOLERANCE TO ACCOMIDATE THE AMPRESS LOAD/DRAW. A BAD CONTACT THAT IS CLEANED IS TEMPORARY AND IF TOO MUCH SURFACE IS REMOVED CAUSES HI-AMPREES AND EXCESIVE HEAT ... IT CAN BURNOUT THE MOTOR THAT IT IS CONTROLING DUE TO INSUFFICIENT VOLTAGE WHICH CAUSES HIGH AMPREES WHEN THE MOTOR RUNS. IF YOU DO DECIDE TO TRY IT ON YOUR OWN? MAKE SURE YOU NUMBER OR "COLOR CODE MARK" ALL WIRES AND CONECTIONS BEFORE YOU REMOVE ANY WIRES ... GOING TO YOUR LOCAL "APPLIANCE PARTS STORE" WITH TIMER PART IN HAND IS WHAT I RECOMEND ... MOST COUNTER SALESMEN WILL TEST THE PART FOR YOU. GOOD LUCK ...
Posted on May 03, 2007
  • 3247 Answers
SOURCE: our Neff S5454x1/21 dishwasher has occasionally stopped/stuck
Looks like the heater unit has packed up.
I cannot seem to find the actual model you have anywhere on the internet. But I am assuming you connect the dishwasher to cold water inlet and it is meant to have a heater.
Are you in UK or Europe. Bosch also makes parts for the NEFF dishwasher but I am not able to find spare parts for your exact model.
Please post a comment.
Posted on Jun 05, 2010
The dishwasher doesn't finish the 30 min program. The display shows 1 minute remaining but the washer doesn't stop.
It sounds like the d/w has a heating issues. Possible internal failure of the heating relay.
Jun 20, 2016 | Dishwashers
My dishwasher has stopped mid cycle showing 1 minute left , when stopped and started again it now shows 28 minutes contantly, plus it continues to run (ie pump running) after the door is open. Any ideas...
HI,
Does the water drain out.If the water doesn't drain out ,it could be a clogged in the drain line. Often the problem is at the point where the drain line attaches to the garbage disposer or household drain line. You should remove this line and clear it form any debris in the hose or the hose connection. Be sure to reattach the hose before starting the dishwasher again.
Please don't forget to rate the solution.
Apr 06, 2008 | Dishwashers
My dish washer wont fill with water
there is a float, usually at front left side inside dishwasher, that may be stuck..possibly an utility holding it up, or the fill valve is stuck. When dishwasher calls for water, it fills until this float rises to proper level and shuts the valve off at proper level. If it sticks, water will shut off at improper level.
May 01, 2014 | Zanussi FS1255S Front Load Washer
Zanussi dishwasher ZSF6161 starts program then stops after 15 minutes
check this steps and fix it. God bless youFloat Switch
The float switch may be hung up and this can cause the dishwasher to be stuck in a cycle.
Timer / Control
If your dishwasher gets stuck in a cycle first try shutting off the breaker for at least 5 minutes if this does not correct the problem you will need to replace the timer /electronic control.
Apr 02, 2013 | Zanussi Dishwashers
DISHWASHER
see this causes and fix . God bless you
Float Switch
The float switch may be hung up and this can cause the dishwasher to be stuck in a cycle. Check the tutorial and the video for checking this part.
Timer / Control
If your dishwasher gets stuck in a cycle first try shutting off the breaker for at least 5 minutes if this does not correct the problem you will need to replace the timer / electronic control.
see the temperature sensor.for E4
God bless you
Oct 02, 2012 | Haier Dishwashers
LG dishwasher error code after 2 minutes
fault with the programe as it has stoped in mid cycle
Aug 01, 2012 | Whirlpool Dishwashers
When I press the start button, Bosch dishwasher (model SHY56A 05UC) just keep running the motor pumping the water out of dishwasher, irrespective of: 1) the wash cycle it is on, 2) whether the door is...
what is happenig i believe and has happened to me 2 times is that the water level float that is on the left side of dishwasher is stuck.
Either remove side panel and flick lever or pull dishwasher out and tap lower portion of panel and this will cause the level to move and then see hat happens
Nov 26, 2010 | Bosch SHY56A02 / SHY56A06 Built-in...
Bosch Dishwasher stuck at 1
I am currently experiencing a very similar problem. However, I have taken the dishwasher out of the kitchen and plumbed and power it up outside. After tipping the water out of the reservoir on the side, it will start a cycle, it will circulate water. But sticks at 1 minute, trying to pump out water and I'm assuming being told by a sensor that there's water still in the machine. Also I note a small amount of water escaping via the plastic base and water pooling in the base.
Doing the code test shows C2 P0 E1 and then 2 depending on the buttons pressed.
My next task is to get it on a workbench on it's side and take the base off. I'm going to try to trace the source of the water in the base and go from there...
Did you get a resolution?
Did you get a resolution to your probl
Jul 17, 2010 | Bosch 24 in. SGV57T03GB Built-In...
Our Neff S5454x1/21 dishwasher has occasionally stopped/stuck
Jun 05, 2010 | Neff 24 in. S5453X1 Built-in Dishwasher
The dishwasher has been running for 3 hours and seems to be stuck on 1 minute left. Upon opening, there was sudsy water remaining in the bottom, but the dishes looked clean. The washer just won't go to...
SHU 53 MODELS To start test program, press and hold both SCRUB WASH and DELICATE/ECONO program buttons, then turn unit on by pressing ON/OFF button. Initially, control module version # will be displayed (e.g./ ?21? = version 1 with jumper). When wash program buttons are released, lights above them will flash. To end test program, press ON/OFF button. To check each program indicator light, press its button. To check Cycle Countdown display, Refill Rinse Agent light and REGULAR WASH light, press REGULAR WASH button (press Delay Start button to test Cycle Countdown display alone). Cycle Countdown display will show ?88″ when REGULAR WASH button is pressed and ?8h? when Delay Start button is pressed. To start testing, press both the SCRUB WASH and DELICATE/ECONO buttons a second time. When testing has ended, Cycle Countdown display will show a fault using codes below. If more than one fault occurs, code numbers will be added together, (e.g./ ?6? = faults 2 + 4). 0 = No faults detected 2 = Heating fault 8 = NTC (temperature sensor) fault 1 = Aqua Sensor (?Sensotronic?) fault 4 = Filling fault F = Filling fault (display occurs during wash, not test) To check for heater, high limit or flow switch problems, start testing until heating starts. Using a meter with a current coil, measure current going into dishwasher. If current is ~ 11 A, then heater, high limit and flow switch are OK. If current stays at ~ 1.5-2 A, then heater, high limit or flow switch are faulty. If water level switch (f1) has failed (opened), display will show fault code ?4″ and unit will continually fill and drain where testing won?t be completed. If flow switch (e5) has failed (opened), display will show ?0″, water won?t heat (to 150?F) and water won?t stop circulating. If NTC probe (f2/f4) has failed (opened), display will show fault code ?8″ immediately and testing will end shortly after water has started circulating.
Aug 01, 2009 | Bosch SHU5315UC Dishwasher
Neff 24 in. S5543X2 Built-in Dishwasher Logo
77 people viewed this question
Top Neff Dishwashers Experts
Cesar Quant
Cesar Quant
Michael Galve
Michael Galve
Are you a Neff Dishwasher Expert? Answer questions, earn points and help others
