2001 jimmy code 0449
Changed purge valves and still code pending
  • 14 Answers
SOURCE: I have a purge valve or VMV fault code 1443 EVAP vaccuum system error
Without more information or testing its impossible to help diagnose this problem. However, when is the last time the oxygen sensor been replaced. My best guess in this situation and remember that this is not a easy item to replace as it is located within the exhaust system and is usually corroded.
Posted on Apr 30, 2009
SOURCE: How do you change a purge valve on a 2001
look right above the altternator it has 2 vacum line and a electric switch
Posted on May 08, 2010
timsauto123
  • 750 Answers
SOURCE: 2001 OLds silouette P0440
could be a vacuum leak,check all hoses and intake,better if you have a shop use a smoker.
TIM..............
Posted on Oct 23, 2010
ryanplex
  • 57 Answers
SOURCE: 2003 Mitsubishi Eclipse has a
There is a purge valve and solenoid on most cars I believe. The purge valve is usally located by the engine and the selenoid is usally located by the fuel tank. Call up or go visit your dealer and you will be able to order the parts from them and they can tell you the exact location.
Posted on Aug 09, 2011
ginko
  • 19396 Answers
SOURCE: have a code
Hi.
P0449 means: evaporative emission (evap) canister vent solenoid valve, incorrect voltage at driver.
Check the evap. ventilation valve, wiring and and solenoid. The evaporative system is located under the vehicle near to the fuel tank.
Regards.
Ginko
Posted on Aug 11, 2011
P0068 P0306 P0449 Why are all on at same time 2007 GMC Yukon
code p 0306 is --misfire on no 6 cylinder ===causes injector wiring ---ht leads , coil
code p 0449 is EVAP purge valve --circuit malfunction ===causes --wiring--EVAP canister purge valve --ECM and code p 0068 is MAP ( manifold pressure )sensor ( mass air flow sensor (MAF)---throttle position correlation===causes --wiring--MAP/MAF sensor--mechanical fault
could be a common wiring harness plug connection or loose connections on the ECM
Aug 10, 2017 | GMC Cars & Trucks
Is there a fuse for the vent solenoid? getting P0449 code but vent is good.
code p 0449 refers to evaporative emission (EVAP)system, vent valve ---circuit malfunction===causes --wiring ---EVAP cannister purge valve ---ECM
check the wiring for breaks , bad connections
replace the purge valve
the vent valve is part of the purge system of the EVAP system( fuel system)
Oct 08, 2016 | 2005 Chevrolet Equinox
2001 hundai Accent code p0444
A purge control valve circuit open.
Jun 27, 2016 | Cars & Trucks
What is code pd1441
The pd means the code is pending, (or intermittent, stored code). Here is what the code means----this DTC indicates that an evap system purge flow was seen by the vehicles PCM ( computer ) during a non purge condition.
Simply put the EVAP purge valve was open when it should not have been. Likely a mechanical failure of the purge valve.
This repair should not be too expensive .
Oct 19, 2012 | 2003 Oldsmobile Alero
I have a 2001 Chevy Blazer with 4.3 liter have to keep putting gas in throttle body for it to start.What might be the problem?
if your car starts after putting gas in throttle, means that you have no sufficient fuel feeding and one cause is the injection system not providing the need fuel, pressure regulator the second cause,or the fuel filter is blogged.
Oct 16, 2012 | 2001 Chevrolet Blazer
Where is the pressure purge valve located
The canister purge solenoid is bolted to the intake manifold. The canister vent solenoid valve is attached to a bracket under the vehicle near the spare tire.
Mar 28, 2012 | 2001 GMC Jimmy
2001 Jimmy purge control circuit
its the valve that allows air into the fuel tank and takes away the fuel vapour
Feb 11, 2012 | 2001 GMC Jimmy
Have a code 0449 2001 blazer
Hi.
Regards.
Ginko
Aug 11, 2011 | 2001 Chevrolet Blazer
Check engine light on steady, and codes 0445 & 0449 from computer
The codes you list are generic and unfortunately the descriptions provided are too. Do a bit of research into the applicalbe parts and you'll likely find a trend of malfunctions and repairs for your particular model year. After that it's time to either get greasy or see the mechanic, doesn't sound like it will be too bad, though.
http://www.obd-codes.com/trouble_codes/
P0445 Evaporative Emission Control System Purge Control Valve Circuit Shorted
P0449 Evaporative Emission Control System Vent Valve/Solenoid Circuit Malfunction
Hope it helps,
Jun 08, 2011 | Pontiac Montana SV6 Cars & Trucks
11 people viewed this question
jasbo
jasbo
