Question about GE ZDBC240NBS Beverage Cooler
It is not cooling. Fan works. Does not click on when the dial is turned.
5 Suggested Answers
SOURCE: ge model gsh25jfrfww not cooling just clicking
Replace the main board on the back i got the part for $130 at a wholesale parts store
Posted on Mar 06, 2009
Sea Breeze
  • 4654 Answers
SOURCE: freezer and refrigerator not cold fan working but
I'm ready to help you when you are. Zero may just be off on that model but if fans run then the compressor is also getting power and overheating. The start relay and components that keep the compressor going are what important now. Don't leave plugged in or the internal overload may damage. I will wait for a reply, Sea Breeze
Posted on Dec 18, 2009
marka19
  • 1430 Answers
SOURCE: GE bottom freezer began making a clicking noise, will not run
The clicking could be the start relay.If the start relay is bad, the compressor will not start and you will hear a clicking noise in 2-5 minute intervals. The clicking noise is the overload cutting the compressor off when it overheats from trying to start with a bad start relay. To find out if this is bad first unplug the refrigerator. Remove the lower cover from your refrigerator. Then take the cover off that is on the side of the compressor,you will see wires going to this. Now you should be able to see the start relay plugged on to the side of the compressor and unplug it. Now the best way to tell if it’s bad is to shake it. If it rattles, it’s bad and needs to be replaced. If not, most of the time it’s ok. But rather than saying the compressors bad, you might want to replace it anyways because it don’t cost much in most cases (less than $25). If you replace it and it doesn’t work then the compressor is bad and you’ll need you call a repairman. (Note that compressors are very costly and are normally not worth fixing). You can also enter your model # at www.appliancehelponline.com for diagrams and illustrations.
Posted on Apr 09, 2010
  • 45233 Answers
SOURCE: monogram beverage center model # ZDBC240NBS. Where can I get a wiring diagram and service manual?
perhaps the manufacturer but most will not give their service manuals out to the general public .
Posted on Feb 15, 2016
Monogram beverage cooler, model zdbc240nbs. Where can I get a replacement control board?
Try a local appliance parts supplier, particularly one that handles GE.
Feb 16, 2016 | GE Refrigerators
Why isn't it cooling? GE Monogram Beverage Cooler ZDBC240NBS
Sara you question does not tell us a MAKE , or model perhaps you need to search the manufacturer's website for support .
Feb 15, 2016 | Refrigerators
Monogram beverage center model # ZDBC240NBS. Where can I get a wiring diagram and service manual?
Feb 15, 2016 | GE Refrigerators
Ge monogram beverage center has ice build up and not cooling
Anytime there is ice buildup it will not cool. Was the door left open? If so that would cause ice buildup. If it wasn't left open and it is a frost free model you have a problem with the defrost circuit. Unplug it and Manually defrost it with items removed by using a hairdryer and towels to absorb water from defrosting Afterwards it will cool again .If the defrost circuit needs service the unit will continue to frost up. Usually in frost free models there is a heater that goes bad.
Aug 01, 2014 | GE ZDBC240NBS Beverage Cooler
Edge star not cooling and clicking sound
the clicking sound may be the condenser fan. if the compressor is running, check to see if there is dust or ice blocking the air flow on the condensor or if the fan is moving slow. this will prevent cooling. remove any obstructions and replace the fan if necessary
Nov 24, 2013 | EdgeStar BWC90SSLT - 84 Can Supreme Cold...
My GE zdbc240nbs recently stopped cooling and the compressor felt very hot, so I replaced the compressor start relay, overload relay and capacitor. It is still not cooling but compressor runs. Any thoughts
The first thing to check is if you have the proper amount of refrigerant in the system, which requires special tools, at the very least a gauge set. You need to know the level of refrigerant is correct before replacing any more parts.
Aug 02, 2013 | GE ZDBC240NBS Beverage Cooler
New house, cooler bought 2006. doesn't seem to run, but light is on
If the compressor is not running you will need to replace the "start relay" and the "run capacitor" on the compressor.
Here is the start relay to order.
Here is the capacitor to order.
Here is a diagram to show you the part locations.
The start relay is number 89 on the diagram and the capacitor is number 96.
The parts come with a 365 day, any part, any reason return policy.
Nov 09, 2012 | GE ZDBC240NBS Beverage Cooler
Will not cool. Fan runs, have cleaned coil.
The compressor may not be starting. Put your forehead against the nmachine when youturn it on or plug it in, You will feel the vibration of the pump. If it is not coming on, you may need a technician to what determine why it is not working.
Nov 17, 2009 | Beverage-Air MT27 Beverage Cooler...
Fan in cooling compartment
The fan inside the unit should run all the time, this insures a more constant temp throughout the compartment by keeping the air moving.
May 28, 2008 | Carrier Beverage-Air UR30GEFD Beverage...
GE ZDBC240NBS Beverage Cooler Logo
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
