Question about Kodak Hero 3.1 All-in-One Printer
Tested and no cyan printed
Did a printer head clean and a test and no cyan printed
SOURCE: Printer will not use cyan
Well I just bought a brand new Kodak 8500 and purchased a few boxes of the 25 1400 print kits after getting it I thought it would be as easy as the Kodak Easyshare 4x6 printers BUT thought different after trying my first box of 25. I got 10 good prints out of 25 due to paper jams after 2 passes. I did the alcohol thing on the LED and sensor and that worked good for 1 full box of 25.
I then loaded a box of 50 8500 ribbon and paper same problem more paper jams after 2 passes wasting more $$$.
I did the whole routine as stated above and after taking the whole darn thing apart I did 1 more mod. I turned the potentiomter 1/2 of a turn but then drilled a small 1/2 hole in the forward plate where that pot is and reamed it out to over 3/4 on and inch thus if you need to make further adjustments you do not have to take the whole thing apart again, just the lower front cover. Because when the front cover is removed with the 5 screws and not 4 the whole darn circuit board falls out and its hard to get the plastic protective strips covering the top and bottom to align back up to slide it back in place. SO with the hole drilled there you do not have to bother with that ever again. After doing the les than 1/4 of a turn I still had a problem and yes I did put it all back together,
BUT at this point I removed the lower front cover and had access
to the pot again and moved it another 1/4 of an inch clockwise installed the 2 screws tried again and I ran a whole box of 50 without a problem.
I don't know if I'll have anymore problems but If I do I'll post it.
Posted on Jun 09, 2008
  • 158 Answers
SOURCE: My black is really faded,
The PHOTO mode is for printing grayscale photographs. Printed letters using PHOTO mode may appear faint because PHOTO mode is optimized for halftones. See if there is a TEXT or LETTER print mode, and try printing on that setting. If printed letters are still faint, you may have to go into ADVANCED PRINTER PREFERENCES, and see if the TONER SAVE mode is on. If it is, turn TONER SAVE off. Also, try changing the DPI image density, or try other adjustments in the ADVANCED PRINTER PREFERENCES MODE.
Posted on Aug 21, 2008
This sort of thing is usually due to dust/dirt on the sensor that detects the gaps in the dye-sub film. Half of the sensor pair is in cover that flips up to replace the ribbon, the other half is under the plastic bar. I clean them with a dry Q-tip or blow them off with canned air.
Posted on Dec 22, 2008
SOURCE: How do I clean the print head for a kodak printer
This is for Kodak AiO printer that has home center software installed
1.On your computer, start the KODAK AiO Home Center software.
2.Click the Help (?) icon located at the upper-right corner of the Home Center window
3.From the Help toolbar, select Maintenance.
4.Click Printhead Cleaning, and wait for the printer to complete the cleaning.
If there is NO Kodak AiO home Center software installed
1. 5100 printer HOME CENTER should be use or open the printer access door wait for the printhead to move at the middle then close the printer access door forcing the printehead to eject ink on the printhead nozzle
2.5300 & 5500 printer press the MENU button > select CLEAN PRINTHEAD > then select BASIC/DEEP CLEAN
3. ESP3 printer [press and hold at the same time COPY and CANCEL button for atleast 10 sec or until the printer start moving]
Posted on Nov 21, 2009
  • 295 Answers
SOURCE: kodak esp 5 not printing properly and no yellow
Call Kodak @1800 421 6699 and get a new printhead free of cost.....Printhead has gone bad and it is the part in which we install the ink cartridges.It takes the ink out of the cartridges and spit the ink on the papers,...Cheers and Enjoy.
Posted on Jan 01, 2010
Why is my Canon Pixma 4820 suddenly leaving lighter lines through color pictures.
Worn print head. And for what they charge for a stinking print head you can get a new printer for less with a warranty to boot!
Mar 24, 2017 | Office Equipment & Supplies
My HP Officejet Pro K550 is not printing the cyan (blue) ink. It has a new cartridge. I've run print quality pages and configuration pages -- no cyan shows up. I cleaned the printheads and no c
Do a test print...
assuming you have done multiple print head cleans... if it fails to print ANY cyan, I'd guess the print head is dead... although to be honest im not an expert with this hp printer. if that is the case, it probably isnt worth repairing.
If it does print some cyan, just missing, you may be able to find info, sorry, I cant help you there, on accessing the service or maintenance mode and doing a higher level clean, if your printer supports that.
As a last option, disassembly and soaking the bottom of the print head in cleaning solution /water... overnight, without getting ANY water on any contacts, then re running print cleans.
good luck
in my exp, again, not with this printer, mind you, if a print head fails to print ANY ink for a given colour, the print head is usually faulty.
Hope this info helps
May 15, 2012 | HP OfficeJet Pro k550 Printer
I had fully-refilled the ink into the CISS tank of my printer (CANON IP1980) however, the only colors that went out were magenta and yellow only. no black or cyan. the ink from the CISS tank did flow into...
You could try a head cleaning or a deep cleaning. You can find them in your printer properties under maintenance. After a few cleanings, try a test page. Keep cleaning and trying a test page until it prints like it should. If it never prints black and/or cyan, the print head is either seriously plugged or damaged.
Aug 23, 2011 | Office Equipment & Supplies
Suspected clogged blue ink tube
most of the time, the print head need to be replaced for your case... but there are cases whereby it's the ink cart that causes the ink clogged.. you can try replacing the cyan ink and do another round of cleaning.. but chances are slim...
May 24, 2010 | Brother DCP-120C All-In-One InkJet Printer
Not printing cyan tryed new cartridge
The print head is clogged.Try unclogging with cleaning tests in maintenance mode.If not help you can try unclogging manually.Warning!!!This can lead to damage of print head.Try it in last case.Open the cover and first remove the ink cartridges.Then open the holder and remove the print head.Run hot tap water and put the print head with the nozzles up to stream water.Hold that 5 mins then turn the print head around with the nozzles down.Hold that for every color of 5 mins.Then put the print head in hot water with the nozzles down.Left
it water about 15 mins and then you must very nice to dry.When the print head dry put it in printer and start cleaning.If this not help you need to replace the print head.Call Canon for support.
Nov 10, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Clot Cyan head gave me a patch in self test i have
Check out this link to an HP-supported way of cleaning the print heads for that DJ.
Oct 20, 2009 | HP DesignJet 1050c plus InkJet Printer
After cyan ran out, installed new cartrige. Printer produced everything colored blue as red. Purchased new cyan cartrige and the problem recurred.
The problem seems from your new cyan cartridge.
It doesnt print cyan ink.
Try to clean print head and test print for each color
from the utility menu
Sep 09, 2009 | Epson Stylus CX6000 All-In-One InkJet...
HP all-in-one not printing cyan color
Place a soft clean tissue paper over the cartridge print head and leave for about eight minutes. You can secure it with the aid of a rubber band. It should be held firm ok. If the tissue paper is not dampened by ink then the cartridge would have gone bad or the ink dried. You also know that they have expiry date and could go bad while yet in the packaging b/c it has expired. Good luck
Jun 02, 2009 | HP Officejet Pro L7680 All-In-One Printer
Cyan Ink cartridge Not printing correctly
After all these tests, then it's defective.
Swap out the cartridge before it damages the printer permanently,
Regards
Ric.
Apr 17, 2009 | Canon PIXMA MP510 All-In-One InkJet...
IP4300 only recognizes magenta OR cyan
1. Get compressed air
2. Run Printhead under HOT water, do not worry about contacts getting slightly wet.
3. Blow compressed air with straw attachment into screens where the cartridge nozzle sits on printhead. then let it sit and dry.
4. reinstall print test page
5. if this fails open paint/photoshop and print a page of the color that is not printing correctly. rinse and repeat until colors flow freely.
I have several ip4300s and I have yet to give up the ghost on a printer with a clog ujsing this method.
Jan 04, 2009 | Canon PIXMA iP4300 InkJet Photo Printer
Kodak Hero 3.1 All-in-One Printer Logo
21 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
