Question about Pioneer Cdx-fm35 6 Cd Disc Changer With Controller And All Wires - Good Working
How does it turn on for CDs to work - Pioneer Cdx-fm35 6 Cd Disc Changer With Controller And All Wires - Good Working
JVC CA-D661T compact home stereo stopped playing burned CDs (it used to play these same CDs, now it doesn't recognize them). Everything else works, including playing of original CDs. Any ideas?
You can try cleaning the laser lens. You can do this using qtips and rubbing alcohol. Be sure you are very gentle though or you could risk scratching the lens which would completely ruin the laser assembly.
Mar 21, 2012 | Car Audio & Video
My sharp cd-ba200 will barley play cds
Put the player On for few hours or overnight. Now remove the panel and get access to the optical head unit, use a clean ear bud to polish the optical head. If not the optical head is weak and must be replaced.
Mar 14, 2012 | Sharp CD-BA200 CD Shelf System
Jammed cds in my RX 330
I also have a 2005 Lexus RX 330. Hold down the eject button with the car on. When you completly turn off the car the cd's should eject. You may have to do this a few times before it works. I also had this same problem with my 2003 Honda Accord. I clean the cd player regularly but I have found that it does not always eliminate the cd errors. I purchased a cassette adapter for my I pod for $12.99 and have been happy and error free ever since! Good Luck
Jul 15, 2010 | 2005 Lexus RX330
Toyota camry eating my cds!
The cd player possibly takes in 6 cds.
May 24, 2009 | 2004 Toyota Camry
A disc is in the Bose Wave system and will not play or eject
Unplug the system. Turn the entire unit upside down. The CDs will eject. After I tried this (found it online somewhere), it worked fine for about 2 months. Now it suddenly turns on by itself and ejects CDs (creepy). But at least the original problem was solved.
Apr 05, 2009 | Bose Wave Music System CD Shelf System
Blank cds don't work
Are you using cds labeled music? These are formatted for cd audio home recorders. Data cds for computers will not work. If in doubt, usually on the packaging it states for home audio.
Oct 27, 2008 | Harman Kardon CDR2 2-Disc CD Recorder
News is perpetually-how to turn that off woithout turning off ALL sound
I'm assuming that this "news type show" is a video or radio. Look for its volume control usually has a symbol like:volume%2bicon.jpeg and it has a slider to its left. Just slide it over the left side to turn the volume off.
Let me know if this helps. Appreciate if you rate it.
Thanks,
ArnWuLF
Oct 10, 2008 | Dell Inspiron B130 Notebook
Having trouble strating car, no power
if its turning over but no spark it is more than likely the electronic capacitor discharge system cds unit which depending on year model cannot be repaired and replacement are expensive and hard to find if the wiring on the distributor touches anything metal with ignition on its shorts out the cds unit they are easy to replace only one wiring plug finding one at less than 400.00 second hand is another thing if buying a second hand cds unit insure that it is working before handing over any money
Jul 17, 2008 | Porsche 911 Cars & Trucks
Pioneer Cdx-fm35 6 Cd Disc Changer With Controller And All Wires - Good Working Logo
Top Pioneer Car Audio & Video Experts
Michael Kovalik III
Michael Kovalik III
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
