Question about Sharp Office Equipment & Supplies
Error code L6 on Sharp AR 151 copier - Sharp Office Equipment & Supplies
  • 33 Answers
SOURCE: sharp AR-5316, showing L6 on display
The L6 code means trouble with the laser unit ( polygon motor), it has to be replaced. The laser unit is under the exit tray. Hope this helps.
Posted on Jan 02, 2008
SOURCE: Sharp AR-162 Laser Unit
searching for solve problem L6 error in the machine sharp m 160
Posted on Mar 19, 2009
  • 990 Answers
SOURCE: Sharp AR-M205 - Error Code L6
Hello sir; "L6" display it means laser motor defect need to replace.
Posted on Aug 19, 2009
xptareq2000
  • 1447 Answers
SOURCE: Sharp AR-M208N copier with error code U2-40. What
reset u2
press c -interrupt-#-interrupt
press 16
press start
machine off
again machine on
remove this signal.
Posted on Jan 20, 2010
randula7
  • 78 Answers
SOURCE: What does error code L6-10 mean on a Sharp AR-235
L6-10 Content Polygon motor lock detection
Detail
It is judged that the polygon motor lock signal
is not outputted.
Lock signal is checked in the interval of
10sec after starting the polygon motor, and it
is judged that the polygon motor does not
rotate normally.
Cause
The LSU connector or harness in the LSU is
disconnected or broken.
Polygon motor trouble
Check and
remedy
Use DIAG (SIM61-1) to check the polygon
motor operation.
Check connector and harness connection.
Replace LSU.
Posted on Jan 24, 2010
SC L6-10 ON 5631
i have problem in my photo copier sharp ar203e the problem is op what mean?
Mar 22, 2013 | Sharp AR-M450N Copier
I have an Error on my Sharp AR-M350n+ copier that says "L6-10" Can you please tell me that that error code means? Thanks
L6 10 Polygon motor trouble
it is a very common problem on sharp copiers
that means the laser unit is defective, tou have to change it , allso is very expensive..
regards,
Adi
Nov 03, 2010 | Sharp AR-M350N Copier
My sharp AR-5316 is displaying an error code L6. please what could be the possible fault and solution. mzm from dubai
Error code L6: Polygon motor lock trouble Details : The polygon motor does not rotate. Possible Cause :
  1. Polygon motor unit failure
  2. Polygon motor connection harness trouble
or disconnection
  1. MCU PWB failure
Solution:
  1. Replace the polygon motor.
  2. Replace the MCU PWB.
Oct 14, 2010 | Sharp AR-5316 Advanced Digital Imager...
L6-10
sorry you must change laser unit
May 26, 2010 | Sharp AR-M450N Copier
Aug 19, 2009 | Sharp AR-M205 Copier
The L6 code is flashing on my copier
No you can't, it is the polygon motor not rotating. It is inside of the Laser unit. You should replace the polygon motor. The part code is RMOTN0028QSZZ. It will cost you about US$ 80
Jun 04, 2009 | Sharp AR-160 Copier
Gunawan
Hi Gunawan,
The error 'L6' is usually an indication of problems with the Laser Unit in the copier.
Unfortunately the unit will have to be replaced and can only be done by trained personnel.
Contact your closest Sharp Dealer for assistance.
Regards
Gavin
Oct 13, 2008 | Sharp AR-5316 Advanced Digital Imager...
Sharp AR-151
E7-03 LSU problem (laser unit) E7-04 CCD white level problem E7-05 CCD black level problem E7-12 Shading problem
Sep 05, 2008 | Sharp AR-5316 Advanced Digital Imager...
I HAVE AN ERROR CODE L6 ON A SHARP AR-163 PDIGITAL IMAGER. WHAT IS CAUSING THIS ERROR AND CAN IT BE REPAIRED IN-HOUSE?
Apr 18, 2008 | Sharp AR-M160 Laser Printer
Sharp AR-5316, showing L6 on display
Jan 02, 2008 | Sharp AR-5316 Advanced Digital Imager...
53 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
