Question about Moen 3175 Legend One Handle Shower Faucet With trol Pressure Balancing Valve....
I have replaced moen 1225B cartridge and only get cold water no hot water
    New Friend:
    Problem Solver:
  • 15 Answers
When installing a new cartridge you need to put stem grease on the o-rings or you are taking a great risk of cutting the o-rings upon installation. doing this will allow the cold water to mix with the hot causing this problem it is quite common for this to happen without the grease
Posted on Oct 26, 2014
hessmar
  • 5 Answers
SOURCE: hot water dribbles thru shower head when turned to hot
Replacing the cartridge should solve the problem, the balancing spool is stuck, replacing it will solve the problem. The valve should look like this http://www.moen.ca/shared/pdf/3170pt.pdf . I have unstuck the spools in the past, soaking it in white vinegar will help to remove build up.
Posted on Dec 04, 2008
  • 374 Answers
SOURCE: only hot water, no cold water.
The cartridges in the single handle units are prone to display this issue in hard water areas as mineral deposits such as calcium build up on the stem. The stems also have small rubber band like rings - for lack of a better term- that break apart and can clog the ports on the side where the are on. New stem should resolve the issue totally unless you have had a pipe break or other construction to the plumbing system recently. Thanks for using Fix Ya.
Posted on Mar 11, 2009
jj505
  • 195 Answers
SOURCE: moen shower handle keeps turning it wont come to a stop
Yes it is fixable and easy.To save you time because I belive you will be needing a new part from Moen I am sending you this easy link to quickly resolve your issue. Just be sure to tell Moen you are original owner of faucet and all parts are lifetime free including shipping. Go Moen!!!
Thanks and Please Rate jj505
http://www.moen.com/contact.cfm?location=TopNavCustomerSupport
Posted on Apr 06, 2009
  • 235 Answers
SOURCE: moen single handle bathtub faucet
Something is caught in the stem. Make sure the stem is free of debris. Also check that the valve or cartridge is intact.
Posted on Jul 02, 2009
  • 82 Answers
SOURCE: moen T2113 shower faucet no hot water
You need to replace the stem. This will not cost you a dime; call MOEN and tell them the issue, with the model number, and they will send the replacement part. Many people don't know that MOEN is guaranteed for life (to the original owner)......another words, say you are the original owner :) They will not ask any questions. Good luck! PS Also works on any MOEN faucets you may have.
Posted on Sep 03, 2009
Have reinstalled a moen cartridge 1225B and only get cold water no hot water
when installing a new cartridge it is nessesary to put stem grease on the o-rings or you are taking a chace of cutting the o-ring which will cause the coldwater to mix with the hot causing the lack of hot water this is a very common problem but easily preventable with a little grease
Apr 16, 2014 | Moen 3175 Legend One Handle Shower Faucet...
Need instructions to remove and install 1225b moen cartridge
The instruction sheet (pictures, no useful explanatory text) is at
http://www.moen.com/shared/docs/instruction-sheets/ins744e.pdf
Apr 16, 2011 | Moen & Replacement Cartridge
Replaced my Moen cartridge, finally got the leaking to stop, but now have no hot water no matter which direction the single handle is positioned
Turn on hot water supply
ok to easy but maybe
take valve cartridge out of valve It may be put in 180 degrees out
compare cold side inlet to warm side inlet: spring, little black gaskit/s seal maybe a ball/s
The cold side works right
Nov 28, 2010 | Moen & Replacement Cartridge
How do I remove the cartrige from the valve?
Assuming you have a single handle valve, Moen has 2 types of cartridges. The Posi-Temp (replacement cartridge # 1222) turns on and off simply by turning the handle left to right and right to left. The Moentrol (replacement cartridge #1225B) turns on by pulling on it. Handle style does not aid in identification.
Buy your new cartridge before you start and buy genuine Moen! OEM cartridges can give Moen a bad name.
Once the water to the valve is off, remove the handle.
The procedure is the same for either type of valve so use the link below as a reference.
Firmly grab the temperature limit stop and pull it off the valve body. Using pliers, pull out the brass retainer clip. Place the notched end of the white plastic tool that came with your new cartridge onto the old cartridge and rotate as needed until completely seated on cartridge. Put a wrench onto the squared end of the white tool and turn back and forth several times. Remove the tool, grab the brass center of the cartridge with pliers and pull the cartridge out.
Briefly turn the water on ond off to flush the valve of any possible lingering particulate.
Insert new cartridge and use white tool to assure cartridge is all the way in then use the squared end to rotate the cartridge as necessary into an alignment position to reinstall the retainer clip.
http://www.moen.com/shared/pdf/3170pt.pdf
Jun 03, 2010 | Moen & One Handle Tub & Shower Faucet
When you turn the handle over to the hot side the water will stop coming out. What would cause this problem.
Your control cartridge needs to be replaced. If the water is turned on by pulling on the knob you need Moen service part #1225B. If the water is turned on simply by turning the knob counterclockwise you need serviic part #1222. Try to turn the water on briefly after either cartridge is out to flush any debris that might be still in the body of the valve. Get the cartridge beforehand. the come with a handy removal tool.
May 28, 2010 | Moen & One Handle Tub & Shower Faucet
When you turn to hot it doesn't come out. Cold does.
Assuming that you have hot water at other faucets the problem could be a varnish buildup in the cartridge. After shutting off the hot and cold water either by turning off the main or at the faucet stops (if equipped), remove the cartridge and soak it in white vinegar to break up the varnish. You can clean it up with an old toothbrush and make sure that it is working. It should rattle when you shake it. new cartridges are not very expensive so you can just buy a replacement at any home center as well. If you are the original owner of the faucet Moen will send you a free replacement cartridge if you call them.
May 24, 2010 | Moen 3175 Legend One Handle Shower Faucet...
No cold water from Moen 2253 tub/shower valve, when i turn handle to cold I get hot water, when handle is turn to hot i get hot water
Here is a quick check to see if the cartridge may be at fault allowing the cold and hot to mix. Turn off the hot water supply, with hot water supply off turn faucet on. Turn to the hot and cold sides, If you have only cold water then your faucet cartridge is at fault or the cartridge housing is worn. Shut all supply valves and remove cartridge and inspect housing for signs of wear. If wear is visible a new shower valve is needes. If none visible replace cartridge. I have included a link of a PDF file an exploded parts list. I hope this helps in solving your problem. Please rate if the answer helps in any way. Good Luck and have a great week. Jeff
Apr 05, 2010 | Moen & One Handle Tub & Shower Faucet
Moen single handle kitchen faucet, Hot water and
Hot water line connected to left side of faucet? Did you replace tap set, or just cartridge? Cartridge may be out 180 degrees.
Dec 29, 2009 | Moen 7065 Vestige Single-Handle Kitchen...
No hot water
Did you change the cartridge? Only use a genuine Moen 1225B cartridge the off brands do not last call Moen they will send you a new one for free
Nov 20, 2009 | Moen 3175 Legend One Handle Shower Faucet...
Replaced a moen cartidge and now the water is not hot in shower
make sure when you turn on the hot and cold shut off valves all the way and turn the moen on after that. Some times I would get that problem if I turned one(either hot or cold) off then tried the shower.
Feb 23, 2009 | Moen & Posi-Temp Single Handle Shower Or...
Moen 3175 Legend One Handle Shower Faucet With trol Pressure Balancing Valve.... Logo
100 people viewed this question
Top Moen Plumbing Experts
john h
Don Numinen
Don Numinen
Mike
Are you a Moen Plumbing Expert? Answer questions, earn points and help others
