Question about Kenmore Refrigerators
Puddles of water are on the floor from the bottom of the refrigerator opposite side of the ice maker (near the compressor or the condenser fan)
  • Kenmore Master
  • 4,655 Answers
Your defrost drain is either blocked, missing the defrost pan, pan cracked or poring through the body of refrigerator. It also could be a leak at your dual water control valve. Let me know what the model number is for example 213.54698 and I will be able to get a picture of your refrigerator and help you better, Thanks, Sea Breeze
SITE=> http://servicepartstec.blogspot.com/
Posted on Jun 19, 2009
Fridgidaire ffht1817lw8 noisy operation
Good Afternoon John, thank you for your post! Your new high-efficiency refrigerator may make unfamiliar sounds. These are all normal sounds and soon will become a common hum in your home. This noise also indicates your refrigerator is operating as designed. Hard surfaces, such as vinyl or wood floors, walls, and kitchen cabinets may make sounds more noticeable.
Listed below are descriptions of some of the most common sounds you may hear, and what is causing them:
A. Evaporator: The flow of refrigerant through the evaporator may create a boiling or gurgling sound.
B. Evaporator Fan: You may hear air being forced through the refrigerator by the evaporator fan.
C. Defrost Heater: During defrost cycles, water dripping onto the defrost heater may cause a hissing or sizzling sound. After defrosting, a popping sound may occur.
D. Automatic Ice Maker: If your refrigerator is equipped with an automatic ice maker, you will hear ice cubes falling into the ice bin.
E. Cold Control & Defrost Timer or Automatic Defrost Control: These parts can produce a snapping or clicking sound when turning the refrigerator on and off. The timer also produces sounds similar to an electric clock.
F. Condenser Fan: If condenser coils are located underneath your refrigerator you have a condenser fan. You may hear air being forced through the condenser by the condenser fan.
G. Compressor: Modern, high-efficiency compressors operate much faster than older models. The compressor may have a high-pitched hum or pulsating sound.
H. Water Valve: If your refrigerator is equipped with an automatic ice maker, you will hear a buzzing sound as the water valve opens to fill the ice maker during each cycle.
I. Drain Pan (Non-removable): You may hear water running into the drain pan during the defrost cycle. The drain pan will be located on top of the compressor for air-cooled condensers (black coils on back of refrigerator).
I do hope this information proves to be helpful. Should you need any further assistance please feel free to respond.
Aug 27, 2013 | Frigidaire FRS3R5EMB Side by Side...
Kenmore SbS refrigerator, water dispenser not working
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
http://www.fixya.com/support/r4588788-refrigerator_or_freezer_not_cooling_or
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Apr 29, 2010 | Kenmore 22.0 cu. ft. Side-By-Side...
Not making ice, making a loud humming noise its a top freezer RT18BMXBL01
The ice maker has completely stopped producing ice:--Check to see whether the ice maker has been turned off. Here's how to check. Look for a wire along the right side of the ice maker that looks a bit like a coat hanger. If this wire is in the raised position, the ice maker is turned off. On some units you simply lower the wire to the down position to turn the ice maker on. On others, you lower a small red plastic lever to lower the wire. If the wire is in the proper position check the freezer temperature, it should be between 0-8 degrees Fahranheit. If it is warmer than 10-12 degrees, the ice maker may not produce any ice. Check your door seals and thermostat, repair/replace as necessary.
The ice maker is producing ice poorly :--When an ice maker is producing ice poorly--when it produces just a few cubes or none, or when the cubes are too small--it's usually because of a clogged water line or a defective water inlet valve.First, check the water line attached to the back of the refrigerator for good water flow. To do that, first turn off the water supply valve. Then remove the water line from the back of the refrigerator. Next, place the water line into a bucket and momentarily turn the water valve back on to test the flow. If the flow is poor, you need to repair, clean, or replace the tubing or the shut-off valve that supplies the water. If the flow is good, you may have to replace the water inlet valve.
Noise can come from these areas:
The inside of the freezer :--Self-defrosting refrigerators use a circulating fan to move the air through the freezer and refrigerator compartments. This fan runs whenever the unit is cooling. The fan is located in the freezer, as follows:If the freezer is on top, the fan is on the back wall, near the top or bottom, in the center of the freezer.If the freezer is on the bottom, the fan is on the back wall, near the top of the freezer.
If the freezer is on the left, the fan is on the back wall, halfway up or near the top.
Over time, the fan may become noisy--usually making a chirping or squealing sound, though it may make a loud groaning noise instead.To find out if the fan is causing the noise, just open the freezer door and push in any fan/light switches. If the noise is louder when the door is open, the evaporator fan motor is the cause. You can't lubricate or repair this motor. You must replace it.
The outside back of the refrigerator:--There are three components on the outside back of the refrigerator that may become noisy: the compressor, the condenser fan motor (if self-defrosting), or the defrost timer (if self-defrosting).The compressor is a football-sized case with no apparent moving parts. You can see it on the outside of the refrigerator at the back near the bottom. It is usually black and has black or copper-colored tubes and various colored wires attached to it. If the compressor is the device making noise, there is probably no repair that will reduce the noise. You will have to replace it--which can be quite costly.
If the condenser fan is making noise, there may be a build-up of lint or other debris on the fan blade. The fan is located near the back of the machine, sometimes behind a thin panel. To clean it, first unplug the refrigerator, remove the thin panel, and use a soft bristle brush to clean it. If there is no lint build-up or debris on the blade, you will have to replace the motor.The defrost timer is often located at the bottom of the refrigerator, near the front and behind the kick plate. Occasionally the electric motor inside the timer may become noisy. The timer must be replaced to solve this problem.
The bottom of the refrigerator:--Noises detected at the bottom of the refrigerator almost always originate from the back of the refrigerator. However, sometimes the drain pan under the refrigerator will rattle. You may need to tape the pan in place to stop a rattle. Also see the “Outside back of the refrigerator.”
This will help.thanks.
Feb 21, 2010 | Roper Refrigerators
My Fridgidaire Professional series refrigerator has a puddle of water in front of it about once every other day. The puddle is around the front on the freezer side of the fridge. What can I do to fix this?
Drain line in the freezer section is clogged, needs cleaning. There is a small drain pan on the bottom of the rear wall in the freezer. It is covered with ice. Defrost or remove ice, and get to the drain hole. try flushing with hot water, if does not help - clean mechanically on both sides of the drain line - in the freezer and in the back of the fridge, where it comes to the drain pan near condenser/compressor.
Oct 16, 2009 | Frigidaire Professional 26 cu.ft....
253 55682402 Kenmore Side by Side Refrigerator Not Working. Freezer is not freezing and the fridge part is not cooling properly. Also water to ice maker and instant water in front of door stopped working....
. Cut everything off for a few minutes then turn it back on and listen for a click from the compressor relay as the compressor tries to start.
Is the compressor motor running.If no check starter/overload relay.
Check to see if the condenser fan at the back underneath near the compressor is running. If no check fan.
Are the condenser coils near there warm or room temp. should be warm
How to check stuff>
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Aug 21, 2009 | Refrigerators
Freezer is leaking and also makea buzzing noice
Hissing and popping is normal, it is the defrost heater.
Check that the freezer is level
Check the drain pan
Check the condenser fan
Check the evaporator fan
Inspect the compressor mounts
Water on floor outside of freezer?
* Check the drain pan
* If you have an ice-maker, check the water supply hose going into and coming out of the water inlet valve
Water inside the freezer?
* Check for a clogged drain tube
* If you have an ice-maker, check freezer and ice-maker for level
Aug 08, 2009 | Maytag MZD2766GES Side by Side...
Water and ice in bottom of freezer, occasional water on floor
I believe your defrost condensate pan below the evaporator is blocked with ice and now when defrost happens the water pours over the tray and to the bottom of the freezer. You will need to defrost the ice in the collector tray and the pour a solution of hot water and clorox to make sure the water ends up in the condensate pan below your refrigerator. So unplug the refrigerator remove the panel and let me know what you find. I have some more solutions depending on what you see is happening. Thanks, Sea Breeze
Jul 23, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice freezing up on bottom of freezer and water puddles in front
Two possibilities, ice maker leaking or the defrost drain is blocked with ice or another object. Unplug the freezer and remove the rear panel in back of freezer. At bottom of the evaporator coil is a tray that catches the defrost condensate and sends it to the pan beneath your refrigerator to be be heated by the compressor and fan heat produced from the condenser. The moisture is then returned to the air inside your home. If the drain is blocked with ice or anything between the freezer and the pan below, the condensate tray will overflow will end up inside your freezer or fresh food compartment. Questions? I will be here to help you, Let me know, Sea Breeze
Jun 23, 2009 | Maytag MSD2758G Side by Side Refrigerator
Not cooling or freezing
When the compressor is running, both the fan inside the freezer and the fan down by the compressor should be running. If OK, look for frost on the back wall of the freezer, indicating a probable defrost heater failure. If yes, remove back metal cover in freezer, defrost with hair blower, replace defrost heater (the thing at the bottom of the freezer coils with two wires going to it)
If no to these, send me an "ask me" follow up question.
Aug 28, 2008 | GE GSS20IEP Side by Side Refrigerator
GE 25 side by side refrigerator ice maker problem
Assuming the temp inside the freezer is at around 0 or -2 degrees, it should dump ice every ~50 minutes or so. Again, depending on temp's, an Ice Bin should fill within 24 to 48 hours. If your freezer temp is running at around 10 degrees, everything will obviously still be frozen (below 32), but the ice maker will take longer to freeze the water than it would if it were at 0 degrees. Open both doors and place the palm of your hand on the partition between the freezer and Fresh Food compartments... (where the door gaskets seat when they're closed). The temp of the partition should be about 5 or 10 degrees warmer than body temp., If it's hotter than that, you found the problem. Either the condenser coils are dirty and need a good cleaning OR your condenser fan motor (the fan in back, near the floor in the compressor area) is failed or about to fail.
Jul 29, 2007 | Maytag MSD2756G Side by Side Refrigerator
Refrigerators Logo
150 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
