Question about ViewSonic VA721 17" LCD Monitor
The screen always has to be adjusted horizontally. It always is too far to the left.
  • 36 Answers
Go into control panel and set your screen resoloution to the correct amount. you will know when it's correct because it will look perfect.
Posted on Jun 18, 2009
I accidentally hit the auto-adjustment button on my monitor. Now, the an inch of of my screen from left to right is black. Not even my mouse can go into the black space.
Did you try hitting the Auto adjust again to possibly shut it off. Quite often the buttons work as off and on buttons such as the Caps Lock. you hit it and it's on. You hit it again. It's off. If you hit the Auto adjust it might shut off and re-adjust your screen to the original setting you had. ....don't forget that you made other adjustments to compensate for the mal adjustment that will need to be fixxed. good luck.
Dec 22, 2014 | HP W2072a 20in. LED-Backlit LCD Monitor,...
My picture is doubled on my toshiba TN50V71 as if there is a shadow behind everything? Please help!
hi, sounds like a convergence issue. try this...
  • Look through your manual. Your manual will always give you the most specific directions for your particular model. Look for an "adjusting convergence" or "set manual convergence" section.
  • Enter the menu on your TV. Use the remote control and bring up the menu.
  • Choose "Convergence." This may be under "Picture Settings," "Function" or "Advanced Options."
  • Select a color. You will have red, green and blue to choose from. Do each one, starting with red.
  • Press "Enter." A crosshair pattern will appear on your screen.
  • Adjust vertically. If there is a horizontal red line visible, press the up or down arrow keys (or channel up or down) to adjust the convergence until the line is superimposed on the horizontal-center line of the white crosshair.
  • Adjust horizontally. If there is a vertical red line visible, press left or right (or volume up or down) to adjust horizontally. Do this until the line is superimposed on the vertical line of the white crosshair.
  • Save settings. It is important to save your settings when you are done, instead of simply exiting the menu.
  • Repeat these steps for all colors.
    good luck!
  • Feb 02, 2011 | Toshiba TN50V71 50" Rear Projection...
    It has tripple vision and looks like a bow tie.
  • good luck!
    Feb 02, 2011 | RCA HD61W66 61" Projection HDTV
    How do you set convergence
    What is your Make and Model number?
    Mar 18, 2010 | Televison & Video
    The screen is stretched there is nothing distorted
    What kind of monitor? They can all be adjusted for width and height by using the buttons along the bottom of the screen. Often it can be confusing and a bit of a pain but look under the monitor menu for 2 sets of icons that look like 2 boxes on top of each other both horizontal and vertical. That is how you adjust it.
    May 29, 2009 | Acer AL2216WBD LCD Monitor
    Convergence lines are SLANTED. Red line is above horizontal center on left side on screen and below horizontal center on the right side of screen. Also left of Vertical center at the top of the screen and...
    did you check the six 3.5 pico fuses that are next to the ICs? They will often be open ( blown) when the ICs fail. Also check the two 5 amp IC protectors on the G board as those protect the two ICs so its possible they have blown also a 5 amp pico can be substituted for the two IC protectors.
    Apr 26, 2009 | Sony KP-46WT500 46" Rear Projection...
    Verticle and horizontal outstretch the scree
    the Video modes should take care of that, you should be able to adjust it from the remote.
    Video size/mode/etc.
    Charles
    Jan 08, 2009 | TruTech PLV16190 Television
    Centering your monitor screen
    on the monitor press the menu button in that adjust the horizontal and vertical size correctly ... you will having the option to adjust in the menu button ...
    this will fix your problem ...
    thank you
    bye
    any doubts you can reply me
    i am always here to assist you
    rate my solution
    Mar 08, 2008 | Samsung SyncMaster 240 T 24.1" Flat Panel...
    How to fix horisontal lines on display ( see the picture)? They stronger when system is restarted and then fading but never disappearing. They always stay the same.
    horizontal lines can be caused by either a faulty grapchics card or a faulty monitor. try adjusting the screen refresh rate. if you are using a windows xp system goto
    start>control panel>display>settings>advanced>monitor
    then adjust the screen refresh rate and see if the horizontal lines disappear. if not, then you probably have a faulty graphics card or monitor.
    Jan 27, 2008 | XFX GeForce FX 5200, Graphic Card
    ViewSonic VA721 17" LCD Monitor Logo
    52 people viewed this question
    Top ViewSonic Computers & Internet Experts
    Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
