Question about Frigidaire Dryers
No hot air - Frigidaire Dryers
  • Frigidaire Master
  • 5,323 Answers
ELECTRIC Dryer no heat or little heat, or shuts down to fast:
Check your venting and lint basket. Check blower for lint build up and blower wheel obstruction., test by trying to turn the wheel manually by hand (should be easy) May have to remove cabinet or front/back plate to get to it)
Next check the heating element itself with a meter for continuity OHMS CLOSED CIRCUIT. If not its defective or has a short if its grounding out? Which in turns causes blown fuses or thermostats or overheating.
Check dryer Terminal block prongs both outside prongs should give combined 220, and 110 each if u check 1 outside & 1 center (ground) prong. Also check house electrical outlet for full voltage. 220 because if u only get half or 110 volts you will be able to run the machine which uses only 110 to run motor but not the heater which uses a full 220,
Check the thermal cut off, the cycling and the hi limit thermostats.
For continuity or OHMS. If no ohms or resistance they need replacement.
In some dryer's the control panel relies on a thermistor rather than a CYCLING thermostat to regulate the drum's air temperature by monitoring the component's resistance changes; resistance goes down as temperature increases and up when temperature decreases. Once the drum's air temperature reaches a certain level required to dry clothes, the control panel shuts off the heater. The panel will turn the heater on again and begin another heating cycle when the thermistor indicates that more heat is needed to keep the air temperature constant inside the drum
Lastly check your moister sensor. ( located inside the dryer door usually) Especially if machine seems to shut down early and clothes are still wet.
Test with a meter at room temperature and it should show continuity.
A failed moisture sensor will affect the dryer run time in the automatic moisture sensing cycle but it will not affect the heating of the dryer or the timed cycle. Which are reflected by the thermostats.
Read more :http://www.ehow.com/info_12203962_check-dryer-thermistor.html
Posted on Apr 22, 2015
Hot air from drivers side cool air from passenger side
Driver's side blows hot air; passenger side cold air - Hyundai ...
www.hyundai-forums.com/.../294097-drivers-side-blows-hot-air%3B-pa...
Jul 29, 2014 - 3 posts - ‎3 authors I soon noticed that the driver's side blows warm air and the passenger side blowscold air as it should. No amount of adjusting the temp control ...
Hot air on driver side vents - Cold on passenger side - Page 3 ...
www.odyclub.com/.../46646-hot-air-driver-side-vents-cold-passenger-si...
May 9, 2012 - 16 posts - ‎10 authors I have a 2009 EXL Odyssey that just is doing the same thing (warm air on drivers side, cold on passenger). I checked freon levels and ...
Oct 15, 2015 | 2009 Hyundai Sonata
My Renault logan only blow cold air
So the AC is working, but when you select hot air, it doesn't work? Does cold air come out when you select hot air, or does no air come out? Please provide as many details as you can. What year is the car?
Perhaps the dial to select hot or cold air is not working. Does the dial feel the same as it always has, or has there been a change recently?
Is the engine warm when you try to select hot air? If the car hasn't been running a while you won't get hot air.
Jun 10, 2015 | Renault Cars & Trucks
Why my 06 suzuki reno blow air while idling but blow hot air when put in drive
is this a HVAC question heater and a/C?
cold engines, make only cold air
hot engines make hot air.
for 100 +years. now.
Mar 26, 2015 | 2006 Suzuki Reno
Hot air blows into car from underneath of car what is causing this
does the air blow in when the car is not moving. if it does, your heater switch is on and blowing hot air in through the bottom vent.
Apr 01, 2014 | 1997 Ford Taurus
My air conditioner on 2007 suzuki reno blow hot air
it will need service,
check pressures.
hot air as in heater on, so turn off the heater,
test in pure A/C mode Cold.
when both A/C and heat are on this is called defrost mode
which adds cold dry air to hot air and dehumidifes the hot air and window.
Jan 18, 2014 | 2006 Suzuki Reno
No hot Air on Driver side vent. 2004 W/Truck with
Check the actuator ot the pass side blend door for proper operaton. If it does operate remove it and confirm that the door is not broken.
Nov 03, 2009 | Chevrolet Silverado 1500 Cars & Trucks
Blows hot air
My 2003 chevy suburban just started blowing hot air...it was working find , then i stopped to eat lunch, when I came out it started blowing hot air
Jun 25, 2009 | Heating & Cooling
Electric dryer only has hot air, or air dry
This is one of those problems that could be a number of issues. It could be a timer contact stuck in a hot condition, it could be the operating thermostat inside the unit, or if you have a heat cycle selector switch, it may have shorted as well. Each one of these items should be tested with an ohm meter to verify which one of them is the bad part. Let me know if you need further help.
Feb 14, 2008 | Dryers
Dryers Logo
53 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
