Akai x200d blows fuse in tape deck as soon as you turn it on. possible voltage spike from lightning?
  • Audio Player... Master
  • 1,267 Answers
More likely a defective Electrolytic capacitor due to age. These things are not new. If lightening damaged it there would be large area of carbon black arcing. This usually happens to telephone or TV with antenna type units not a tape deck.
Posted on Jan 02, 2015
robotek
  • 1512 Answers
SOURCE: Gx-77 Akai reel to reel tape deck -belt
G'day Chidu
You can buy a replacement belt kit with the correct belts for your model from here
Thanks for using FixYa, a FixYa rating is a great reward for locating this part for you. Good luck with the repairs, and happy listening.
regards
robotek
Posted on Sep 11, 2008
SOURCE: I'm looking for a speed sleeve for the Akai 4000DS
I had no problem I was looking for a speed sleeve for an Akai 4000DS MK2.
Thank you.
Regards,
John Hynes
Posted on May 03, 2009
Grubhead
  • 5455 Answers
SOURCE: akai gx-625 reel to reel tape deck has no sound
This could be a head fault? Another possibilty is the preamp stage. You will need to look for something that would take out both channels. Such as an IC.
Posted on Sep 11, 2009
caroldon
  • 17130 Answers
SOURCE: akai -300 tape deck the chassi is hot.ground and
It is possible that the main line in the power supply must be checked first for any leaks . Use a good multimeter to check for the resistance shorting to the ground. If there is neglible reading then disconnect the DC section and start from the power supply side. check from the supply wire, the capacitor, the transformer, motor and any foreign material that could create a short. Connect the line and use a good line tester to check for the voltage and disconnect one by one the sections until the line leak is found. Then probe into the section last disconnected to confirm and correct. I am sure this will not be difficult to solve. Good day
Posted on Aug 10, 2010
dunnbiker
  • 8546 Answers
SOURCE: I have an AKAI X-1810D tape deck that does not
Just a guess. Have you cleaned the two conductors on the sensor? You can test its function by running the tape in either direction and shorting it with a non-ferrous metallic object, say, an aluminum. You don't want anything magnetic near your prerecorded tapes.
Posted on Jan 04, 2011
I have an Akai X200D reel to reel and my reverse direction button will not work.
The "button" may be defective but possibly salvageable by using contact cleaner.
Jan 13, 2018 | Akai Audio Players & Recorders
Akai x200d reel to reel tape player playback is a bit high pitch,
The capacitor, if you mean the run capacitor, its value is not critical. Probably a dirty contact in the speed switch.
Nov 24, 2017 | Akai Audio Players & Recorders
AKAI REEL TO REAL MODEL 1700 OPERATOR'S MANUAL
Here you are Andrew. That is a blast from the past!!
Service Manual and Owner's Manual!
Akai 1700 Manual Stereo Tape Recorder HiFi Engine
Jan 23, 2016 | Computers & Internet
I have a 04 explorer keeps blowing ignition fuse. Need to no why. It just started today. Please help
Have your alternator checked. The voltage regulator may be failing causing spikes in the voltage, which will blow fuses (and possibly damage other things). Another thing to check is the ignition coil for shorts.
Jan 12, 2016 | Cars & Trucks
Manual for AKAI MK8 reel to reel recorder
Do an online search for Akai MK8 data. I was able to get information for my Akai that way
Jun 17, 2013 | Audio Players & Recorders
We have PDV42S10, There is no power to TV. The green light does not come on. There is power in socket . Thank you
In most cases, if the main power supply fails, the low voltage supply that provides enough power so the set can receive input from your remote, also lives on to signal problems, often by flashing the power LED in a pattern.
In your case, apparently the low voltage supply is also dead.
This can be caused by both supplies being damaged from a line surge caused by 'dirty' AC power, or a spike from a lightning strike somewhere in your power network.
These spikes can travel long distance so a strike need not be all that proximate to do damage.
If no fuse holder is found on the back of the set, it may be necessary to remove the back panel for access.
If you choose to do this, it is safer to leave the set unplugged overnight to allow any hazardous voltages to discharge.
Look for a separate board or an area which has larger components in it.
These will be cylindrical cases and larger block-like parts.
If there is a user-replaceable fuse in the set at all, it will most likely be in that area.
If this damage was caused by a high voltage spike replacing the fuse may be fruitless and if a replaced fuse blows again, then other circuits have been damaged and major boards will have to be replaced as well.
The cost of reviving a lightning damaged set of any kind can often exceed the cost of replacing the whole set.
Even the most primitive plug strip contains components that afford some protection against this kind of damage but the best protection can be had with a 'whole house' surge suppressor.
These cost ~$200 US and feature insurance against appliance losses up to $10,000.
They require access to the main breaker box, safety precautions and a few tools for installation.
Sep 13, 2011 | Akai 42 in. LCD TV
I static shocked my tape deck while plugging in my droid with a tape adapter, is the deck dead?
def dead if the fuse is good usualy hooking them up live spikes the capacitors and causes a short circut internaly
Feb 05, 2010 | Car Audio & Video
When I try to record a VHS tape or play one it continually ejects the tape as soon as TV is turned on.
Try turning the TV on first and then inserting the tape into the VCR. You may be getting a small voltage spike that is causing your VCR to eject the tape.
Dec 01, 2009 | Televison & Video
Instantly blows the 5 amp fuse next to the power cord plug.
You have a short in the power supply. Look at the regulator and or rectifier diodes. These are all on th primary side of the SMPS (switched mode power supply) the secondary side if shorted shouldn't cause a blown fuse at all.
Mar 18, 2007 | Mitsubishi VS-50607 50" Rear Projection...
67 people viewed this question
 Grubhead
Grubhead
