Question about Singer Confidence 7469 Mechanical Sewing Machine
Presser bar adjustment
My presser foot is stuck down and will not move
3 Suggested Answers
  • 1788 Answers
SOURCE: My presser foot bar moves
I just looked at your manual on www.singerco.com and all I can see is that maybe, your chosen stitch length is not long enough, or your feed dogs are not up. Another possibility could be tangled thread or fabric is too slippery(try some tissue paper under fabric) check your needle size. If, you misplaced your manual it is free on the above website. Good luck, sometimes machines are just being ornery.
Posted on Sep 17, 2010
SOURCE: The Presser Bar on my Singer 66 does not move up or down when I use the Presser Bar Lever. It seems to be stuck solid and therefore it will not lower onto the feed dogs to enable me to sew. The Presse
it's possible that the presser bar could be bent or damaged, the only way to know what is exactly wrong would be to take it to a sewing machine repair shop
Posted on Mar 21, 2012
The presser foot on my Singer Touch & Sew 756 is stuck in the up position. I can move the lever up and down but the presser foot will not move. Any suggestions.
Very common thing because the presser bar is always very tight in the housing, all you need to do is put some easing oil or wd40 on the bar and physically move the bar up and down and it will free off
Oct 03, 2013 | Sewing Machines
Singer 756 diagram
WD40 on the presser bar at the top and physically move the bar up and down until it frees off, very common
I have a Singer Stylist 533 and the feed dog isn't working properly. It is not jammed because if I turn the handle to use the machine manually I can see it moving below the presser foot. However, once I...
This could be a couple things. First it could be your presser foot pressure is not high enough or the presser bar is sticking and not pushing on the fabric properly. Second it could be broken feed gears. To check this remove the needle and foot and place a finger on the feed dogs. Then turn the hand wheel and feel if the feed dogs are still moving with the pressure of you holding them down. If the stop moving the you most likely have a broken gear or two. The first problem could be resolved by adjusting the setting of the needle bar pressure or oiling the bar if sticking. The second one needs a sewing machine repair person,
Sep 13, 2013 | Sewing Machines
My presser foot "handle" is stuck on my Pfaff Creative 7550, I can't move it to use my machine. I don't see anything wrong, any suggestions?
Yikes! I bet that since it has sat for so long that you have some corrosion not allowing the foot bar to be moved.
Dec 15, 2012 | PfaFF Creative 7570
I can't get the foot to lower and raise.
it sounds like it's out of time--here's how to fix it
to adjust the pressure on the presser bar and in turn the foot, locate the thumb
screw at the top of the machine
by rotating the thumb screw clockwise, you will increase the pressure, a counter
clockwise turn will decrease the pressure
the correct height of the pressure foot from the needle plate is 7mm.
to adjust this clearence loosen the screw & adjust the pressure bar through
the guide
secure the screw firmly when the correct adjustment is obtained
the distance between the presser bar lifting arm & the presser bar guide should
be 0.5mm ..( be sure the needle bar does not rotate left or right during the
adjustment process. the needle must be center of the presser foot & needle
plate hole,, if this is not centered re-adjust to the center of both needle foot
& needle plate hole.
Apr 07, 2012 | Sewing Machines
My machine makes a "knocking" sound.
Needle bar probably catch the presser foot, because it does not return the the right position. Clean and oil the presser foot assembly. There is no tension adjustment there. It should move freely about 1 cm.
Dec 03, 2011 | Brother PE770 Computerized Sewing Machine
The foot doesn't go down enough to reach the feed dogs
The presser bar may be stuck and may need some WD40 on the top so it seeps down the needle bar, or the presser foot dial or adjuster is set to 0, or the presser bar spring has broken, or the block and screw on the presser bar where the lever is has come loose.
Sep 02, 2011 | PfaFF Sewing Machines
I have a singer 4552 (portable) and I am having a prblem getting the zipper foot attached. Also I am having a problem getting the design stiching to work. I can get the red design stiches to work but not...
Hi. Here's how to attached the zipper foot.
To Attach the Zipper Foot
1. Loosen the large screw at the left of the presser bar and remove presser foot (You do not need to remove the screw).
2. Hook the prongs of the Zipper Foot around the presser bar from the back, and tighten the presser-bar screw.
3. If the raised edge (zipper or cording) is to the right of the needle, adjust the Zipper Foot by loosening the thumb screw at the back of the foot and sliding foot to the left of the needle. If the raised edge is to the left, slide foot to right.
4. With presser foot down, check its position by lowering needle into side notch, making sure it just clears the foot.
5. Tighten thumb screw to lock foot into position.
When raised edge is placed to right -- adjust foot to left of needle.
When raised edge is placed to left -- adjust foot to right of needle.
Sep 04, 2010 | Singer Sewing Machines
Presser foot lifter is stuck can i fix it
If you can't lift the presser foot up at all undo the presser bar screw on top of the presser bar, if you have a dial turn it to 0, you should now be able to move the lever, if it is still tight put some WD40 on the presser bar and leave it for a couple of hours.
Nov 04, 2009 | Brother XL-5130 Mechanical Sewing Machine
Singer 6038
The presser bar is not moving, there is a set screw that controls the presser foot height on the bar, it may be to tight. Take the side cover off, and look for the presser bar, the set screw unit should be facing you. Unscrew it and see if the presser bar handel will now move.
The presser bar height should be set at 7 mm. To make an adjustment loosen the set screw. From the top of the machine, press down firmly on the presser bar and then secure the set screw.
Apr 07, 2008 | Singer 7442 Mechanical Sewing Machine
Singer Confidence 7469 Mechanical Sewing Machine Logo
18 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
