Question about LG enV VX9900 Cellular Phone
LG enV VX900 - need manufacturer/part number for charger connector
Connector has broken from PC board. I would like to buy another and replace it.
  • hurricanes29 Nov 05, 2007
    When i try to turn the phone on the verizonwirless symbol thing comes up, then the screen goes black and goes back to the symbol. It keeps doing that over and over again. Ive tried taking the battery out and putting it back in many times, but it hasnt worked.
The phone is an enV by the way
Posted on Nov 05, 2007
The ok button on my Env Vx9900 stopped working. Its a repaired one
your flex is broken. it should be replace with a compatible flex connector
Jul 24, 2012 | LG enV VX9900 Cellular Phone
My LG enV will not charge. The actual part that you put the charger in wobbles and is unstable. I do not believe that there is anything wrong with the charger. I have tried moving it around to find a...
The charging port has broken off the main circuit board.
You will need to have it repaired by your service provider.
There is no other way to charge it.
Aug 04, 2011 | LG enV VX9900 Cellular Phone
I've had my voyager for less than a week, and the place I got it from gave me a generic charger that broke inside the phone, what can I do?
Use tweezers or needle-nose pliers to remove the broken charger from the phone. If you cannot remove it, you will need to replace the phone.
Once you remove the broken charger, buy an OEM (original equipment manufacturer) charger, or a generic one from a respected brand.
If this helped you, help me with a few thumbs up!
Mar 03, 2011 | LG enV VX9900 Cellular Phone
Envy charge port keeps breaking
Try this one open your verizon phone.remove the shield can.. the one that covers all the components. See the usb port?solder both side of the usb connector to the ground.. that will make the connector stable and prevents from port from breaking
Dec 22, 2008 | LG enV VX9900 Cellular Phone
Verizon Wireless EN V LG needs help
you can get the new piece of the charger port & can be replaced that by soldering the wire to the circuit board ........
any way the charger ports are available at very very cheap rates ....
buy the one which is compatible for your phone & replace it ......
any doubts you can reply me
i am always here to assist you
thank you
rate my solution
Jul 07, 2008 | LG enV VX9900 Cellular Phone
My laptop will not charge!! the charger works, but it just wont charge my laptop!
most likely either a bad connector on the power cord or you've broken the motherboard connector. check the power cord with a volt meeter. if it comes up fine the i would recommend either contacting the manufacture or taking it to a reputable tech. if you are comfortable with doing it you can take the laptop apart and look at the connector with the laptop apart plug it in (CAREFULL IT COULD KILL YOU) and test the voltage after the connector wit the volt meeter. if it has power then most likely *********** board is dead. if it doesn't have power then you need to repair/replace the power connector.
Jul 07, 2008 | Computers & Internet
Broken charger port
i have the same problem with my enV my friend stripped the wires to my charger at the part where you plug it into the phone so now to charge my phone i tape the red wire to the positive on the battery and the black wire to the negitive there will be a shiny metal goldish color thing (there like 4 lil gold bars) on your battery that looks like this --> (negative) | | | | (positive) | - | | | + | tape the wires on the outside were the symbols are - and + and try not to let it toch the middle bars on the battery or it wont work and dont cover the little bars up with tape put the battery back in the phone making sure the wires dont move to much and it should charge sometimes you got tape the battery onto the phone to make sure it doesnt pop out but its what i do and it saves you money on having to go buy a whole new one or if you know someone with the same phone give them your battery to charge it :)
Apr 18, 2008 | LG enV VX9900 Cellular Phone
Env help plz
The reason the phone won't charge is because the internal power port pins are broken off of their solder joints to the main board inside the phone. Wiggling it helps at first because the pins can still touch their connection points but after a short time that will cease to help. Google "cell phone repair". It usually cost around $50 to get it fixed with a new power port installed. Turn-around is usually 2-3 days.
Mar 05, 2008 | LG enV VX9900 Cellular Phone
Orange LG EnV
if you look at the charger port you will see a metal sleeve around the inside. Itneeds to be bent a little in so it will make the soket tighter. then the socket needs to be cleand out with a small brush. I use a old dry tooth brush
Jan 02, 2008 | LG enV VX9900 Cellular Phone
LG enV VX9900 Cellular Phone Logo
263 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
