Question about GE Profile Arctica Stainless Steel Top Freezer Refrigerator
Ptb1952grw maytag fan runs no cold top and bottom
2 Suggested Answers
  • 1462 Answers
SOURCE: refrigerator warm on top, cold bottom, blower fan top of freezer not turning
check continuity thro the fan motor and check it is free to turn. also check if power is present at the fan
Posted on Oct 13, 2008
Maytag refrigerator not cold.
do you have a full frost pattern (coating) on freezer coils or see a ice ball, if ice ball Leak in system or bad valve in compressor. not worth fixing. go on (repair clinic .com).
you have a dampener and a fan to let the cold air go to all the areas check to make sure fan is running push in light switch in freezer and llisten for fan could be problem or no power to fan from main control board.
Dampener is flapper door that lets cold air from freezer go into ref. section
are your doors sealed, gaskets, frapper between door on ref section closing.
also your return air ducts need to be clear of ice, is your ice maker working that means that it is below 10 degees and repairable.
May 03, 2014 | Maytag (MFI2568AEW) Bottom Freezer French...
Kenmore refrigerator
If the compressor is running & the fans are working then it is probably a low gas problem, call a service man.
Nov 30, 2013 | Maytag MTF2155GRW Top Freezer Refrigerator
Maytag frig is plugged in and running but not getting cold. What may be the fix?
Is the compressor kicking on? By running do you mean the freezer fan is running?
Oct 21, 2012 | Maytag MFI2568AES Stainless Steel Bottom...
Maytag MTF1895AEW Not Cooling
Sounds to me the compressor start relay=> 63001003 Overload=> 63001004 and Run Capacitor=> 63001005
needs replaced, the clicking noise indicates that that is the problem, Sea Breeze
Feb 16, 2012 | Maytag Refrigerators
Fan motor run all time make bottom to freeze up
Which fan motor are you talking about? There are two fans, one that is under the cabinet that blows air over the condenser grill and compressor. The other one is normally in the freezer and is referred to as the evaporator fan, which forced cold air out of the freezer and into the refrigerator. This fan is normally controlled by the thermostat and coldness setting. So It could be either of these two that are keeping it running.
Jul 16, 2011 | Maytag 18.9 Cu. Ft. Top-Mount Refrigerator...
Freezer is cold but the refrigerator is not
Might something blocking the cold air which originates in the freezer. Too many grocery's will block the air. Check the fan motor up there. If it ain't running the cold air cannot get to the bottom. If the defrost heater died the ice would block the evaporator and cause problems too.
Here is a nice old school refrigerator training manual which illustrates these problems nicely:
ICE BOX TRAINING MANUAL
May 08, 2010 | Maytag MTB2156GES Top Freezer Refrigerator
It does not continuously run and it is not cold
These units are not repairable.(per Maytag) The entire unit must be replaced.(per Maytag)
May 26, 2009 | Maytag SkyBox MBV1976A Beverage Dispenser
Inside of refrigerator isn't cold and ice on top of freezer door
Is fan running in frzr? IF not, then it is bad and needs replacing. Common issue.
Nov 27, 2008 | Maytag 22.1 cu. ft. Bottom Freezer...
Maytag fridge not cold
IF THE COMPRESSOR IS COMING ON AND OFF IN A MATTER OF SECONDS, YOU MAY HAVE A BAD START DEVICE(RELAY) ON THE COMPRESSOR. IF THE COMPRESSOR RUNS FOR FIVE MINUTES OR MORE, CHECK THE FAN NEAR THE COMPRESSOR AND THE COILS
UNDER THE REFRIGERATOR. IF THINGS SEEM EXTREMELY
HOT, CLEAN THE COILS AND MAKE SURE THE FAN IS RUNNING. IF IT IS ALL O.K. YOU MAY HAVE A LEAK IN THE SEALED SYSTEM( TUBING WHERE THE FREON FLOWS).
THAT WOULD REQUIRE A CERTIFIED TECHNICIAN LICENSED TO HANDLE FREON TO MAKE REPAIRS.
Mar 27, 2008 | Maytag MTF2155GRQ Top Freezer Refrigerator
Warm fridge, cold freezer...
Listen for a fan running when you open the freezer door. May have to hold the light switch closed for it to come on. If you don't hear it then the fan is most likely bad. The evavorator fan motor is the most common repair on the trio's
Oct 06, 2007 | Maytag MFD2560HES Bottom Freezer French...
GE Profile Arctica Stainless Steel Top Freezer Refrigerator Logo
22 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
