Question about Premium HP PhotoSmart 5512 Ink Cartridge Black PhotoSmart 5512 - 6800 Page
Printer not printing black
Hp 4620
MY HPOFFICEJET ALL IN ONE SERIES 4620 WILL NOT PRINT IN BLACK WHEN YOU DO A ALIGNMENT PAGE THERES NO BLACK WRITING SO THE SCANNER SAYS COULD NOT DETECT ALIGNMENT PAGE ALIGNMENT FAILED WHAT CAN I DO NEW...
I have a 4620, and had the same thing occur with the black ink. After a few hours on the phone with HP and them sending me a replacement printer that also wouldn't print, I found that there is a "vent" on the printer cartridges that if clogged, will cause that color not to print. The vent is on the top of the cartridge, facing up when installed into the printer. The vent looks like a "T". Unfortunately, the packaging that HP uses on these cartridges sometimes causes glue to clogged the vent. Take a sharp nail or straight pin, and clean out the vent. Hope this is successful for you.
Aug 01, 2014 | HP Office Equipment & Supplies
Printer will not print black copies
When you choose print & pick your printer you can then press the option of properties. That will allow you to chnage to black only for printing
Jul 15, 2014 | HP Officejet 4620 e-All-in-One Printer,...
How do i remove the print head from hp office jet 4620
remove all the inks and look for a release lever might be grey in color or black lift the lever and remove/lift the print head assembly from printer... your inks sit directly on top of the print head assembly
May 03, 2014 | HP Officejet 4620 e-All-in-One Printer,...
WONT INSTALL
Might be CD fault., go to "hp.com"...support...download drivers... type UR product..select OS.. download full feature drivers. &..install....
Apr 04, 2014 | HP Officejet 4620 e-All-in-One Inkjet...
HP Officejet 4620 not printing even with full cartridges
the printer only follows instructions from the computer
If you get weird things , the driver is suspect for the printer
Jan 29, 2018 | HP Officejet 4620 Wireless Multifunction...
The scan of color document gives a black and white product
there some reasons :
1- Are you sure to select the copying color not black and white ?
2- try to reset color ink cartridge ,
3- try to select clean print head
i hope that was help you
Mohamed Hejazi
Afaqnama -Libya
ipg@hplibya.com
Mar 21, 2013 | HP Officejet 4620 e-All-in-One Printer,...
Hp 4620 printer doesn't print black ink
i have same problem and have tried everything suggested on HP website. I can print in color but not black and white
Nov 08, 2012 | HP Officejet 4620 All in One
Premium HP PhotoSmart 5512 Ink Cartridge Black PhotoSmart 5512 - 6800 Page Logo
Top Premium Photography Experts
pontelemon
pontelemon
Are you a Premium Photography Expert? Answer questions, earn points and help others
