Question about Lionel Crafts & Hobbies
Lionel instructions need diagram for hooking up #41 contactor track trip to gateman
  • 161 Answers
Posted on Oct 15, 2014
5 Suggested Answers
  • 6 Answers
SOURCE: i have a lionel legacy cab-2 remote i hooked up
just unplug the transformer from the grey box (the one with the green light and red light) and check the voltage. if it doesn't read anything, try unplugging the transformer from the outlet and plugging it back in again. if you get a reading, replug the transformer to the grey box and check the voltage of the silver screws (where you put the + and - wires from the track to) and try using the train again
Posted on Jan 11, 2011
SOURCE: need wire and hook-up diagrams for Lionel train
http://cs.trains.com/TRCCS/forums/t/195035.aspx
Posted on Aug 01, 2011
  • 34 Answers
SOURCE: CANNOT GET THE UNCOUPLING TRACK SECTION TO WORK
Track power is not recommended for this uncoupler. Use an aux fixed supply of at least 10 to 13VAC for the supply. You have to move a jumper on the bottom of the track to do this. Then there will be four wires needed. Two for the aux power (hot and common) and the other two which go to the pushbutton switch.
Note: Same goes for Lionel FasTrack Remote switches. Run the switches from a 10 to 12 VAC aux supply. There is a jumper you remove on the bottom of the switch to connect an aux supply.
Posted on Sep 05, 2011
residentoccu
  • 161 Answers
SOURCE: Need diagram for hooking up #252 Lionel Crossing Gate
Here's a link to the Service Manual to the 252 Crossing gate.
http://www.lionel.com/media/servicedocuments/71-2714-250.pdf
Posted on Feb 13, 2013
How to replace arm on Lionel 1054 gateman
If it is the 1045 flagman, you need a replacement arm with the attached flag. disconnect the man from the metal base and open the figure with the screws on his back. Disconnect old arm or whats left of it and reverse the process to re assemble. If you do not have a 1045C contactor, one side of a 154C will work
If it is the 145 gateman the arm has a screw or drive pun into the man's shoulder. If you can get a seperate arm this is the way to go. if not parts dealers will have the complete man. Open the base undo the screw that holds the man to the arm remove damaged man, Reverse process to reassemble
May 11, 2014 | Crafts & Hobbies
How to hook up lionel #41 to gateman and power supply
Here is the manual for the switcher. http://www.lionel.com/media/servicedocuments/71-8474-250.pdf
Here is a link for gatemen, select the one you have to find the manual.
http://www.lionel.com/Products/Finder/SearchResults.cfm?doAction=search&Keywords=gateman&CategoryID=39&Gauge=&RailLineID=&CatalogID=&CollectionID=&searchWithin=Current
Here is the link for power supplies.
http://www.lionel.com/Products/Finder/SearchResults.cfm?doAction=Browse&CategoryID=40.
Apr 16, 2014 | Crafts & Hobbies
Lionel toys
see attached pdf.
Jan 19, 2014 | Lionel Crafts & Hobbies
Dec 31, 2012 | Lionel O 27 252 Auto Crossing Gate
CANNOT GET THE UNCOUPLING TRACK SECTION TO WORK THRU TRACK POWER - WHAT IS PROPER WAY TO HOOK UP RED AND BLACK WIRES? LIONEL FASTRACK
Apr 27, 2011 | Lionel 12020 Fastrack Remote Uncoupling...
Is lionel 40 watt transformer from toy train enough power to run a dual motor larger train engine it just lites up and sputters
It would depend on what engine you're trying to run. The 40 watt transformer's circuit breaker will trip off if you put too large of an electrical load on it. If the engine light stays on while it sputters, the track or the engine's motor and electrical pick-ups may need cleaning. Older engines that haven't been run for a while can get stiff. Your engine may need some lubrication.
Jan 18, 2011 | Lionel 40 Watt Transformer Train Set Track...
Need lionel trains on track instruction manual for nintendo DS
I have uploaded the On Track manual to scribd.com.
Look here:
http://www.scribd.com/doc/76894727/Lionel-on-Track
or search for lionel_on_track.pdf
Nov 23, 2010 | Lionel Trains: On Track for DS
Ι've just joined 2 ovals 40x60 lionel fastrack, used some other items 2 Lionel 6-12018 FasTrack O-36 MANUAL SWITCH RH, 2 Lionel 6-12017 FasTrack O-36 Manual Switch LH, A few 6-12014...
It sounds as though you may have two defective transformers. Lionel has reported problems with some of their smaller transformers. I would have the transformers and the engines checked by a Lionel service station or contact their customer service department for help.
Nov 12, 2010 | Lionel 40 Watt Transformer Train Set Track...
I need schematic for 450 signal bridge
Each side of the 450 signal bridge has 3 connections....one common to both one lights green light the other the red You need to connect the red and green wires to a 153C contactor the pressure switch that changes the light colors as the train passes. The side of the 153C that has 2 terminals is for the red and green bulb wires. The single terminal and the third terminal on the 450 get connected to 12V fixed voltage. Repeat the process for the second track and contactor. This is the simple mode of wiring a signal bridge or any of the single change the color signals...153,163,353 and 452 single signal; bridge.
Feb 22, 2010 | Toys
Crafts & Hobbies Logo
226 people viewed this question
Top Lionel Crafts & Hobbies Experts
Tom Chichester
freddyfox
J.D. Browning
J.D. Browning
Are you a Lionel Craft and Hobby Expert? Answer questions, earn points and help others
