Question about RCA Ipod Tabletop Charger With Usb Port And Ac Outlet
Tabletop charger wont charge
I inserted iphone in well and it wont do anything will not charge
My I pad wont turn on
Make sure it is charged - us a different charger and cable if possible (remember iPad chargers are different to iPhone chargers).
If this doesn't help, reply with more detail.
Feb 21, 2015 | Apple iPad Tablets & eReaders
POLARIOD KIDZ TABLET 2WONT CHARGE
Make sure the tiny circuit board inside the charge port is not bent, otherwise the charger plug will not get inserted properly and get connected.
May 24, 2014 | Polaroid Tablets & eReaders
Charger broken
Go to ebay, type in the exact model of your tablet and search for the tablet, you can order one from there.
Feb 10, 2014 | RCA Ipod Tabletop Charger With Usb Port...
Charge broke where can i get another one
Go to ebay and type in the exact model of your tablet and search for it, you will find it.
My charge got broke can i use a regular usb charger
Press "Volume +" together with "Power on", during 8-10 seconds. Choose first line in menu.
Feb 08, 2014 | RCA Ipod Tabletop Charger With Usb Port...
My ipad mini is not charging fully when i plug it in it is usually charging up to 75%
Are you using the charger that came with it? The charger needs to be at least 10watts. A charger meant to charge iPhones or iPods will cause this kind of problem.
Jan 26, 2014 | Apple iPad Mini
My google nexus 7 wont turn on
Sorry to hear/read this.
First, try get a new charger and plug your Google nexus 7. Suspect a dead battery with no charge left on it.
Otherwise, confirm your charger isn't just lighting up whereas it isn't delivering any charge current to your device.
Next to try if your ac charger is confirmed good is to attempt replacing the battery; at the store, have them insert a compatible/similar battery and then try power on your device.
NOTE:
New batteries at the point of purchase have some charge on them; sufficient to power on your device.
Device not power on, DON'T PURCHASE NEW BATTERY. Obviously, you don't have a power/battery problem.
Device power on, then you either have a battery that has failed or that your device's charging port needs to be serviced or repaired.
Please post update/feedback asap. Thanks
Oct 10, 2017 | ASUS Google Nexus 7 Tablet
My apple ipad wont charge or turn on
With iPad Magic, you can transfer photos, videos, music, books, etc. between iPad, iTunes and computer at ease. Moreover, it also enables you to convert audio and video files, rip CD and DVD discs, download online videos, make ringtones and more. Also, it works well on iOS 7 and iTunes 11.
http://www.youtube.com/watch?v=8ALYybIAL3k
Supported iOS Devices:
iPad, iPad 2, The New iPad, iPad mini, iPad with Retina display;
iPhone 3G/3GS, iPhone 4/4S, iPhone 5, iPhone 5C, iPhone 5S
Apr 25, 2012 | Apple Tablets & eReaders
My coby kyros wont charge
Try plugging in your charger to a different outlet. If that doesn't do anything, there might be a problem with your charger or your USB port on the Tablet. May have to replace the charger.
Mar 07, 2011 | Coby Kyros 716829701508 Tablet PC
I got a ipad for christmas it was working great but now it wont charge anymore is it the charger or the ipad?
Most chances are the problem is the cable. You can try connecting the ipad to the pc, if you can connect then the problem is not the cable, but the charger.
You could try to use another cable from a friend with an ipad/ipod/iphone, just to be 100% sure.
Also try moving the cable around, the cable may be interrupted, it happened the same for me with my iphone.
Regards,
katharsys_i
Mar 03, 2011 | Apple iPad 16 GB 3G Tablet PC
RCA Ipod Tabletop Charger With Usb Port And Ac Outlet Logo
12 people viewed this question
Top RCA Tablets & eReaders Experts
Christoverre Kohler
Christoverre Kohler
Lawrence Thornton
Level 1 Expert
Are you a RCA Tablet and eReader Expert? Answer questions, earn points and help others
