Question about Sony MDR-RF960RK Consumer Headset
How to install wireless headphone model # AX-W026S
Can not connect to a laptop
Could be the laptop needs a driver installing for it to work.
Conventional bluetooth and wireless needs a 2-way signal so the item you want to connect will appear in the laptop wireless and bluetooth menus and you can click on it and enter a password or pin number.
If the headphones don't appear in the menus you won;t be able to connect them. In that case you should refer to the headphone instruction manual.
Apr 16, 2016 | Bluedio Model R - Wireless & Bluetooth...
Where is the serial number on tritton ax pro
Usually it's underneath the headset headband cushion, the one on top, you have to pull on it to the side to take it off.
If it's not there it will be underneath your decoder box.
Aug 15, 2014 | Tritton Triton Ax Pro Xbox 360, Ps3, Pc
Windows xp - ms bluetooth adapter dongle - motorola s305 headset
Headphones are a convenient way to experience audio-rich entertainment on your own terms. Headphones allow you to customize your listening level without disturbing other people in your general vicinity.
Headphone cables can be a hassle, however, so many new headphone models feature a wireless connection.
PCs tend to be wire jungles, so eliminating one wire from a potentially jumbled mess can be an intriguing feature of wireless headphones.
Connecting wireless headphones to your PC allows you to take advantage of the benefits of listening to your movies, music or games through headphones without the struggle of the headphone cable.
Charge up or place batteries in your headphones and transmitter.
Wireless headphones require power to function.
Many wireless headphones come with a charger base.
You need to charge your headphones before you attempt to connect them to your PC.
Some wireless headphone models require batteries, which you must install before you connect the headphones to the PC.
Connect the transmitter to your PC.
The transmitter may connect via the PC's headphone jack or USB port.
If the transmitter connects to the headphone jack, plug it in and check your headphone's user guide to verify how to synchronize the headphones to the transmitter.
If the transmitter connects via USB, you will likely need to install software to use your wireless headphones.
If your wireless headphones are Bluetooth-compatible, continue to the next step.
Pair your headphones via Bluetooth to your PC.
If your PC is not Bluetooth-equipped, you will need to install a Bluetooth USB dongle.
Turn on your headphones and open the Bluetooth software on your PC.
Scan for Bluetooth devices from your PC.
Your headphones should appear.
Select the headphones and follow any further instructions to complete the pairing process.
Test the headphones.
Pick out a song or a video and play it on your PC.
Connect your wireless headphones and verify that you can hear the audio.
Find the volume controls on your headphones and adjust them to make sure the volume changes correctly.
If your headphones are not functioning properly, verify that the headphones are turned on.
If the headphones are on and you do not hear anything, verify that your transmitter is functioning properly and that you have your volume turned up on your PC.
Recharge your headphones when you are finished using them.
To ensure that the headphones are ready anytime you need them, you must always place them on the charging base when you are finished using them.
If the headphones are battery-powered, be sure that you always have spare batteries on hand.
Jul 18, 2013 | Microsoft Bluetooth v2.0 USB Dongle...
My hed set not sapprt
Headphones are a convenient way to experience audio-rich entertainment on your own terms. Headphones allow you to customize your listening level without disturbing other people in your general vicinity. Headphone cables can be a hassle, however, so many new headphone models feature a wireless connection. PCs tend to be wire jungles, so eliminating one wire from a potentially jumbled mess can be an intriguing feature of wireless headphones. Connecting wireless headphones to your PC allows you to take advantage of the benefits of listening to your movies, music or games through headphones without the struggle of the headphone cable.
Charge up or place batteries in your headphones and transmitter. Wireless headphones require power to function. Many wireless headphones come with a charger base. You need to charge your headphones before you attempt to connect them to your PC. Some wireless headphone models require batteries, which you must install before you connect the headphones to the PC. Connect the transmitter to your PC. The transmitter may connect via the PC's headphone jack or USB port. If the transmitter connects to the headphone jack, plug it in and check your headphone's user guide to verify how to synchronize the headphones to the transmitter. If the transmitter connects via USB, you will likely need to install software to use your wireless headphones. If your wireless headphones are Bluetooth-compatible, continue to the next step. Pair your headphones via Bluetooth to your PC. If your PC is not Bluetooth-equipped, you will need to install a Bluetooth USB dongle. Turn on your headphones and open the Bluetooth software on your PC. Scan for Bluetooth devices from your PC. Your headphones should appear. Select the headphones and follow any further instructions to complete the pairing process. Test the headphones. Pick out a song or a video and play it on your PC. Connect your wireless headphones and verify that you can hear the audio. Find the volume controls on your headphones and adjust them to make sure the volume changes correctly. If your headphones are not functioning properly, verify that the headphones are turned on. If the headphones are on and you do not hear anything, verify that your transmitter is functioning properly and that you have your volume turned up on your PC. Recharge your headphones when you are finished using them. To ensure that the headphones are ready anytime you need them, you must always place them on the charging base when you are finished using them. If the headphones are battery-powered, be sure that you always have spare batteries on hand. Hope this helps.
Dec 20, 2012 | Computers & Internet
Need wireless adapter for Acer AX- 1430-EF30P
Come the case see if there is PCI slot in your Computer. As per my knowledge there is Two PCI slot in your computer which means you can add any PCI device, It can be PCI Wireless Adapter also.
Aug 17, 2012 | Acer Aspire X1 Ax-1430g-uw30p Slimline...
How to install rca wireless headphones to hdtv. And it is posible that i can hear the tv at the same time that i use the wireless headphone.
The answers would depend on the specific models. And manuals explain it. Try web searching the exact products followed by 'manual'.
Aug 08, 2011 | Audio Players & Recorders
Model No. TH-42PD50U can you hook ext speaker or wireless headphones?
Yes,if want to hook up ext.speakers.Buy the BOSE system,the best system out there so far.Wireless headphones.Buy the wireless headphone system.Plug in the remote stick to the HDMI hub and u have a wireless headphone.
Apr 28, 2010 | Panasonic TH-42PD50U 42 in. Plasma EDTV
Sony MDR-RF960RK Consumer Headset Logo
Top Sony Radio Communications Experts
 Grubhead
Grubhead
basssplayer
Level 1 Expert
Piyal Perera
Piyal Perera
Are you a Sony Radio Communication Expert? Answer questions, earn points and help others
