Code identification I have a chevy small blok Gm 5.7 lg,shI whit this code K0901XKA what is this?
Chevy engine block identification numbers V0710FSC TEJ528846
Small Block Chevy Engine Block casting and code identification
www.nastyz28.com/sbchevy/sblock.html
Sep 14, 2012 - Small Block Chevy engine identification. Code identification, Casting Number info.
Chevy Casting Number identification - Block casting numbers
outintheshop.com/faq/casting/castings2.html Chevy Casting Number identification including Block casting numbers, cylinder ... 2-bolt Chevy II Nova Recessed filter .... 2 & 4-Bolt Mexico cast Crate engine.
Reference: Chevy Engine Block Casting Numbers - Chevy ********
www.chevyhardcore.com/news/reference-chevy-engine-block-casting-numbers/ Sep 19, 2013 - The engine block casting number for both BBC and SBC engines is found at the back of the block where the transmission mounts to the engine.
Chevy Identification Numbers - 73-87.com
www.73-87.com/chevy_ids/sbcid2.htm If you have a small block Chevy engine, and need to identify any parts you have laying around, or maybe the engine that is in your truck, I think you will find the ...
Chevrolet - Browse - Casting Numbers .info: engine blocks, heads ...
www.castingnumbers.info/site/browse/m/chevrolet 12562932, Category: Cylinder Heads Type: Big Block V8 Date: 1991-1995. Notes: oval port, open chamber, Gen.V, truck crate motor, 118cc chambers gm chevy ...
http://outintheshop.com/faq/casting/castings2.html
Jul 04, 2017 | Cars & Trucks
I hav a 2004 Chevy Colorado 4x4 ext cab 5 cylinder. I put in an aftermarket stereo and viper alarm no problems.. then put in an amp. Now it won't turn over. The lights come on but when u turn key dead
So , what did you do about the class 2 serial data bus ? Do you know what that is ? And it is suppose to be hooked up too the radio . With aftermarket stereo's on GM vehicle you need to use a interface module . ! Have it check for DTC'S - diagnostic trouble codes , you will probably find a U - code , communication network failure .
Each module connected to the class 2 serial data circuit monitors serial data communication during normal vehicle operation. Operating parameters and other information are exchanged among the modules. When a module receives a message that contains a critical operating parameter, the module records the identification number of the module which sent the message. If a module does not associate an identification number with every critical parameter within 5 seconds of beginning serial data communication, DTC U1000 or U1255 will set.
Something on the bus is not letting normal communications happen .
Jan 21, 2017 | 2004 Chevrolet Colorado
07 Chevy express when blower motor is in operation with highest setting, ABS and parking brake light's come on with ringing tone Code U1041 showed up on obd scanner What is possible cause? Thanks
Sounds like a network communication issue.
Modules connected to the class 2 serial data circuit monitor for serial data communications during normal vehicle operation. Operating information and commands are exchanged among the modules. When a module receives a message for a critical operating parameter, the module records the identification number of the module which sent the message for state of health monitoring/node alive messages. A critical operating parameter is one which, when not received, requires that the module use a default value for that parameter. Once an identification number is learned by a module, it will monitor for that modules node alive message. Each module on the class 2 serial data circuit is required to send a Node Alive message every 2 seconds . When no message is detected from a learned identification number for 5 seconds , a DTC U1???.
??? is equal to the 3 digit identification number of the module. Control Module ID = BCM
I would start checking ALL ground wires/straps on this vehicle. That has been a problem with GM. Try clearing the code and see if it comes back after you clean ground connections.
Dec 30, 2015 | Cars & Trucks
Was there a recall on the brake boosters in 2008 Saturn Vue XE
If you call the service department at your local chevy/gmc dealer and give them your Vehicle Identification Number, they can tell you if there was a recall on your specific vehicle. Many recalls had VIN breaks where only certain number ranges were recalled. It's always safer to call the GM dealer.
May 04, 2014 | 2008 Saturn VUE
Alarm activated and is unable to deactivate
REMOTE KEY INITIALIZATION For this type of key.
The initialisation of the FZV keys is required to establish the Lock/Unlock signal synchronisation with the GM V. The initialization procedure provides the GM with a key identification number and a "rolling code" for each key. If the initialisation is not performed, the GM will not respond to the key signals. Up to 4 remote keys can be initialised. They must be initialised at the same time. Key initialisation is only possible with the vehicle unlocked.
Procedure:
1. Close all doors and have all keys available.
2. Using key number 1, turn the ignition switch to KL R, then switch off within 5 seconds and remove the first key.
3. Within 30 seconds of turning the ignition switch to "off" Press and hold button #2 .
4. While holding button #2 , press and release ("tap") button #1 three times within 10 seconds.
5. Release both buttons. The LED in the key will flash momentarily. The GM will immediately lock and unlock the doors signalling a successful initialisation.
6. If additional keys need to be initialised repeat steps 3 - 5 within 30 seconds.
7. Switching the ignition to KL R completes the initialisation.
SERVICE NOTE:
The key memory function of the GM responds to the key identification number of each key. If the keys are not initialised in the same order prior to initialisation, the key memory functions activated by the keys will not be assigned correctly. Always initialise the keys in the same order.
REMOTE KEY INITIALISATION For this type of key.
The initialisation of the FZV keys is required to establish the Lock/Unlock signal synchronisation with the GM. The initialisation procedure provides the GM with a key identification number and a "rolling code" for each key. If the initialisation is not performed, the GM will not respond to the key signals. Up to 4 remote keys can be initialised. They must be initialised at the same time. Key initialisation is only possible with the vehicle unlocked.
Procedure:
3. Within 30 seconds of turning the ignition switch to "off" Press and hold the arrow button.
4. While holding the arrow button, press and release ("tap") the roundel button three times within 10 seconds.
5. Release both buttons. The GM will immediately lock and unlock the doors signalling a successful initialisation.
SERVICE NOTE:
The key memory function of the GM responds to the key identification number of each key. If the keys are not initialised in the same order prior to initialisation, the key memory function activated by the keys will not be assigned correctly. Always initialise the keys in the same order.
Apr 08, 2014 | 1996 BMW 540i
How i know what type engine my chevy cobalt has???
Normal 0 Vehicle Identification Numbers (VIN codes)/GM/VIN Codes
GM has traditionally encoded the platform as the fourth character of the VIN. Other content includes an engine code the eight character, model year 10 th character and so on.
Take note of the eight character and call a GM dealer.
Aug 14, 2010 | 2006 Chevrolet Cobalt
Need code for radio anti-theft system.for a 2001 chevy silverado
You would need to go to a Chevy dealer to have to codes burned in to the vehicles computer. The reason why GM had done this was to deter theft of radios from their vehicles. The radio must have the VIN (vehicle identification number) burned into the chip to match the VIN on your vehicle so it will play
Jan 27, 2010 | 2001 Chevrolet Silverado 2500HD
Computers & Internet Logo
David Payne
David Payne
