Question about Lorenz Perko BATTERY SWITCH CABLE SPACER 0462DP0RED
I have a dead short on my boat what should i test firsst
  • 5,687 Answers
First try to use a continuity tester (ohm meter). You take both wires off the battery and connect the ohmmeter to both battery cables. Again no power from any battery. When the positive and negative cables are connected by this meter the meter should not show connection. Positive and negative are separate and whatever is shorted out is connecting them. Everything should be off. When you pull each fuse till you break the connection you will have found the problem.
Posted on Jun 18, 2009
My boat has a 50 amp thermal circuit breaker that won't reset
dead short after the thermal breaker
faulty thermal breaker --replace it
May 13, 2018 | Electrical Supplies
Raymarine dsm300 Circuit breaker keeps tripping g when connected to chartplotter
either the cord to the chart plotter is faulty or the chart plotter itself is dead short
have an electrician do an insulation test and circuit test on the cord and plotter unit
Jan 08, 2017 | Raymarine Boating
Wireing problems
you wired to a dead short
recheck how you did the wiring
Oct 13, 2015 | Boating
Fuse keeps blowing in engine
check for a dead short in the wiring from the key to the starter
probably corroded connection in the line
Jul 05, 2015 | Boating
I have a 1980 Thompson Vacationer Express boat with an OMC 260 engine. No crank, no start, no accessories work. Turn key and nothing..no click or anything. No indicator lights come on.
have a load test done on the battery as it may be flat or have dead cell. Check and clean the battery terminals and battery posts (shiny clean ) as the moisture around boats causes lead sulphate to build up on the terminals which prevents current flow ( black coating)
Oct 28, 2013 | 1994 Volkswagen Jetta
Boat motor won't start. battery fully charged
I would have the battery tested anyway to make sure you don't have a dead cell. Usually even with a weak battery the starter will try to engage the flywheel on top of the motor.Besides the battery check the fuse located on the motor. If all is good then you can remove the starter for testing and possible rebuilding.
Jul 07, 2012 | Nitro Boating
Every time I turn on my viper mk3 the fuse blows! Does anyone know the problem?
You need to disconnect the batteries and start using an Ohmmeter to test for a short. If you have wired the boat and run a connector for this unit, you need to find out if the boat wiring is blowing the fuse or the motor is.
You may have problems finding the specs you need for the Resistence that is built into the motor. But you should have little problems in finding if you have continuity in any wires leading to the electric motor. Even if this is a jumper cable wired motor, you may have set the weight of the motor on top of the wiring and pinched the wires creating a dead short.
Jan 22, 2012 | Boating
New battery just put boat in water always had a solar powered charger on battery took it off about a week ago today went to start boat battery dead. I do not know if it has altanator or what have a friend...
You will need to do 3 tests:
1 - you must find out if you have a short in the wiring: disconnect the + cable from the battery and put an ampermeter in there to close the circuit; if a current is detected it means that you have a short and it will drain the battery. To locate the short start disconnecting wires and look at the meter - when you will disconnect the wire that goes to the failed wire or part the current will stop flowing; find the faulty part and fix or replace it.
2 - you must find out if the alternator is charging the battery correctly: start the motor, wait for half an hour then measure the voltage on the battery. If it's below 14.1 volts then the alternator is failing and it will have to be replaced.
3 - you must find out if the battery is in good working order: after the second test has finished shut down the engine and disconnect the battery; wait one hour and measure it -if the voltage on it has dropped to below 11.8 volts then the battery has aged and it's no longer holding the charge so replace it.
Jun 06, 2011 | Sport & Outdoor - Others
Yamaha 70 took on water. Drained everything and it ran fine in the yard. But now, even on a charger it won't turn over enough to start.
test your battery it should have no less than 12.5 volts un hooked and when the motor is running you should have no less than 13.5 volts if not then u have a bad regulator recitfier if both are good then you have a dead short and i would install a battery cut off switch to your main power
Jul 22, 2009 | Light Outboard Motor Boat Bass Fishing...
I have a 2000 5.7 efi with bravo3. It seems to have a dead miss maybe one cinlinder. Changed plugs and tested for fire on each.(good)Checked injectors and they are working fine except one side seems to...
This sounds like you should ask several boat repair shops if they have a tester for the TBI module. By the flow you suspect the TBI is not regulating correctly and with a fuse blowing intermittingly it indicates grounding somewhere. You might do a close inspection of the injector wires and unwrap their wiring loom to see if there is evidence of shorting.
If there is slack in the TBI loom try a wiggle test with the engine running to see if miss changes.
Jul 12, 2009 | Boating
Lorenz Perko BATTERY SWITCH CABLE SPACER 0462DP0RED Logo
117 people viewed this question
Top Lorenz Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you a Lorenz Electrical Supply Expert? Answer questions, earn points and help others
