The tuner is not working on my lg tv
Neither the hdmi ports nor the tv tuner are working on my LG flat screen tv
SOURCE: LG t.v is saying no signal on the screen for the cable box and a dvd player.
if the sky box is not registered with your viewing card, it will not show. if you want to check that the monitor is working plug in a dvd to make sure its not the monitor that is at fault.
Posted on Oct 17, 2007
  • 92 Answers
SOURCE: LG 42LC2DB LCD TV Flickers when Ps3 is connected via HDMI port
Make sure you have the PS3 set to the correct frequency for the TV. Many cannot accept 1080p / 24fps etc.
Try different settings.
I hope this helps.
Posted on Mar 28, 2009
  • 4 Answers
SOURCE: LG flat screen TV speakers make a vibrating noise
I have this problem with my 37LG30.
They all seem to have the same factory flaw.
The plastic bezel and rear is vibrating against itself I have found.
Tonight, just now, I just took all the front bezel screws out,(from the back) loosened the other 4 big screws in the rear center(I don't recommend removing them)and loosened the stand screws also and tried separating the bezel from the back as I went around the set. This did not really help much except around the bottom where the noise/vibrating comes from-the speaker area.
The two plastic pieces are vibrating against one another.
The vibrating was coming from the speaker area without doubt.
The next thing was to try separating at the bottom where the speakers are with my fingers and a stiff metal nail file carefully..fingers seemed to work best for me.
As I separated the front bezel from the rear housing (at the speaker location)most if not all the buzzing/vibrating /distortion went away.
I then inserted small pieces of cotton (you can use felt, or similar I suppose) and buttoned it all back up;put the screws in
Almost all the distortion and speaker buzz/vibratingis gone except on very low frequencies.
good luck!
Posted on Apr 16, 2009
  • 458 Answers
SOURCE: LG 37LG30 HDMI no sound problem
This is more probably a software fault within the TV. They need instructions for HDMI inputs & a no sound is a related fault. I would get in touch with your dealer to arrange the TV to be updated to cure this problem. Hope this helps.
Posted on Apr 18, 2009
SOURCE: installing a LG Network Blu-ray Disc/DVD Home
YOU NEED TO CONNECT OPTICAL CABLE (NOT INCLUDED) TO OPTICAL1 CONNECTION ON YOUR HB405 AND OPTICAL OUT OF YOUR TV. IF YOU ALREADY HAVE DONE THAT TRY PRESSING SIMPLINK BUTTON ON YOUR TV REMOTE NAD CHANGE THE SPEAKER OUTPOUT FROM TV TO HT(HOME THEATER).
Posted on Oct 03, 2010
How can I connect my TV to a Dell laptop via HDMI?
if oyur LG tv has multiple HDMI ports, then you might need to choose the correct HDMI port from the 'INPUT' menu. Does the HDMI port on TV (sidepanel / back) has a sticker which denotes the number? if yes, then on tv remote, choose INPUT /SOURCE menu, it will show TV, Component, RGB, HDMI1 , HDMI2, HDM3, etc (depending your tv model, these options might vary) and choose the port number which you plugged the HDMI into. if you do not have a number on the port, then you might need to select each HDMI from "INPUT' menu and wait for a couple of seconds.
Sep 01, 2015 | LG Televison & Video
How do I hook up lg tv to lg dvd to sound bar then to dish
LG TV - LG Blu-Ray = HDMI (any except 1 if using below)
LG TV - Sound bar = Digital Optical Audio or HDMI 1 or Headphone (depending on your TV Audio out ports.)
LG TV - Dish STB = HDMI
Dec 27, 2014 | LG Televison & Video
LG Tv M227WDL HDMI black screen
If the HDMI input is failing you will need to ring Customer Support or Get a New TV because if its not outputting then The HDMI may not get Prosecced (sorry about spelling) And make sure you have checked its the Correct port and that there is no Blue-Tac or dust in the port ( that ussually solves this) If all else fails Use a Hairdyer and give it a Big clean :D
Mar 14, 2014 | Televison & Video
Panasonic LG plasma no audio on hdmi 1
HDMI cord may be faulty. Try the cord that works on the port that doesn't If it works then the HDMI cord is bad. If it doesn't work then the HDMI port may be bad on the TV.
Dec 29, 2012 | LG 42PC3RA 42 in. HD-Ready Plasma TV
The lg 42 in tv indicates invalid format when I connect the hdmi cable but the first time I connected it was working fine I moved it to another lg tv and it works fine
Tries tv unplug,replug tv it back like about an hour later.By letting tv resetting iself back to the factoty setting.Goto Menu goto PICTURE go down to resetting to reset the whole tv tuner signal board back to factory.That HDMI port should work again now,If not that HDMI port is shorted and dead sorry.
Jan 05, 2011 | LG 32LC7D Television
I have an LG 47" TV (47LG50) that I bought a year and a half ago. It worked great up until now. I have three seperate HDMI ports (PS3, Cable and Blu-Ray.) It all off a sudden says "no signal" to all...
Tries reset the tv and cable box,by unplug,replug both devices about an hour later.Let the cable boot up and update it softwares.Goto tv Menu goto PICTURE,go down to reset.The Tuner board it reseting to the Factory setting.The HDMI hubs,should all works now.Not than,the tv Tuner board have problems,must be change.Tries Shopjimmy.com,Ebay.com to buy a refurbish a Tuner board for the replacement.
Jul 15, 2010 | LG 47LG50 47 in. LCD HDTV
Hdmi port 1
No,Unplug,replug the tv about an hour later.Go to the tv menu go to PICTURE.Go down to reset,the Tuner board will return back factory setting.All ur HDMI ports will work again,not than ur tv Tuner board have that HDMI port 1 is shorted and dead.Fixing cost known,must call the yellow pages tv shops dicuss the problems and get the estamate.
May 24, 2010 | LG 42LC2D 42 in. LCD HDTV
LG LCD TV HDMI port not working
Have you tried rebooting the tv with the laptop on so that it can possibly detect the laptop?
Mar 23, 2010 | LG 42LC2D 42 in. LCD HDTV
Televison & Video Logo
50 people viewed this question
Top Televison & Video Experts
Electro Med Services...
