Question about Teac Audio Players & Recorders
How to play a mp3 cd on Teac PC-D895M CD player
My player will not play the mp3 cd
stoodleysnow
SOURCE: Every CD is skipping
If the cleaning cd does not work, try unplugging the player, taking the back cover off and manually cleaning the lens with cotton wool or cotton buds. If there is a stubborn smear on the lens, try methylated spirits on the cotton wool. Please note the following: Don't lose any screws You may need to take additional pieces of metal or plastic off to get at the lens; do not lose these or the screws that hold them and make sure they go back in the right order DO NOT TOUCH THE LENS WITH YOUR HANDS OR ANYTHING NOT CONSISTING OF COTTON WOOL OR METHYLATED SPIRITS! The lens will be quite fragile-do not apply excessive pressure Ensure everything goes back together the way it was, minus dust and dirt. hope this helps. stoodleysnow P.S. You can get methylated spirits at a local hardware or diy shop, or occasionally art shop.
Posted on Aug 30, 2006
shanth
  • 108 Answers
SOURCE: CD player will not play CDs
1.Check whether your cd s are good and readable
2.then the problem with the cd player laser beam reading assembly and its associating blocks
3. i guess your cd player laser beam lens is too weak or dead.
4. There is possible to change the lens system with a new one
5.Contact service centre for further rectification
Posted on Dec 22, 2007
VOTIT
  • 2071 Answers
SOURCE: CD player won't play disk and says "no disk"
The problem of "'no discs'"displayed is in the mechanism in the roller thats moving back and port bringing the lense set .The old grease thier is already hardened that cause the problem.Clean that by using a lighter fluid or like that fluid to take the old grease,and put it with a new one first class grease type-A grease put only a little grease and wipe the lense with a cotton buds without any chemicals on it .Try this solution so performance will be better.
Posted on Jun 18, 2008
  • 65 Answers
SOURCE: Teac CR H100 CD player just clicks when I press
it sounds like it is the motor that spins the disk most likely not worth replacing unless the unit has high sentimental value to you
Posted on Sep 23, 2010
  • 99 Answers
SOURCE: TEAC CD P1120 wont play
replace the loading tray belt as this also lifts the laser mechanism up to the level of the disc once loaded.
the humming sound you hear will be the motor trying to lift the mechanism up to read the disc but can't because the belt has lost its tension and is slipping.
Posted on Sep 24, 2010
The CD-P1250 skips while playing cds
There is no easy answer to this. I know that I have problems when I burn CDs in any format using my computers DVD burner. Fortunately I also have a regular CD burner which seems to do a much better job.
It may also be the CD player needs to be cleaned, seems that MP3 capable CD players are more sensitive when playing MP3 discs as opposed to regular CDs. There is really no other format that is widely supported (other than WMA) that will give you the capacity of a MP3.
May 24, 2010 | Teac CD-P1250 CD Player
Why does Burn't Audio CD not play on some CD Players
because the codec's are different, if you have ever burned a avi file and it didnt play till you added say divx ir xivd to get it to play tech leaves out alot of the codec's so there system will work on most but not all cd's dvd's the only way around it is to find out which codec will work for that player to test what I have just told you take the cd to the store and try it on a different mechine and see if it works
Jan 14, 2010 | Teac AD-600 3-Disc CD Changer
Will the CD x60i operate using a sansa mp3 player or only apple i-pods
Yes, but only by using the auxiliary input in the back. You can't charge the Sansa or control it with the TEAC remote like you can with the iPod, but you can listen to the music on the Sansa.
Nov 13, 2009 | Teac CD-X6 CD Player
My teac dvd/cd player wont play some cds
Probably a codec problem on the notebook. rather than a drive problem. Try a 3rd party media player such as Real Player or Quicktime
Feb 15, 2009 | Teac CD-Rewritable W28E CD-RW Burner
Teac cd-x10
try to play a cd I get an error message stating that it detects no cd.
Jul 12, 2008 | Teac CD-X10i Docking Station for Apple...
Trying to finalize a cd
Hi, This is just a guess but it may be worth a try. I have heard that Audio CD-Rs, which are the only media this machine will record onto, are famous for being finicky about being played on different kinds of CD readers. My suggestion is that you "rip" the Audio CD-R's content to your computer (in .wav or .MP3 format) and then make a copy of your album onto a reagular CD-R which is more likely to be played on any CD reader. Not sure if this'll work for you but it's worth a shot. Hope this helps.
Jul 31, 2007 | Teac GF-350 CD Shelf System
Top Teac Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Teac Audio Player and Recorder Expert? Answer questions, earn points and help others
