Question about Electrolux 24 in. EDW5505EPS Stainless Steel Built-in Dishwasher
Leak detector light temains on
Have drained all the water and checked for any other leaks. The display panel continues to flash. How do I reset the display panel and turn off the leak detection light
4 Suggested Answers
SOURCE: error code 01 on elecrolux dishwasher EIDW6305GSI
Usually the error code 01 means you backed up water in the unit. First be sure that the drain is clear.  Run the garbage disposal and be sure your sinks are draining.
I got lucky on a EIDW6105 unit by trying this.
All the lights are flashing and it shows error code 01.
Push down on two of the buttons and hold (I pushed on the Favorite and Heavy buttons), until the flashing stops (about 8 seconds).
The machine now showed and error code 08.  Then hit the start button.  My washer then cleared and runs normally.
Hope this helps, better than a sevice call to clear the code.
Posted on Dec 28, 2008
tattootech2
  • 72 Answers
SOURCE: ewdw6505gso electrolux. error 1. have turned off
the water will have leaked into the drip pan underneath, which is installed to protect your floors. Unfortunately, only way to get at it is to pull out dishwasher and remove 3 phillips screws that hold it on. In order to repair leaks, Electrolux came out with a "leak kit", which is part number 154769101. Comes with all parts that they had leak issues with
Posted on Apr 07, 2010
  • 70 Answers
SOURCE: ER 01 error, leak detected,
Hi, there is water lodged in the bottom pan of the unit. (Unit has to be pulled out to get to the pan.) Am thinking that the back legs of the dishwasher is too high and water is unable to drain out properly. So lower the legs and pull the dishwasher out in about 2 months to check for water in the pan.
That will solve the problem....
Posted on Jun 28, 2011
How do i reset a Samsung DW80F800UWS with display showing "LE"
Oh, that stands for Leaking - Samsungs have a plastic bottom that catches leaked water which activates a leak detector, which puts up the LEakin message. Most often leaks occur around the drain pump or drain hose. To clear the error, you must remove the standing water under the leak detector; no key sequence will remove that error.
Jan 04, 2015 | Samsung DW80F800UWS/AA 24" Stainless Steel...
DISHWASHER DRAINS WHILE DOOR IS OPEN. HEAVY LIGHT IS ON BUT NO WATER
Apparently you have water down in the flood area of the dishwasher, where the leak detector is located. Pull the dishwasher out and remove the right-side panel. Pull the insulation up, and look inside with a bright flashlight. The leak detector is located on that side. Depending on the model, you may have to move the motor capacitor out of the way, or move the controller out of the way to be able to get to that area to dry up the water. But the question is, "Where did the water come from?" You may have a bad (leaky) main pump, a bad drain pump, or a crack or hole in one of the hoses (the drain hose is the most common).
Jul 29, 2014 | Samsung DMR78AHS Builtin Dishwasher
Kenmore dishwasher clean button constantly flashing ,washer has been unplugged ???maybe reset itself did not work. 2 yrs old
please follow this steps and fix it. God bless you
Heating Element
If lights are flashing on the control panel, the heating element might have burned out. The heating element heats the water up to operating temperature. After a set amount of time if the temperature isn't reached a light on the control panel might start flashing. The heating element can be checked for continuity with an Ohm meter.
Enter your model number to see parts for your dishwasher.
Help me find my model number
Heating Element Assembly
If lights are flashing on the control panel, the heating element assembly might have burned out. The heating element assembly heats the water up to operating temperature. After a set amount of time if the temperature isn't reached a light on the control panel might start flashing. The heating element assembly can be checked for continuity with an Ohm meter.
Check Fault Codes
If the display lights are flashing and there is an error code in the display window, check the wiring diagram and tech sheet in the dishwasher that will provide information on the fault.
Drain Pump
If lights are flashing on the control panel, the drain pump might not be working properly. For two-wire drain pump motors check them for continuity using an Ohm meter. If it's defective You'll need to replace it. Drain pumps are not repairable.
Touchpad and Control Panel
If the lights are flashing on the display the entire touchpad and control panel assembly might be defective. If the display works but the dishwasher functions are all out of synch, or some of the buttons don't respond properly the entire touchpad and control panel might need to be replaced.
Touchpad
If the display lights are flickering for no reason, the touchpad might need to be replaced. Sometimes when the touchpad is defective the display lights are flashing randomly.
Jul 09, 2013 | Dishwashers
Dishwasher Siemens /se64m359gb tap light comes on in red on main display,what does this mean?
Heating Element
Check Fault Codes
Drain Pump
Touchpad
Jul 08, 2013 | Dishwashers
G1022
Heating Element
Check Fault Codes
Drain Pump
Touchpad
Jun 13, 2013 | Miele Dishwashers
Flashing start light
see this causes and fix it. God bless you
Drain Pump If lights are flashing on the control panel, the drain pump might not be working properly. For two-wire drain pump motors check them for continuity using an Ohm meter. If it's defective YOU'LL need to replace it. Drain pumps are not repairable.
Heating Element If lights are flashing on the control panel, the heating element might have burned out. The heating element heats the water up to operating temperature. After a set amount of time if the temperature isn't reached a light on the control panel might start flashing. The heating element can be checked for continuity with an Ohm meter.
Heating Element Assembly If lights are flashing on the control panel, the heating element assembly might have burned out. The heating element assembly heats the water up to operating temperature. After a set amount of time if the temperature isn't reached a light on the control panel might start flashing. The heating element assembly can be checked for continuity with an Ohm meter.
Touchpad and Control Panel If the lights are flashing on the display the entire touchpad and control panel assembly might be defective. If the display works but the dishwasher functions are all out of synch, or some of the buttons don't respond properly the entire touchpad and control panel might need to be replaced
Touchpad If the display lights are flickering for no reason, the touchpad might need to be replaced. Sometimes when the touchpad is defective the display lights are flashing randomly.
Check Fault Codes If the display lights are flashing and there is an error code in the display window, check the Error Codes guide on our website to determine which component has failed or is failing
Oct 03, 2012 | Dishwashers
We have a whirlpool quiet partner iii. It was working fine and was opened mid cycle. Then it wouldnt drain. Then all the lights started blinking. At some point it drained the water out. We flipped the...
see this causes and fix it. God bles you
Touchpad and Control Panel If the lights are flashing on the display the entire touchpad and control panel assembly might be defective. If the display works but the dishwasher functions are all out of synch, or some of the buttons don't respond properly the entire touchpad and control panel might need to be replaced.
Oct 02, 2012 | Dishwashers
Selection Buttons on GE Cafe Dishwasher
Adg 3962 IX showing fault code f2 with flashing
The machine has a switch inside that activates when a set amount of water is loaded.
If this switch then breaks (switches off) during the wash the machine assumes that the water has leaked out.
Run it through a couple of washes, check for a leak and see how it goes.
Hopefully it will be fine.
F2 indicates a flooded base.
Press and hold the start button until the start light goes out. (This resets the appliance)
Select a new programme and try the machine again.
If it comes up with a fault F2, take the panel off below the door and check for water in the base.
Be careful when you take the panel off, the exposed edges are razor sharp.
Drain any water in the base, reset and try the machine again and watch for a leak through the inspection panel.
May 24, 2010 | Dishwashers
Indesit DV620 Dishwasher
You have a internal leak in the dishwasher...there is a safety float system in the base (below where you put the dishes in!) of the unit, which in the event of water in the base will stop the cycle and activate the drain pump continiously.... You will have to open the unit and find the leak. Don't know these models, but usually you have to remove side panels and front panel, drain water from the base and re-start....then check with flashlight where the leak is. Oshie
Jun 21, 2007 | Indesit 23 in. DV62 IX Built-in Dishwasher
Electrolux 24 in. EDW5505EPS Stainless Steel Built-in Dishwasher Logo
94 people viewed this question
Top Electrolux Dishwashers Experts
Mike
Starnley Johnwells
Starnley Johnwells
Are you an Electrolux Dishwasher Expert? Answer questions, earn points and help others
