Question about Air Tools & Compressors
Air compressor motor stalls under pressure
Bought a used electric Campbell Hausfeld air compressor, 1.5 HP 11 gal "Super Pal" model LT500800, used very little recent years. Will start from 0 psi and go to 90 psi auto shutoff, but sometimes only to 80 psi and then stalls (hums). Tries to restart (hums) at kick on pressure, but won't run unless psi is about 15. Same results in two different garages.
  • zauggs Jun 24, 2009
    Thanks for your reply. It turned out to be burned contacts in the pressure switch, so the motor wasn't getting full current and didn't have the umpf to start when there was pressure in the tank. The unloader valve was working OK. When starting at 0 psi, in could maintain enough momentum to reach shut off pressure. thanks again!
    Habit-Forming:
  • 174 Answers
This sounds like a bad pressure switch.if the unit is not shutting off at the same pressure each time this would be the cause.2 if the pressure is not unloading the air pressure on the compressor side of the unit it will cause the unit to struggle when it starts a cycle because the piston is under a load .how this works is say the unit starts from 0 psi when it get to the desired pressure you have it set on the unit kicks off . the other adjustment most units have on them is what pressure to cycle back on.so when the unit reaches say 100 pounds ,it kicks off and bleeds the air off the compressor side so when it starts back up it wont start up with pressure on the piston.
Posted on Jun 22, 2009
Name: Campbell Hausfeld S/N: 0519588 Year: 1996 3.5 HP 11 Gallon Do you carry parts for the compressor described above ? In particular a Conrad Kit
No
This is not a business
It is a social web site,
we are at home
Use the Cambell Web site
You can buy directly from them
Mar 15, 2011 | Campbell Hausfeld NoEX8300 5HP 20GAL Hd...
Compressor trips breaker on re-load
if it has been an on going problem i would suspect that your power cord is too small,try a outlet closer to the breaker system.or get a bigger cord if one is used.is it maintaining pressure in the tank?if not a check valve is defective,you should hear air leaking if this is the case.let us know.
Mar 21, 2010 | Campbell Hausfeld Air Tools & Compressors
Need new pressure regulator for Campbell Hausfeld
their web site is chpower.com can order on line if not to old can check warranties also they can direct u to service location in ur area
Feb 01, 2010 | Campbell Hausfeld Air Tools & Compressors
Air Tools & Compressors Logo
1,214 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
