Question about KitchenAid KP2671 Professional 6 Series Stand Mixer
Show beater types - KitchenAid KP2671 Professional 6 Series Stand Mixer
How do I keep beaters in mixer without them falling out?
Each beater may be shaped differently and only will click into its appointed port. There may be a picture on the mixer showing which side to put each beater.
May 12, 2014 | Black & Decker MX55 PowerPro Hand Mixer
Beater is hitting bowl
You can find the User's Manual (which shows how to adjust beater-bowl clearance) for your model at:
https://www.kitchenaid.com/customer-service/manuals/
Apr 22, 2014 | KitchenAid KITCHEN AID 5 Quart Artisan...
Just replaced planetary and gears, flat beater still heating bowl. is planetary to be loose or fit tight against mixer head?
The beater cannot "heat" the bowl, so I am going to assume that is a typing error, and you meant hitting.
If the beater hits the bowl it is usually caused by the adjusting screw at rear of the column being improperly set. To correct this you need to turn the adjusting screw slightly to right, or left to adjust clearance. Clearance should be 1/16", about the thickness of a dime.
If this does not fix the problem, and the beater still rubs the bottom of the bowl, it can be corrected by tapping the yoke arm with a mallet, there should be 1/16" clearance between bottom of bowl and end of the beater.
You can determine the 1/16" by dropping a dime in the bowl, the flat beater should just "touch" the coin as the beater rotates.
If you have questions feel free to call us @ the Mending Shed.
Thank you,
Colleen
Customer Service
MendingShed.com
800-339-9297
Apr 30, 2013 | KitchenAid KP2671 Professional 6 Series...
Beater hits bowl beater height adjustment screw does not fix problem
Is this a new beater that you just bought? Or is it the same beater you have had? When you adjust the screw, which way are you turning the screw, how much is it hitting the bowl?
If the beater is too close to the bowl the adjustment screw should be turned in. If the threads on the screw are loose the screw needs to be replaced.
Page 17 and 21 both show how to adjust the head of the mixer so the beater his the bowl correctly. Here is a link to the service manual: http://lib.store.yahoo.net/lib/mendingshed/kitchenaidservicemanual.pdf
Please let me know if you have any questions.
Thank you,
Colleen
Customer Service
MendingShed.com
customerservice@mendingshed.com
800-339-9297
Apr 14, 2013 | KitchenAid Artisan Series Tilt-Head Stand...
Need beaters for a black and decker SM100 mixer
I searched for replacement beaters for Blacker & Decker SM-100 type 1 (SM100) electric stand mixer for years. I found the Sunbeam Mixmaster Mixer Replacement Beaters for stand mixers, item 4955, at a large Ace hardware store. They were priced over $16.00, so you may consider buying a new stand mixer. The beaters are the correct length, snap in and grip correctly even though the ends are curved like a half ball rather than flat as the originals. The beaters turns well but I haven't tested them with the bowl because I need to find the turn table that I have in storage. The beater set was design ed to replace parts for Sunbeam stand models 2355-1, 2356-1 and 2360-2.
Jan 18, 2012 | Black & Decker Food Mixers
I have a new sunbeam mixmaster 2594 and can not remember where I put the user's guide. There are two different shaped mixers and I don't know which goes where.
Hello Hdjohnston! If I were you I would call Sunbeam's Customer service number
Or email them and ask for a replacement user's guide (aka manual). This shouldn't be a problem as I've gotten replacement guides for other things before with no trouble :) Better yet, here's a link to get you your manual from Sunbeam's official website:
http://www.sunbeam.com/InstructionManuals.aspx?section=
Also, if you sunbeam mixmaster is like mine, it you look at the holes where the beaters are inserted it shows little symbols of beaters (one with for example a square top and the other with a more curved top) which lets you know which type of beaters goes in where!
Hope this helps! Kat
Nov 14, 2009 | Sunbeam 2370 MixMaster Series Stand Mixer
I need replacement beaters for an old GE hand mixer.
I bought an old GM mixer no. 30M47 with no beaters yesterday at the Salvation Army store. The beaters I have for a newish (ugly) GE hand held beater fit perfectly. I suggest taking your old beater to a store that sells new GE handheld beaters and seeing if the new beaters fit. If anyone reads this and wants me to look up the number of the new ugly beater for them, please say so before I take it to the Salvation Army.. : )
Oct 21, 2009 | Black & Decker MX55 PowerPro Hand Mixer
My beaters are starting to peel the silver covering
at this point it is best to get a new set of beaters ---- get the stainless steel ones instead of the plated type
Aug 12, 2009 | Food Mixers
KitchenAid KP2671 Professional 6 Series Stand Mixer Logo
Top KitchenAid Food Mixers Experts
Appliance engineer
Henry  Thomas
Henry Thomas
Colin Stickland
Colin Stickland
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
