Question about ASUS U46E-BAL7 14in Laptop i7 2.8GHz 8GB 750GB DVDRW
Overclock asus u46e-bal7 - ASUS U46E-BAL7 14in Laptop i7 2.8GHz 8GB 750GB DVDRW
No usb boot setting in available in Asus laptop aptio utility version 2.01.1
You can't because the usb root hub won't work until the PC boots. You'll never get the pc to boot from the usb drive with that bios version.
Nov 15, 2013 | ASUS " 14"" Laptop - 8GB Memory - 750GB...
Hi, i bought my Asus U46E-BAL7 one year and several mounths ago and i have noticed some unknown noise. It seems to be from hard disk, but I am not sure. So the system stops working and even rebooting, the...
Its probably that the hard disk has some clusters with damage , but you need to do test directly with the hard disk, its posible one time to ron the scandisk search from the tools by propierties in the Disk ( Button right) when try to see the disk from my computer. Ok
Sep 24, 2013 | ASUS U46E-BAL7 14in Laptop i7 2.8GHz 8GB...
Some keys laptop keyboard not working
Rarely does anything good come from dropping a laptop. It could be a loose connection or the keyboard needs replacing. Open the laptop and reseat the keyboard connection.
May 28, 2013 | ASUS Recertified - U46 Series U46E-BAL5...
What keys change bios values on asus u46e
Restart your computer
During the boot process you will see on the screen to press a certain key to enter setup usually the Delete or F2 key
this will vary depending on your computer and operating system
Press and hold that key during the boot up process to enter BIOS using the arrow keys load failsafe defaults or load optimized defaults press escape then press f10 to save to cmos to restart
this will set the boot order
hope this helps
if this fails you might try some of these
Acer: - Ctrl+Alt+Esc
ALR PC: (F2) or (Ctrl)(Alt)Esc)
AMI BIOS: (Del), (F1) or (F2)
AST, Advantage, Award, Tandon: - Ctrl + Alt + Esc
Award BIOS: (Del) or (Ctrl)(Alt)(Esc)
Jul 28, 2012 | ASUS U46E-BAL6 U46E-BAL7 U46E USB External...
Upgrade asus u46e
First of all you just can't swap the internal wireless card. You have to make sure it is compatible with your laptop. Your best bet is to buy a usb wireless adapter that has blue tooth capabilities.
Mar 14, 2012 | ASUS Computers & Internet
Where can I get a owners manual for the Asus U46E-BAL5 laptop ? Bought the laptop but no manual in box
please try to download it from the site. just google Asus U46E-BAL5 laptop manual
Sep 13, 2011 | ASUS Computers & Internet
I have an Asus U46E. my sound seems to randomly stop working, how can i fix it?
Check your speaker terminal connection going into your laptop to make sure it is not shorting or falling out. Try using a pair of headphones to see if this issue is still present.
Else, try updating to the newest sound card driver, available here:
http://www.asus.com/Notebooks/Superior_Mobility/U46E/#download
Aug 03, 2011 | ASUS Computers & Internet
Overclocking
Overclocking is set from the BIOS configuration. Not all BIOS allows overclocking, it may need a BIOS upgrade.
Check the ASUS WEB site for your model motherboard.
Overclocking the CPU (ie running at a higher clock speed) and increasing Frontside bus speed will give better performance BUT there is a downside too, if you overclock too high you could overheat the CPU and it could fail.
Sep 01, 2009 | ASUS P5GC-MX/1333 Motherboard
ASUS U46E-BAL7 14in Laptop i7 2.8GHz 8GB 750GB DVDRW Logo
44 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
