Question about Acer Aspire 4520-5582 Notebook
Need Key combination for wireless - Acer Aspire 4520-5582 Notebook
Need to wireless network on using function key
Hi
Please press the fn key and the key with the radio mast symbol or the sattelite symbol, it varies for different manufacturers but is usually the F5 key
Feb 11, 2010 | Compaq Computers & Internet
My Dell Studio 1737 states that it can not connect to wireless internet. I need to enable the wireless connection by a button in the front that I can not find or a combination of functions keys that I also...
Press the Fn key. While keeping it pressed, press F2 key. This combination of keys will turn on the wireless. You can use the same key combination to switch off the wireless also. When the wireless is turned on the wifi light glows to indicate it is on.
Feb 10, 2010 | Dell Studio 1737 Laptop
Need to change password from previously changed password
To secure the wireless network or to change any settings on the router you will need to access the router set up interface.
Open the set up interface of the router . Make sure that your computer will be connected to the router with the Ethernet cable.
Once you open the set up page of the router , you will find the place to change the wireless settings of the router. In case of Linksys wireless router , you will see the Wireless Tab at the top.
SSID : It is the name of the wireless network. This name will be shown on your wireless computer or the wireless device so that you can identify your own wireless network. All the routers come with their factory default settings. For example , the Linksys router will come with the Linksys network name.
It will be better to change the wireless network name.
Wireless Security
Change the security mode to WEP. This security type is supported by all the operating system. When change the security mode to WEP, you will find the Network key box to type the network key. Do not type anything in the Passphrase box. Type your network key in the Key 1 Box. If you set the encryption to 65 bits, your network key will be 10 digit hexadecimal number. that means you can use the combination of 0,1,2,3,4,5,6,7,8,9 and letters a,b,c,d,e,f only. remember it should be exactly 10.
If you set the Encryption to 128 bit, your network key will be the combination of 26 digits. You will need to remember the network key.
WPA
This is one of the most secured type of encryption.
Open the set up interface of the router. Change the wireless security mode to WPA personal. You will find the passphrase box. in this box you can type any password for your wireless network. The password should be the combination of number and letters and it should be 8 or more than 8 characters.
This security type is supported by WINDOWS XP SP2 and above Operating system.
WPA2
This is one of the highly secured type of encryption.
Open the set up interface of the router. Change the wireless security mode to WPA personal. You will find the passphrase box.In this box you can type any password for your wireless network. The password should be the combination of number and letters and it should be 8 or more than 8 characters. Keep the Algorithm to TKIP.
This security type is supported by WINDOWS VISTA and above.
Once you change the wireless settings on the router , try to connect to the new wireless network
Click Here for more info
Dec 19, 2009 | 2wire 1800HG Router (RG1800HG00)
Ntel(R) Wireless WiFi Link 4965AGN i want to
Wireless Security
WPA
WPA2
Once you change the wireless settings on the router , try to connect to the new wireless network .
Dec 16, 2009 | Computers & Internet
Dell Inspiron 1525 cannot connect and says I need to turn on wireless capability using function key combination - what is it?
The wireless radio combination should be the Fn+F2 keys to activate it. That is to hold down Fn and hit the F2 key.
Regards.
Nov 09, 2009 | Dell Inspiron 1525 Notebook
Where is the switch or function key combination to turn on wireless connection?
It's difficult to tell, but there seems to be a small switch on the front, that may activate the wireless connection. If that isn't it, you can usually access the modems through control panel, under 'network and internet,' and the wireless assistant, or possibly the network and sharing center; if the wireless modem is disabled, right clicking on the icon will usually give you an option to activate it, or you can connect to a network through the network and sharing center, as well as detecting networks, and that will tell you whether or not the thing is working.
Oct 23, 2009 | Acer Aspire 4720 Notebook
Wi Fi on Laptop
What's the brand of your laptop? Usually the key combination is Fn F2
Jul 27, 2008 | Linksys Wireless-G WRT54G Router
Wireless conection
typically, there is a key combination to turn your wireless on and off. The combination is most often the FN key + F8. If you look at keys F1 thru F12, you will find a key that has a blue symbol that looks like a transmitting antenna. You will need to hit the FN key + the key with that symbol. I, too, have a similar problem, but the key combination is not working. I hope you don't have that problem.
Dec 03, 2007 | Toshiba Satellite A105 Notebook
Acer Aspire 4520-5582 Notebook Logo
23 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
