Can i disable my freezer alarm it keeps on beeping
SOURCE: freezer alarm
nana,
Your defrost elements are not working or the inlet to the evaporator tray is clogged, if you haven't gotten iny icy water build-up in the bottom of the fridge you will soon. This may require a service call.
randy320sgi
SOURCE: Sears Ken Elite upright freezer model no 25329082991 temp alarm
alarm should go off when freezer reaches minus 18c or lower.
SOURCE: Bosch Fridge Freezer KGU3200GB/01 alarm beeping temp rising
Is your circulating fan working?
Sometimes they stick and need a shot of WD 40 and then work
it back and forth a little until it wants to take off again. Keep me informed
and PLEASE give a Thumbs Up for the effort. The Raz Shack
SOURCE: the alarm keep beeping and when I turn it to off
Sounds like you have a bad door switch. Depending on the age of the fridge, it might still be under warranty. If it's not, then you might be able to access the door switch yourself and pull it out & replace it.
This is common. Unplug it or turn off the circuit breaker for a full 5 minutes. Things will be good
SOURCE: Cannot open alarm system to change battery
Push down on the tab at the top of the panel and open the front panel (Panel will say enter security code now). Put a slotted screwdriver in the top hole and depress to fold dowm the second door. Battery is inside the plastic case with two screws holding on the lid. The battery is a 6V 1.2AH battery
AlarmProfessor.com
