Question about Proform 400 CT Treadmill - Treadmills
Tap tap tap noise when the belt turns on. consistent.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 132 Answers
Can you determine where the noise is coming from . under the front hood or back. if you can remove the hood and look at the drive belt for fraying . also look at walking belt for fraying. any loose piece will hit something and make noise with every revolution
Posted on Apr 20, 2014
Engine has squeasky noise consistant with rocker timing
Not sure what rocker timing is but if you are talking about a rocker arm tapping then you will need to remove the rocker arm cover and adjust the lifter that is making the noise.
Apr 15, 2015 | 2006 Chevrolet Silverado 1500 2WD
Hi, I've got a Kenmore model 110.70052991 and the drum won't rotate. It will intermittently. I have just replaced the belt and it still won't spin consistently. Could it be the
are u able to spin the drum manually? do u hear any sounds? squeaking? scraping? smell anything? the rollers (spinners lol) usually make funny noises when they go out and may still turn but roughly. Bad bearings may be an issue here? However if the motor has bad windings it may not have enough power to run (turn) drum consistantly, u can remove the drum and belt and housing and run the motor by itself and see if it turns and runs easily. with no pressure or weight added? Then add drum and belt, once the drum is added and it stops or runs half hazardly its ur motor ? In some cases the tensioner the belt sits on ( near the motor) can be damaged and cause similar problems , lastly u did add the belt correctly?
Dec 23, 2014 | Kenmore Dryers
Tapping noise in 86 toyota tercel after replacing timing belt
timing belt idler pulley could be loose causing timing belt to slap.
Dec 20, 2012 | 1986 Toyota Tercel
Engine is heating up. very low idle when stopped. turn on heater makes strange noise and affects the idle of the engine.
This is impossible to tell without seeing the vehicle, but check to be sure your sepentine belt is still intact and turning the alternater and the water pump. I've seen these go out b4, and these symptoms seem consistent with the belt not driving it's components, overheating (the water pump not being turned) and lack of electrical poiwer( the alternater not being turned). Good luck and contact me if you are still having problems. We will try our best to help you solve this!
Jan 15, 2011 | 2002 Saturn Sl
Hi, i have a toyota fielder 1.8cc with a some problem which has now come up. when i switch on esp in the morning after staying overnight, it produces some really annoying sound from the engine. when the...
If it is a 'squealing' noise it's probably the alternator/power steering drive belt. Before you turn on the engine in the morning, lightlt smear or spray some oil on the inside of the drive belt to lubricate it. If the squealing stops/disappears, then that's the fault ..
That squealing noise can be caused by an incorrectly tensioned belt, or a worn belt. Replacement is the only option.
The other frightening sounds can best be described as 'rattles' or 'tapping'. When a car stands overnight all the oil drains back into the sump (oil/pan).
There are two things (usually) that can be cause the rattle/tap:
1. Because the oil hasn't been pumped around the system, at start up worn big end bearings can rattle and tap on the crankshaft until the oil 'fills the gaps'. The tapping/rattling goes away as the engine warms and oil is pumped around the lubricating system.
A 'bottom end tapping' is a symptom of worn big ends (they are bearings at the bottom of the piston and fit around the crankshaft).
2. A rattle/tapping from the top of the engine can either be a worn camshaft or 'lazy tappets'. Again, when the engine warms and oil gets to the camshaft and tappets (also called 'hydraulic lifters) the noise will disappear.
If your car has this rattling/tapping noise - identify whether it is coming from just under the rocker box (ie the camshaft/tappets..) or the bottom end of the engine (big end bearings).
If the noise is coming from the top of the engine, try an oil change with a can of thick 'additive' included. A lazy tappet (lifter) isn't too much to worry about. A worn camshaft will affect the performance of the engine, though continue to do its job. An oil change with an additive included may help in quitening things down.
A bottom end tap/rattle (or 'knock') - the sooner that is sorted out the better.
Aug 16, 2010 | Toyota Corolla Cars & Trucks
When on the freeway and my power steering "turned off", which has
With the power steering quitting immediately, it indicates a broken belt or serious lack of power steeering fluid. If it's fluid, you have a leak allowing it to escape.
The "tapping noise" sounds like it might be the belt flapping around with engine running.
Feb 16, 2010 | 1999 Honda Prelude
Lifter tapping
The tappet noise usually will get louder and louder as it wears. A totally collapsed lifter will definitely be noticeable by loss of power to that cylinder, misfiring, and excessive noise. But then again your current lifter noise could be possibly maintained for years to come by regular and consistent oil changes.
Nov 03, 2009 | 1991 Ford Explorer
Washer has started making a heck of racket during the drain/spin cycle. It's not consistant. Two loads may go thru ok no noise. A third load and it will make a very loud grinding chain like noise.
Grinding noises are most often the result of a failing water pump. The noise can increase during the spin\drain cycle due to the added load on the pump. Although less likely it could also be the drive belt rubbing on something or a pulley bearing failing. If you are able to locate and remove the drive belt, you should be able to turn the water pump pulley by hand. If the pump does not turn smoothly it is bad.
Aug 06, 2009 | Maytag Washing Machines
Tapping noise sometimes
Just add oil, or better yet get an oil change, your oil is obviously low, antifreeze is not a fix all.
Feb 12, 2009 | 1994 Mazda 626
Valve tapping noise
you possibly bent a valve ever so slight when a valve gets bent it increases the gap between the rocker & the valve
Sep 21, 2008 | 1995 Honda Accord
Proform 400 CT Treadmill - Treadmills Logo
187 people viewed this question
Top Proform Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
Electro Med Services...
Are you a Proform Exercise and Fitnes Expert? Answer questions, earn points and help others
