Question about Pool & Spa
Leisure bay spa starts and runs for30 sec and stops power still on no error code just presentNt temp reading
5 Suggested Answers
  • 366 Answers
SOURCE: How do I stop the spa from starting up and
It's not possible to stop the spa from starting up after a power loss. Most spas go through a self test then try to reach the last set temperature. Pump 1 usually runs the filter/heater, once it's activated it should run for 20min or until you turn it off. The high speed on pump 1 should always work. One problem with the pump may be that it's heating up and the internal high limit won't let it turn on. When you shut the pump off, the motor gets even hotter for a period of time since the fan is not turning, it may be getting hot enough to trip the internal high limit so that it won't turn on until the motor cools down. It won't turn on even if the topside control indicated that it should be on.
Posted on Dec 02, 2009
  • 990 Answers
SOURCE: Pool Heater Mis-reading Temp.
Your temp sensors are on the heater, a small tube that slides into the water manifold, usually on the left side. On the remote it will be in one of the pipes coming from the pump or the filter. If it is after the heater you should move it to between the filter and heater. It will be a tube that is in the pipe with a stanless steel clamp holding it in place.
To find out wich one it is you will need to remove the remote from the system by takeing the wires that go to it from the wireing inside the heater and wire nuting the wires in the heater together. If the heater runs normal then it is the sensor for the remote if not it is the sensor for the heater. Let me know how you do and if need be we can get a little more specfic for your system. good luck.
Posted on Mar 29, 2010
  • 8404 Answers
SOURCE: Need manual for Leisure Bay spa
Go here http://www.spasbyleisurebay.com/ and click on Spa Manuals.
Posted on May 16, 2010
SOURCE: I have a leisure bay spa with a s pack 3000
i have a s-pack 3000 that has no display ? so do i need a top side or a new pack??
Posted on Jul 16, 2011
Older leisure bay tub. only a few buttons on topside panel work as they should. temp control buttons switch from economy to standard,cant raise or lower temp. Topside panel or control board?
Top side control. 90% sure by your description of problem. Buy the topside, plug it in and try it before you do full install. If it doesn't work you can return it. Most places won't take back a PC Board.
Apr 25, 2017 | Leisure Pool & Spa
Where can i view a leisure bayhot tub manual?
You can find a copy of the Leisure Bay hot tub owners manual on The Cover Guy website. We also have a guide for error codes and information relating to Leisure Bay hot tubs. Leisure Bay Spas Hot Tubs Information
Jun 11, 2014 | Qca Spas Dream Series Dream Master Hot Tub...
Leisure Bay spa will not heat past 86 degrees. Element and sensors are new. Spa has excellent flow and correct voltage at terminals.
if the spa does not heat up to 104 degrees then the temp sensor is what you are going to need.
Are there error codes showing on the screen of the topside?
You will need to know the model number of the control box or the model number of the heater tube in order to get the proper sensor.
Rod
US Parts Center
888-521-6183
Feb 09, 2013 | Pool & Spa
My leisure bay spa will not heat past 86 degrees.
If your spa will not heat up to the 104 degrees or what temperature you set it at then you have a bad temp sensor.
RodUS Parts Center888-521-6183
Pool & Spa Logo
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
