Question about Toshiba MV19N2 19 in. TV/VCR Combo
Toshiba TV?VCR combo problem
The top of the screen (about 4 inches) inverts the image so its really hard to see any scores during sporting events.
  • 143 Answers
Re: Toshiba TV?VCR combo problem
You have bad caps in the vertical curcuit if you open it up you will see a smallmetal square ground sheild in there you will find two red caps look at them very carefully one will be wet it is leaking replac it
Posted on Nov 02, 2007
0 characters
3 Points
Looking for a 4 digit code for toshiba 13 inch tv
go to this site, it has the manual, download it and look for the code
Jan 30, 2011 | Toshiba MV13N2 13 in. TV/VCR Combo
Over and inch of fine lines at the top of the screen. How do I correct this?
The Toshiba sets are well known for these types of problems, this is a vertical deflection issue that involves two or three capacitors and touch up to the ic. This is a job for a technician because it will need parts and solder work to install them.
Jan 09, 2011 | Toshiba MW24FM3 24 in. TV/VCR/DVD Combo
White lines at top of screen - can't make go away
You have a problem in the vertical output circuit. Check for bad capacitors around the vertical output IC. The value of these caps are marked on the side of them. Thanks for using fixya. Please take a moment and rate this responce.
Nov 30, 2009 | Toshiba MW27FN1 27 in. TV/VCR/DVD Combo
At the top of Viewing screen
I would suspect that the vertical output transistor is getting ready to go.
Sep 23, 2008 | Toshiba MW27F51 27 in. TV/VCR/DVD Combo
White lines accross top of screen on our 27 inch Toshiba,
lcd or plasma.
are the lines solid or blurred. do they have sharp edges.
You may have a memory problem with the display which can only be repaired by factory trained technicians, or a brave soul willing to find parts on ebay.
May 02, 2008 | Toshiba MW27FP1 27 in. TV/VCR/DVD Combo
TV picture
This set will need to be serviced by a tech shop as you have a problem called "vertical foldover"...accordianman
Apr 09, 2008 | Emerson EWC27T3 27 in. TV/VCR/DVD Combo
I was having the same issue and I've been to several video stores to rent DVDs and 2 out of 3 rentals have the same affect where it is just 'reading' but even worse, it would play fine and then freeze up during the movie- very frustrating. Now, after 3 years of owning it, it died today. They just don't make them the way they used to :(
Apr 01, 2008 | Toshiba MW24FP1 24 in. TV/VCR/DVD Combo
Screen white line problem.
There are two capacitors in the vertival output circuit that need replaced
Oct 19, 2007 | Toshiba MW27FN1 27 in. TV/VCR/DVD Combo
Toshiba MV19N2 19 in. TV/VCR Combo Logo
47 people viewed this question
Top Toshiba Combination Televisions Experts
matt martin
matt martin
Jaime Hernandez
Are you a Toshiba Combination Television Expert? Answer questions, earn points and help others
