Question about Electrical Supplies
WHAT THE VALVE SPEC ON MY GENERATOR ALL POWER APG3009
VALVE SPECS
SOURCE: replacing head after repair bent valves need tork specs for head
if interested i can e-mail you a diagram of the torque sequence and torque values just did one this weekend.
Posted on Nov 15, 2008
  • 52 Answers
SOURCE: Valve specs for VT 500 honda shadow 1983
Your valve clearances should be:
Intake .08-.12 mm (.003-.005 in)
Exhaust .12-.16 mm (.005-.006 in)
I usually start all gaps in the middle of given specs, then fine tune from there.
Hope this helps
Posted on Mar 15, 2009
Hentie
  • 18 Answers
SOURCE: specs for a 1997 Ford Ka 1297 cc
If the vehicle is fitted with a Rocam engine, the valve clearance is not adjustable, hydraulic lifters.
The camshaft caps are torqued in two stages, first 10Nm and than 90 degrees
Posted on Apr 20, 2009
  • 3567 Answers
SOURCE: I need valve specs oor timimg adjustment for the
Go to this site and you can download a free PDF service manual.
www.carlsalter.com/motorcycle-manuals.asp The closest in the list is a 2003. This will work perfectly well for your repairs. Yearly changes are normally cosmetic and don't affect the mechanics.
Can I get a “very helpful” rating on this answer? Thanks!
Posted on Aug 03, 2009
wracefans24
  • 1985 Answers
SOURCE: 1972 ford 302 V8 What is the timing spec? The
10 degrees BTDC
Posted on Dec 28, 2009
Buffalo tools 7000 watt 13hp ohv 4 stroke valve clearance
if you cannot get the specs from on line or from a service agent , generally the following apply:-
water cooled engines
inlet hot .010"--exhaust hot .012"
for air cooled engines inlet hot .012"-- exhaust hot .014"
Aug 30, 2015 | Buffalo Tools Electrical Supplies
What is the valve clearance on a 1800 watt generator
Use the name plate information on the engine to identify the make and model of the engine. You shuld then be able to look up the engine specs on-line.
Mar 01, 2015 | Honda Electrical Supplies
Keeps bending pushrods
It sounds like your tolerances on cams, etc, inside the engine are out of spec causing this problem. I would do a complete teardown of engine to properly diagnose.
Feb 10, 2014 | Eastern Tools & Equipment ETQ TG72K12 Gas...
Valve adjustment spec edl5500
point 1.3 mm is the valve gap but most put it to 1.4mm as they tend to tighten up over time.
Jan 06, 2014 | Yamaha Edl5500 Generator Oil Filter...
Looking for fuel filter for Onan HDKAK=1046 rv generator. Anyone have the product number
You didn't indicate a Spec number for your gen that would be required. Any RV place can get this part it is Cummins part # 149-2513 but a Spec number would help.
Oct 09, 2013 | Onan Cummins 8.0 HDKAK/1046 RV QD 8000...
I need valve spec,s for mod PM0435001,
For specs on the engine, look for engine model number and type then google. You will find the engine model number either on the block of the engine or on the fan cover. If you can't find a number, google the brand of the engine using search key " engine model number location" ex Briggs model number location. Could be either briggs, tech, honda or other. Good luck.
May 22, 2013 | Coleman Powermate Electric Generator...
My generator is poping or firing back through the carb. What is the problem.
Generally this is caused by leaking intake valve. The valves could be out of adjustment, weak or broken valve spring or bent valve. If the generator was not used for a while, rust could have formed on the seat. Easy to check compression and compare to factory specs. Or loosen valve adjustment a bit and run engine with upper cylinder lube in fuel or squirt directly into carb. If it does not improve may be time for valve grind. Not too difficult. Good luck on your repair
Jul 09, 2010 | Coleman Powermate Premium Plus 6250W...
Need help with the needle valve placement on a Tecumseh Carburetor for a generator
Do you have the model and spec number for the engine?
Is it the high speed or idle adjustment?
Rule of thumb for high speed it turn in til snug and back of 1.5 turns; idle is 1 turn. Start engine and adj to ear.
Jan 02, 2010 | Coleman Powermate Powermate 5000W...
Electrical Supplies Logo
100 people viewed this question
Top Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
