Question about Levelone 24 Port Gigabit Switch GSW2476
ISsue with resetting Gigabit Switch GSW2476
Unable to reset back to default settings
Default password
The default password is blank (i.e., leave the password field blank).
Nov 18, 2013 | NetGear ProSafe GSM7248 48-Port Gigabit...
I have a D-Link router and when I try resetting it, the password won't work even if it's the default password
You may have to do a full factory resent. Try a hard reboot (turn off the on) of the router. If not try a factory reset that you should be able to do using the admin functions in the settings. Of course you will have to set-up you router from scratch but this may solve your password issue.
Apr 15, 2013 | D-Link DIR-815 Xtreme N Wireless 802.11N...
Default password for a Cisco SG200-26? cisco, cisco do not work .. ??
I had the same issue after what I thought was a succesful reset. It turns out I hadn't reset the switch completely. There is a reset pin hole next to the power switch. Hold it in with a paper clip for at least 30 seconds. ( I was holding in the power button for 30 seconds.)Then you can use the cisco admin and cisco for password defaults. Hope this helps someone in the future since I spent WAY TOO MUCH TIME on it :)
Oct 27, 2012 | Cisco SG200-26 24 10/100/1000 Ports,...
Unable to detect my Netgear Gigabit smart switch GS748T via Smartwizard discovery. Earlier have tried reset the switch to factory default but to no avail. Pls help.
First, make sure your switch and PC are in the same broadcast domain/subnet, and that there is a DHCP server in operation.
Second, make sure you are following the "factory reset" procedure correctly (http://support.netgear.com/product/GS748Tv1).
Third, check your version of Smartwizard Discovery, and download a newer version if one is available. I think the latest version is 2.05.05 (download from http://support.netgear.com/product/GS724Tv2).
Sep 28, 2011 | NetGear ProSafe GS748T 48-Port Gigabit...
I want to reset my D-link 4046 to factory default. How do i go about that?
in general, to reset the D-Link to the Factory Default Settings, please follow these steps:
Turn off the router
Locate the Reset button on the back of the router.
Use a paper clip to press the Reset button and power on.
Hold for about 5 seconds (don't hold too long) and then release. (Or, release when M1 and M2 flash at the same time.)
After you have completed the above steps, the router will be reset to the factory default settings
May 19, 2011 | D-Link 24 Port Gigabit Unified Layer 2+...
I want reset the factory default of my switch HP Procurve 2510G
To reset using the CLI, run the command "erase startup-config". When prompted, say yes to reboot and that will restore the procurve switch back to factory settings after it starts up.
Mar 08, 2011 | HP ProCurve Switch 2510G-24 24-Port...
We have lost the password for Linksys srw2008mp switch and would like to reset it to factory defaults we cannot get into it to reset it.
To reset to factory Default settings you need to do the below steps
1. Look for the reset button. The reset button is a tiny black button on the back of the switch.
2. Power Off the switch.
3. Press the reset button (preferably with help of a ball point pen or a small head scew driver) keep the tiny black button pressed and do not release that.
4. Power On the switch and the sys LED will blink slowly and then rapidly. 5. Now release the black button
6. Wait for 5 minutes. The switch will boot up with factory default settings.
Best Regards
Nov 13, 2010 | Linksys SRW2008MP 8-Port Gigabit Ethernet...
Good morning, how do I reset my Linksys SD2005 5-port Gigabit Ethernet Swith to default factory settings.
There is a tiny reset button on the back of the switch.
Power off the switch. keep the tiny black switch pressed and do not release that. Power On the switch and the sys LED will blink slowly and then rapidly. Now release the black button and wait for 5 minutes.
Oct 28, 2010 | Linksys SD2005 5-Port Gigabit Ethernet...
Reset a switch
Please login in Switch usign Default ip
then in last menu they give one option reset switch as factory default setting please click on this.
May 10, 2010 | NetGear GSM712 Managed Gigabit Ethernet...
I can't access default IP add of DLink DGS-3100 48P
Straighten one end of a paper-clip, and insert it into the back of the router, to "reset" the router to its "factory" settings.
Then, try again.
Oct 27, 2009 | D-Link DGS-1008D 8-Port Gigabit Ethernet...
Levelone 24 Port Gigabit Switch GSW2476 Logo
Top Levelone Computers & Internet Experts
micky dee
Prashant M
Prashant M
Are you a Levelone Computer and Internet Expert? Answer questions, earn points and help others
