Question about Mitsubishi CK-35308 35" TV
Weight of tv and console - Mitsubishi CK-35308 35" TV
Do weight loss programs help you to lose weight?
Losing a weight will a lot depends on the person itself. Weight loss program works because it will give you complete guidance about how to Lose weight.
It helps you to lose weight fast with a better strategy. They provide a proper diet and work out the plan with some traditional massage therapies which will help you to lose your weight easily.
Things with proper planing will always give you the better result. They provide their services with better planning which will help you to lose your weight fast. I believe so because I had undergone through this weight loss program and it really helps me in losing weight.
Jul 31, 2017 | You Video Game Consoles & Games
How do I find out the weight of my 42LC2DB television for a wall bracket
If its not on the paperwork get your bath scale have some one hold tv and stand on scale. note weight put down tv back on scale note weight and subtract,
I am assuming it's not a 60 inch, if so maybe 2 people and 2 scales
mike
Feb 19, 2016 | Televison & Video
How do you adjust the enternal weight on this?
The following link will take you to the console codes that allow you to program information according to your desires.
Stairmaster 4400CL and 4600CL Console Codes Customize Diagnostic
Jan 18, 2012 | Stairmaster 4600 Cl Cordless Freeclimber
Weight on console is 1 stone below actual weight
false advertising maybe???
We I am used to the metric system over in aus but my understanding is that a stone is about 6kg. It might also be if you included accessories, like hard drives. they probably weight that much. i wouldn't worry if you got it from a legit place, if you got it online or at an auction it might be worth getting it looked at.
Mar 09, 2011 | Video Game Consoles & Games
Can you tell me the dimensions and weight of a Wii gaming system. I am interested in shipping one to Panama, Central America and need the information to provide the local delivery firm.
hi, here is the weights and dimensions of just the wii console
it measures 44 mm (1.73 in) wide, 157 mm (6.18 in) tall and 215.4 mm (8.48 in) deep in its vertical orientation, slightly larger than three DVD cases stacked together. The included stand measures 55.4 mm (2.18 in) wide, 44 mm (1.73 in) tall and 225.6 mm (8.88 in) deep. The system weighs 1.2 kg (2.7 lb)
let me know if you want the weight of it as if it was in the box as the weight and measurements i have given you are just for the wii console on its own i would have to get the weights for you if you wanted it as if it was boxed and new with control, powepack,av cable,manuals etc, let me know if these are the details you want and ill locate them for you ok
Dec 14, 2010 | Nintendo Wii Console
I must dispose of my Mitsubishi VS-60607 Projection TV. I have a weight requirement for disposal. My manual failes to specify the weight of my TV. What is the weight of my TV?
This thing weight 200 pounds.U can't dispose tv in ur regular disposal.This must gose to Electronic recycle center.Becauce,it have leads and chemicals inside it component parts.
Sep 09, 2010 | Mitsubishi VS-60607 TV
I can't see the picture from the game on my tv
Try hooking up the Genesis to a different TV. If it works, then there's something wrong with the TV or the connector between the Genesis and the TV. If it doesn't work, then the Genesis is most likely on it's way to becoming a paper-weight, or once again the connector could be bad.
Jul 06, 2010 | Sega Genesis 2 Console
Ps3 tv screen blink
Try plugging the cord (the one on the right of the back of the ps3 when facing the ps3 from the front) .The problem is that that cord will come loose, the best solution I found was either putting it on the floor (after plugging it in all the way) or by (when its like on top of a tv or something) looping the cord around something, just so there isn't so much weight on where it pluggs into the ps3..
Apr 05, 2010 | Sony Playstation 3 (PS3) Console
Disc door will not open
The magnetic weight thats mounted on top of the dvd drive on the inside has came loose and jamming the door. Also it wont read the discs if this happens. I repair drive issues in PS3 and 360's with 99% success
Jan 22, 2010 | Microsoft Xbox 360 Console
How much does a 39 inch flat screen olevia tv typically weigh?
I couldn't find a 39" Olevia TV, but I did find 37" ones and they weight a little over 50 pounds. You can find the weight for your specific model at www.olevia.com. Select the series and then click "View Full Specifications" on your model. Then click the Specifications tab and go down to Other. Gross weight should be the weight when packaged, and Net weight should be the weight of the TV by itself.
Mar 21, 2009 | Televison & Video
Televison & Video Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
