Question about Lisle Pneumatic Oxygen Sensor Remover 43900
Where is the oxygen sensor on my 2004 durango 4.7 v8?
Where is the down strean oxygen sensor
4.9 Durango motor interchange
For the 4.7L v8 (I couldn't find any listings for 4.9L): 2000- early 2002 Durango, 2000- early 2002 Dakota, 2002 Ram 1500, 1999-2004 Jeep Grand Cherokee. In later part of 2002, Durangos and Dakotas changed the reluctor/cam gear on the right camshaft for the cam pickup sensor, and changed the tone wheel on the crankshaft from 16 tooth to 32 tooth.
Sep 11, 2016 | 2001 Dodge Durango
How many 02 sensor and how many wire each sensor
depending on the engine make
v8 and v6 have 2 oxygen sensors( O2S) , one after each cat converter with 2 wires and 2 heated oxygen sensors ( HO2S) in the exhaust manifold/ pipe before the cat converter with 4 wires each
6 cyl and 4 cyl engines have one oxygen sensor after that cat converter and one heated oxygen sensor before the cat converter
Mar 24, 2016 | Cars & Trucks
Where is the oxygen sensor for 2004 dodge durango 4 wheel drive?
It has 4 . 2 upstream of the cats 2 after the cats . Whitch one are you looking for
Apr 18, 2015 | 2004 Dodge Durango
How to change upstream o2 sensor on 2008 chevy uplander 3.9l ?
  • 1 Warm up the engine for about four minutes to bring it to operating temperature. Then turn off the engine. This will avoid damage to the exhaust pipe threads if that sensor has seized to the pipe.
  • 2 Find the oxygen sensor or sensors you need to replace. The upstream sensor is located near the exhaust manifold and the downstream sensor on the back exhaust pipe, close to the catalytic converter.
  • 3 Disconnect the oxygen sensor electrical connector. Depending on your particular Chevy model, both sensors may be disconnected from the engine compartment.
  • 4 Lift the front of your Chevy model to reach the sensor you need to change, if necessary. Use a floor jack and two jack stands to support it.
  • 5 Remove the oxygen sensor using a box-end wrench or a ratchet and oxygen-sensor socket.
  • Read more : http://www.ehow.com/how_5159092_replace-oxygen-sensor-chevy.html
    Jul 23, 2014 | Chevrolet Chevy Cars & Trucks
    How many o2 sensors are on a 1999 Silverado 5.3
    The 1999 5.3 V8 engine had 4 oxygen sensors. There are two catalytic converters on this engine, one on the driver side of the engine, and one on the passenger side of the engine. This is important to know, as the number of oxygen sensors is directly related to the number of catalytic converters on the vehicle. Driver side is referred to as Bank 1, passenger side is referred to as Bank 2. This is very important to know when looking up replacement oxygen sensors. There is one oxygen sensor in front of, or before the catalytic converter, usually referred to as a pre-catalyst O2 sensor. There is also one behind, or after the catalytic converter, usually referred to as a post-catalyst oxygen sensor. So, you have two oxygen sensors on Bank 1, and two oxygen sensors on Bank 2, for a grand total of 4 oxygen sensors.
    Oct 03, 2013 | 1999 BMW 318 ti
    What is the best way to remove O2 sensor bank 1 sensor 2?
    Here is the low-down on oxygen sensors, and their location designations explained:
    Oxygen sensors are screwed into the exhaust system at various points. Some people say that there are 4 oxygen sensors, but technically, that is not correct. Only the front 2 are considered oxygen sensors.
    These oxygen sensors are screwed into the exhaust pipe or directly into the exhaust manifold, one on each bank. Because they are in front of the catalytic converter, this is often referred to as 'upstream'.
    The other 2 are actually called catalyst monitors. They are oxygen sensors, but they serve a different purpose. They monitor the activities of the catalytic converters, thus the name, catalyst monitors. They are screwed into the exhaust one on each bank, after, or downstream, of the catalytic converters.
    On a 4 cyl engine, there are only a total of two such sensors, the one in front of the catalytic converter is the O2 sensor, the one behind the cat is the catalyst monitor.
    The location names for them are as follows:
    • On a 4 cyl, the front / upstream is called "bank 1 sensor 1" and the rear / downstream sensor is called "bank 1, sensor 2."
    • On a V6 or V8 engine:
      • the passenger side bank on a forward facing engine, or the bank closest to the firewall on a transverse mounted engine, is bank number 1, so the forward / upstream sensor on that bank would be "bank 1, sensor 1."
      • The driver's side bank (forward facing mount engine), or front bank (transverse engine) would be bank number 2, thus the forward / upstream sensor on that bank would be "bank 2, sensor 1," and the rearmost / downstream sensor on that bank would be "bank 2, sensor 2."
    Jul 28, 2012 | 2004 Mitsubishi Endeavor
    2000 Dodge Durango 5.2L V8 starts but won't run
    By run - do you mean it dies when you put it in gear? Or that it just bogs down when you attempt to accelerate or drive away?
    A plugged Catalytic converter will cause this. So will a Bad MAP or MAS (Mas Air ) sensor. So will a bad TPS (Throttle Position) sensor.
    Need more input to answer more precisely.
    Jul 25, 2012 | 2001 Dodge Durango
    I have a 07 f150 4.6L V8 and I need to replace the Bank 1 sensor 1 oxygen sensor but cant figure out which sensor it is since there are 4 sensors. Where can I find a picture of the location?
    Heated Oxygen Sensor (HO2S)- The Bank 1 Sensor 1 tells me that it's an upstream O2 sensor. The larger the number the further down the line of the exhaust it is. Removal & Installation 4.2L Engine ford-04-42-2750.gif
    To Remove:
    1. Raise and safely support vehicle.
    2. Disconnect battery ground cable.
    3. Detach electrical connector from right inner fender splash shield (if necessary).
    4. Remove right inner fender splash shield (if necessary).
    5. Disconnect heated oxygen sensor electrical connector.
    6. Remove heated oxygen sensor.
    To Install:
    1. Apply anti-seize lubricant to heated oxygen sensor threads.
    2. Install heated oxygen sensor. Torque to: 34 ft-lbs (46 Nm)
    3. Connect heated oxygen sensor electrical connector.
    4. Install right inner fender splash shield (if necessary).
    5. Attach electrical connector to right inner fender splash shield (if necessary).
    6. Connect battery ground cable.
    7. Lower vehicle.
    To Remove:
    3. Disconnect heated oxygen sensor electrical connector.
    4. Remove heated oxygen sensor.
    To Install:
    4. Connect battery ground cable.
    5. Lower vehicle.
    Nov 07, 2010 | Ford F-150 Cars & Trucks
    Where is the EGR Valve on a 2004 Dodge Durango Limited, V8, 5.7L Hemi? Is a hard operation to replace?
    Have not replaced the EGR on my 04 Durango as of yet, but if you look into the the passenger side front fenderwell you will see part of it. Usually 2-4 bolts and the harness connector are all that is required.
    Chrysler EGR valves are not known for their reliability.
    Don
    Apr 14, 2010 | 2004 Dodge Durango
    Lisle Pneumatic Oxygen Sensor Remover 43900 Logo
    57 people viewed this question
    Top Lisle Air Tools & Compressors Experts
    John Trevino
    Joe Garcia
    Joe Garcia
    Are you a Lisle Air Tool and Compressor Expert? Answer questions, earn points and help others
