Question about Konica Minolta Kip 3000 Series Printer
KIP 3000 has a blank screen
Has a black or blank screen
BLANK COPIES ,STARTED WITH PARTIAL BLANK COPIES
Check the transfer/ separation assy. directly below the drum then mite need cleaning>
Oct 09, 2014 | Konica Minolta Kip 3000 Series Printer
BLANK COPIES
Check 1st the charging corona wires for cutoff or spark on both ends.. replace it.
The display is bigger than the screen on a kip 3000
You need to change your resolution so that it matches your screens resolution. To do this close all windows and right click on your desktop, after that select screen resolution and there should be a recommended setting.
Jun 03, 2013 | Computers & Internet
Black blank screen Lenovo 3000 N100
You say the laptop all of a sudden flashed off.
How old is the laptop? You may have suffered one of two things? First of all, if the hard drive will not boot back up, even after using the recovery discs, then that would explain it powering off. I have seen this happen on old desktop hard drives.
Next, try to get the transformer or adapter tested. It may not be putting out enough amperage to run the laptop.
Sep 01, 2009 | Lenovo 3000 N100 0768 - Pentium Dual Core...
Kip 3000 plotter
voltage error 031-034 on the kip 3000
Jul 05, 2008 | Office Equipment & Supplies
Konica Minolta Kip 3000 Series Printer Logo
64 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
