Question about Acer Aspire 5100-5033 Notebook
Acer 5100 Mouse Buttons Broken
These buttons have become very loose and need to be replaced , also the unit will not charge. Both battery and a/c cord have been replaced.
  • 36 Answers
The cheapest replacement touchpad and base i could find is at this link. also check the ac input socket and check that all the wires are connected.
Posted on Jun 18, 2009
Acer aspire one charging port loose
If I recall this model line uses a fixed DC power jack directly soldered to the main board. When they become loose, you can visually inspect the jack itself (without the cord plugged in), and use a pen or probe to see of the center peg is excessively loose. The common result is the solder connections have been broken between the DC jack and the main board. Often the jack itself needs to be replaced (involving complete disassemble, de-soldering old jack, cleaning, repair PCB if needed, and re-solder new jack in place.
TIP - if it is not charging, remove battery, and gently put pressure from different angles with the power cord plugged in, and try to turn it on. If it turns on with pressure from a specific angle, it would indicate the DC jack is indeed loose, and likely needs to be replaced. It works becomes the pressure is making the electrical contact that has other wise been broken. ALSO, if it turns on easily, yet losses power at certain angles, its a similar issue.
TIP2 - If it still indeed charges regardless of the angle, and does not lose power, it may be a "Modular" DC jack, meaning the jack connects to the main board through a wire harness, and is less prone to breaking the electrical contacts, and the jack is simply loose inside it's retaining clips/slides. Minor disassembly and hot glue are quick fixes for this since usually the plastic clip/slide in the chassis have broke.
GOOD LUCK! :)
Dec 06, 2013 | Acer Aspire One PC Notebook
My external mouse quit working on my Acer Aspire 5100 laptop.I have tried plugging it in to all the ports. It says USB device not recognized.
you might have to uninstall the mouse then restart your computer then reinstall the mouse and its drivers
make sure the lead from the mouse has a secure seating and the lead is not bad/faulty
((if applicable))
make sure the battery is good (has full charge)also you might test the usb device for the mouse is inserted correctly into the usb port (if applicable)
click start control panel mouse you should see 4 tabs buttons,pointers,pointer options and hardware make sure you have the correct mouse selected also under hardware you can troubleshoot also you can select properties under driver you will have options to update driver,rollback driver or uninstall and under hardware you can troubleshoot
in xp
hope this helps
Jan 24, 2011 | Acer Aspire 5100 Notebook
The left mouse button on my acer aspire 5100 laptop is broken. Can the plastic mouse button and surround be replaced?
yea, its a very common problem with Mousepad hardware.
But, it might be costly since, only 5% customers face this due to less cautiousness of handling mousepad.
But as the answer to your question, it is easily replaceable.
Get it replaced by an authorised servicemen.
Hope it helps.
Thanks.
Jun 17, 2009 | Acer Aspire 5100 Notebook
Acer laptop keyboard and touchpad not working Have had the acer aspire 5100 laptop for two years. Would not boot up. Sent to have fixed under warrany. Came back the boot up was fixed but now the keyboard...
The Acer service centre have probably not connected the keyboard and touchpad to the motherboard. Common mistake by Acer. It is best to send it back to Acer to have it fixed under warranty as if you try it yourself, the laptop could be rendered out of warranty. Good luck... :)
Mar 22, 2009 | Acer Aspire 5100 Notebook
Acer aspire 5100 notebook kb and mouse doen't work on boot up
Try to remove ram memory and put it back after a while. Do it on removed battery.
Acer 5100 laptop doesn't work on ac or charger battery
Motherboard is bad and will have to be replaced unless of course the AC Jack on the back of the laptop is loose. That would cause the ac adapter not to charge and then you would have to take the motherboard out and put solder on each leg on the bottom of the ac jack to make sure it stays in place then the ac adapter can charge the battery properly.
Even going thru the solder method the motherboard could still be bad and have nothing to do with the ac jack.
Mar 08, 2009 | Acer Aspire 5100 Notebook
Acer aspire 5100 bios rattery how to remove and replace
you will have to shut down the unit and unplug the power cord from the pc:
(1) check and see if all of the connections are secure one of the ribbons from the board may have came loose or it may be loose on the harddrive its self
(2) check the cables and ribbons also to make sure that they are all in good working condition no cuts or broken or kinked wires
(3) power back up and see if you can hear the harddrive is spinning up. if not mayby the harddrive is bad
please try these things first ok and please keep me informed of how this goes ok best regards mike
Aug 27, 2008 | ASUS P5PE-VM Motherboard
My acer aspire 5100 mouse buttons
You have to go through the Control Panel, double click the mouse icon and find the settings for what is actually called a Glide Pad and change any values from there.
May 11, 2008 | Acer Aspire 5100 Notebook
Touchpad button loose
I shouldnt think that opening it up is necessary. The button should click back in with a gentle nudge. Else it is broken and needs to be replaced. If you can take it out completely and examine it you will know if it is broken.
Sep 30, 2007 | Acer Aspire 5100-5033 Notebook
Acer Aspire 5100-5033 Notebook Logo
152 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
