Question about Electrolux EWFLS70JSS Washer
Electrolux ewfls70jss does not drain
Does not drain
2 Suggested Answers
chrispolkele
  • 4342 Answers
Our people make the difference
    Verified Fixya Pro
    SOURCE: E26 code on Electrolux front load ewfls70jss
    Hello ajwalz - Typically E26 indicates that there is a recirculation pump relay. You will need a certified professional to check the wiring between the main control board and pump/recirculation board to determine which part has to be replaced.
    Posted on Sep 25, 2012
    After wash was completed, there are water sitting in fabric softener tray up to the full line
    Hello Warren, thank you for your post!
    From what you have described there is water filling up the fabric softener tray in your Electrolux washer, EWFLS70JSS. At times water will fill into your fabric softener due to draining and siphoning action however, this is a normal operation within your washer. Hopefully this information is helpful to you. -Matt
    Feb 26, 2016 | Electrolux EWFLS70JSS Washer
    Electrolux front load washer drain
    Good Afternoon Friend,
    I see that your Electrolux washer, model# EWFLS70JSS, is having trouble draining. First, I would start by checking the drain hose, to make sure there are no kinks in it and it is not clogged. Secondly, I would make sure that the drain hose is between 6-8 inches down inside the drainpipe. If it is too far inside the drainpipe, it can cause slow or no drainage. Thirdly, I would make sure that the drainpipe is not clogged. Finally, I suggest resetting your washer. You will do this by either unplugging it or shutting the power off at your homes circuit breaker for 2-3 minutes. When the power is restored, run a wash. If your washer is still experiencing a no drainage issue, I suggest contacting your local authorized technician. Hope this is helpful.
    -Best Regards-
    WP
    Apr 16, 2014 | Electrolux EWFLS70JSS Washer
    My electrolux EWFLS70JSS front load washer is showing a E57 error and is not entering spin cycle.
    Hello Walter, thank you for your post!
    An error code E57 could mean a number of issues, but primarily that the motor is overheating or a higher-than-usual motor current caused by other issues. Typically, an experienced technician would remove the belt to check the motor and motor pulley to ensure all is in working order first. Their next step would be to check the tub pulley and tub bearings. Last items they would examine would be the drive motor and speed control board by ohm measurement. Once the tech has ruled out a number of possibilities, he or she can pinpoint the exact problem and the necessary part to fix the issue. Since parts can often be quite costly, I would personally recommend reaching out to a qualified tech who can accurately diagnose the issue your washer is experiencing.
    Hope this proves helpful!
    Jan 16, 2014 | Electrolux EWFLS70JSS Washer
    Sep 25, 2012 | Electrolux EWFLS70JSS Washer
    Problem with electrolux washing machine
    draining pipe its too low. check this link:
    http://applianceguru.com/washers/drain-min.jpg
    Aug 26, 2012 | Electrolux Washing Machines
    I have an Electrolux washer model EWFLS70JSS. The bleach dispenses during the rinse cycle rather the wash cycle. I thank you in adavance for your help.
    This is a siphoning problem. Please clean out the dispenser cup(s) as much as you can and try again. You may need to clean the unit and run vinegar through instead of bleach to unclog any small components.
    Jul 23, 2012 | Electrolux EWFLS70JSS Washer
    Bleach getting dispensed during rinse cycle
    Never heard of Bleach being used in wash cycle ! Are you putting the Bleach in the correct dispenser .
    Display panel says key stuck, and door unlocks?
    If its giving you a F5 error code than your will have to replace the touchpad/ keypad. There is a malfunction.
    If you have anymore questions or need further help please feel free to contact me.
    Jul 27, 2011 | Electrolux EWFLS70JSS Washer
    Electrolux EWFLS70JSS Washer Logo
    50 people viewed this question
    Top Electrolux Washing Machines Experts
    Tim Whalen
    Dan Webster
    Dan Webster
    Are you an Electrolux Washing Machine Expert? Answer questions, earn points and help others
